root/radiance/ray/platform/cygwin.cfg
Sat Jun 7 09:07:18 2008 UTC (16 years ago) by schorsch
Changes since 1.7: +2 -0 lines
Diff to previous 1.7
Scons: EZXML_NOMMAP for cygwin.
Mon Apr 21 07:31:28 2008 UTC (16 years, 1 month ago) by schorsch
Diff to previous 1.6
Scons update for mingw.
Mon Sep 19 11:30:10 2005 UTC (18 years, 8 months ago) by schorsch
Diff to previous 1.5
Wed Sep 14 09:28:35 2005 UTC (18 years, 8 months ago) by schorsch
Changes since 1.4: +0 -1 lines
Diff to previous 1.4
Tue Sep 13 10:07:07 2005 UTC (18 years, 9 months ago) by schorsch
Changes since 1.3: +7 -5 lines
Diff to previous 1.3
New mingw.cfg, and fixes to the other Windows configs.
Wed Feb 2 00:17:35 2005 UTC (19 years, 4 months ago) by schorsch
Diff to previous 1.2
Turned bmalloc.c into a standard module.
Mon Oct 27 10:35:41 2003 UTC (20 years, 7 months ago) by schorsch
Changes since 1.1: +7 -1 lines
Diff to previous 1.1
Tue Oct 21 19:27:28 2003 UTC (20 years, 7 months ago) by schorsch
