root/Development/ray/platform/cygwin.cfg
Revision 1.9
Thu Mar 10 01:44:51 2016 UTC (9 years, 8 months ago) by schorsch
FILE REMOVED
arch dependent config
Sat Jun 7 09:07:18 2008 UTC (17 years, 5 months ago) by schorsch
Changes since 1.7: +2 -0 lines
Diff to previous 1.7
Scons: EZXML_NOMMAP for cygwin.
Revision 1.7 - (view) (download) (annotate) - [selected]
Mon Apr 21 07:31:28 2008 UTC (17 years, 7 months ago) by schorsch
Diff to previous 1.6
Scons update for mingw.
Mon Sep 19 11:30:10 2005 UTC (20 years, 2 months ago) by schorsch
Wed Sep 14 09:28:35 2005 UTC (20 years, 2 months ago) by schorsch
Changes since 1.4: +0 -1 lines
Tue Sep 13 10:07:07 2005 UTC (20 years, 2 months ago) by schorsch
Changes since 1.3: +7 -5 lines
New mingw.cfg, and fixes to the other Windows configs.
Wed Feb 2 00:17:35 2005 UTC (20 years, 9 months ago) by schorsch
Turned bmalloc.c into a standard module.
Mon Oct 27 10:35:41 2003 UTC (22 years ago) by schorsch
Changes since 1.1: +7 -1 lines
Tue Oct 21 19:27:28 2003 UTC (22 years, 1 month ago) by schorsch
Diff to selected 1.7
