root/radiance/ray/platform/aix.cfg
Mon Apr 21 07:31:28 2008 UTC (17 years ago) by schorsch
CVS Tags: rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Diff to previous 1.4
Scons update for mingw.
Mon Sep 19 11:30:10 2005 UTC (19 years, 7 months ago) by schorsch
Diff to previous 1.3
Wed Feb 2 00:17:35 2005 UTC (20 years, 3 months ago) by schorsch
Diff to previous 1.2
Turned bmalloc.c into a standard module.
Mon Oct 27 10:35:41 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 1.1: +6 -1 lines
Diff to previous 1.1
Tue Oct 21 19:27:28 2003 UTC (21 years, 6 months ago) by schorsch
