root/Development/ray/platform/Windows_32.cfg
Mon Mar 28 17:45:18 2016 UTC (9 years, 5 months ago) by schorsch
CVS Tags: HEAD, rad5R1, rad5R2, rad5R3, rad5R4, rad6R0
Diff to previous 1.12 , to selected 1.10
Compiler flags
Thu Mar 10 18:09:43 2016 UTC (9 years, 5 months ago) by schorsch
Changes since 1.11: +2 -1 lines
Diff to previous 1.11 , to selected 1.10
MS VC 2015 (possibly earler?) has learned about erf() and erfc()
Thu Mar 10 17:36:18 2016 UTC (9 years, 5 months ago) by schorsch
Changes since 1.10: +11 -6 lines
Diff to previous 1.10
Tifflib support and sleeker binaries on Windows
Revision 1.10 - (view) (download) (annotate) - [selected]
Thu Mar 10 01:44:51 2016 UTC (9 years, 5 months ago) by schorsch
Changes since 1.9: +5 -5 lines
Diff to previous 1.9
arch dependent config
Sun Mar 6 01:13:17 2016 UTC (9 years, 5 months ago) by schorsch
Changes since 1.8: +4 -4 lines
Diff to previous 1.8 , to selected 1.10
Mon Apr 21 07:31:28 2008 UTC (17 years, 4 months ago) by schorsch
CVS Tags: rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Changes since 1.7: +1 -0 lines
Diff to previous 1.7 , to selected 1.10
Scons update for mingw.
Mon Sep 19 11:30:10 2005 UTC (19 years, 11 months ago) by schorsch
Changes since 1.6: +2 -3 lines
Diff to previous 1.6 , to selected 1.10
Tue Sep 13 10:07:07 2005 UTC (19 years, 11 months ago) by schorsch
Changes since 1.5: +3 -3 lines
Diff to previous 1.5 , to selected 1.10
New mingw.cfg, and fixes to the other Windows configs.
Wed Feb 2 00:17:35 2005 UTC (20 years, 7 months ago) by schorsch
Diff to previous 1.4 , to selected 1.10
Turned bmalloc.c into a standard module.
Thu Oct 21 15:47:12 2004 UTC (20 years, 10 months ago) by schorsch
Changes since 1.3: +5 -5 lines
Diff to previous 1.3 , to selected 1.10
SCons build simplifications.
Sun Jul 4 12:08:47 2004 UTC (21 years, 2 months ago) by schorsch
Diff to previous 1.2 , to selected 1.10
Mon Oct 27 10:35:41 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 1.1: +10 -3 lines
Diff to previous 1.1 , to selected 1.10
Tue Oct 21 19:27:28 2003 UTC (21 years, 10 months ago) by schorsch
Diff to selected 1.10
