1 |
Platform configuration files for SCons based build procedure. |
2 |
3 |
4 |
<platform>.cfg |
5 |
6 |
7 |
The <platform>.cfg files in this directory are use to determine |
8 |
the right settings, libraries, source files etc. on the platform |
9 |
where you are building Radiance. The build system will select the |
10 |
right file automatically. |
11 |
12 |
If your platform isn't supported yet, then you can create a new |
13 |
file with an appropriat name (SCons will tell you what it |
14 |
expects). Usually, you will start by copying the file of the most |
15 |
similar suupported platform. |
16 |
17 |
On unix based platforms without a specific config file, the file |
18 |
"posix.cfg" will be used (which may or may not work well enough). |
19 |
20 |
21 |
<platform>_custom.cfg |
22 |
23 |
24 |
If you want to experiment with changes to the shipped file, then |
25 |
you can create a copy named <platform>_custom.cfg, and make your |
26 |
changes there. If such a file exists, then it will be used in |
27 |
place of the original. |
28 |
29 |
30 |
Contents and format |
31 |
32 |
33 |
Any text starting with a hash character (#) until the end of the |
34 |
line is ignored as a comment. |
35 |
36 |
A config file consists of several sections, each of which is |
37 |
introduced by a keyword in brackets. |
38 |
Within each section, a configuration directive starts with a |
39 |
keyword and a colon, followed by the specific instructions. |
40 |
41 |
42 |
Sections |
43 |
44 |
45 |
[install] # directories where to install the software |
46 |
[build] # compile and link instruction for production builds |
47 |
[debug] # compile and link instruction for debug builds |
48 |
[code] # code compatibility configuration |
49 |
50 |
51 |
Install section |
52 |
53 |
54 |
# The root directory of the Radiance installation |
55 |
RAD_BASEDIR: /home/gm/src/rad/r6b |
56 |
57 |
# The following are relative to RAD_BASEDIR! |
58 |
# The directory for executables |
59 |
RAD_BINDIR: bin |
60 |
# The directory for support files (.cal, .pic, .fnt, etc.) |
61 |
RAD_RLIBDIR: share/lib |
62 |
# The directory for the manual files |
63 |
RAD_MANDIR: share/man |
64 |
65 |
66 |
Debug and Build sections |
67 |
68 |
69 |
# The same keywords can be used in both, but usually their |
70 |
# assigned values will vary. |
71 |
72 |
# The compiler to use (example: Gnu gcc) |
73 |
CC: gcc |
74 |
75 |
# The directories for C header files (not normally needed). |
76 |
CPPPATH: |
77 |
78 |
# Symbols to define for the preprocessor (example for Cygwin) |
79 |
CPPDEFINES: freebsd HDSUF=.exe |
80 |
81 |
# Flags for the C preprocessor (example |
82 |
CPPFLAGS: -O2 -Wall -Wno-uninitialized |
83 |
84 |
# Flags for the C compiler (example for debug build) |
85 |
CCFLAGS: -pg |
86 |
87 |
# The directories for required libraris (not normally needed) |
88 |
LIBPATH: |
89 |
90 |
# Flags for the linker (example for debug build on Windows) |
91 |
LINKFLAGS: /debug |
92 |
93 |
# Flags specific to ezxml.c (example for cygwin/mingw) |
94 |
EZXML_CPPDEFINES: EZXML_NOMMAP |
95 |
96 |
# Where to find an installed libtiff and its include files |
97 |
# (Not needed when on a standard search path) |
98 |
# If no libtiff is found here or on the standard paths, then |
99 |
# Radiance will build its own. |
100 |
TIFFLIB: |
101 |
TIFFINCLUDE: |
102 |
103 |
104 |
The Code section |
105 |
106 |
107 |
# There should be no need to edit this section in existing |
108 |
# config files. If you create a new file for a yet untested |
109 |
# platform, you may need to ask on the dev-list what might |
110 |
# work best. |
111 |
112 |
RAD_COMPAT: # theoretically obsolete (src/common/strcmp.c) |
113 |
RAD_MATHCOMPAT: # erf.c floating point error function |
114 |
RAD_ARGSCOMPAT: # fixargv0.c for Windows |
115 |
RAD_NETCOMPAT: # [win_]netproc.c for ranimate |
116 |
RAD_MLIB: # usually 'm', or any fastlib available |
117 |
RAD_SOCKETLIB: # ws_2_32 on Windows (VC links it automatically) |
118 |
RAD_PROCESS: # our process abstraction and win_popen() |
119 |
RAD_PCALLS: # more custom process abstraction |
120 |
