| 1 |
Platform configuration files for the SCons based build system |
| 2 |
| 3 |
| 4 |
<platform>.cfg |
| 5 |
| 6 |
| 7 |
The <platform>.cfg files in this directory are used to determine |
| 8 |
the right settings, libraries, source files etc. on the platform |
| 9 |
where you are building Radiance. The build system will select the |
| 10 |
appropriate file automatically. |
| 11 |
| 12 |
If your platform isn't supported yet, then you can create a new |
| 13 |
file with an appropriat name (SCons should tell you what it |
| 14 |
expects). Usually, you will start by copying the file of the most |
| 15 |
similar suupported platform, and then make the necessary changes. |
| 16 |
| 17 |
On unix based platforms without a specific config file, the file |
| 18 |
"posix.cfg" will be used (which may or may not work well enough). |
| 19 |
| 20 |
As of this writing, the following platforms are included |
| 21 |
(although not all of them have been tested very recently): |
| 22 |
| 23 |
* linux.cfg Linux |
| 24 |
* freebsd.cfg FreeBSD unix |
| 25 |
* darwin.cfg Macintosh OS-X |
| 26 |
* sunos.cfg Sun Microsysems Solaris Unix |
| 27 |
* irix.cfg sgi IRIX Unix release 5.x or later |
| 28 |
* irix4.cfg sgi IRIX Unix release 4.x (obsolete) |
| 29 |
* irix3.cfg sgi IRIX Unix release 3.x (obsolete) |
| 30 |
* hpux.cfg Hewlett Packard HP-Unix |
| 31 |
* aix.cfg IBM AIX Unix |
| 32 |
* posix.cfg default for unknown Unix systems |
| 33 |
* win32.cfg MS Windows (Visual C compilers) |
| 34 |
* cygwin.cfg Cygwin on MS Windows http://www.cygwin.com/ |
| 35 |
* mingw.cfg MingW on MS Windows http://www.mingw.org/ |
| 36 |
| 37 |
| 38 |
<platform>_custom.cfg |
| 39 |
| 40 |
| 41 |
If you want to experiment with changes to the shipped file, then |
| 42 |
you can create a copy named <platform>_custom.cfg, and make your |
| 43 |
changes there. If such a file exists, then it will be used in |
| 44 |
place of the original. |
| 45 |
| 46 |
| 47 |
Contents and format |
| 48 |
| 49 |
| 50 |
Any text starting with a hash character (#) until the end of the |
| 51 |
line is ignored as a comment. |
| 52 |
| 53 |
A config file consists of several sections, each of which is |
| 54 |
introduced by a keyword in brackets. |
| 55 |
Within each section, a configuration directive starts with a |
| 56 |
keyword and a colon, followed by the data assigned to that keyword. |
| 57 |
| 58 |
| 59 |
Sections |
| 60 |
| 61 |
| 62 |
[install] # directories where to install the software |
| 63 |
[build] # compile and link instructions for production builds |
| 64 |
[debug] # compile and link instructions for debug builds |
| 65 |
[code] # code compatibility configuration |
| 66 |
| 67 |
| 68 |
Install section |
| 69 |
| 70 |
| 71 |
# The root directory of the Radiance installation |
| 72 |
RAD_BASEDIR: /opt/radiance3.6 |
| 73 |
| 74 |
# The following are relative to RAD_BASEDIR! |
| 75 |
# The directory for executables |
| 76 |
RAD_BINDIR: bin |
| 77 |
| 78 |
# The directory for support files (.cal, .pic, .fnt, etc.) |
| 79 |
RAD_RLIBDIR: share/lib |
| 80 |
| 81 |
# The directory for the man pages |
| 82 |
RAD_MANDIR: share/man |
| 83 |
| 84 |
| 85 |
Debug and Build sections |
| 86 |
| 87 |
| 88 |
# The same keywords can (and usually will) be used in both, but |
| 89 |
# their assigned values will often differ. |
| 90 |
| 91 |
# The compiler to use (example: Gnu gcc) |
| 92 |
CC: gcc |
| 93 |
| 94 |
# The directories for system header files (not normally needed). |
| 95 |
CPPPATH: |
| 96 |
| 97 |
# Symbols to define for the preprocessor (example for Cygwin) |
| 98 |
CPPDEFINES: freebsd HDSUF=.exe |
| 99 |
| 100 |
# Flags for the C preprocessor (example |
| 101 |
CPPFLAGS: -O2 -Wall -Wno-uninitialized |
| 102 |
| 103 |
# Flags for the C compiler (example for debug build with gcc) |
| 104 |
CCFLAGS: -pg |
| 105 |
| 106 |
# The directories for system libraries (not normally needed) |
| 107 |
LIBPATH: |
| 108 |
| 109 |
# Flags for the linker (example for debug build on Windows) |
| 110 |
LINKFLAGS: /debug |
| 111 |
| 112 |
# Flags specific to ezxml.c (example for cygwin/mingw) |
| 113 |
EZXML_CPPDEFINES: EZXML_NOMMAP |
| 114 |
| 115 |
# Where to find an installed libtiff and its include files |
| 116 |
# (Not needed when on a standard search path) |
| 117 |
# If no libtiff is found here or on the standard paths, then |
| 118 |
# Radiance will build its own. |
| 119 |
TIFFLIB: |
| 120 |
TIFFINCLUDE: |
| 121 |
| 122 |
| 123 |
The Code section |
| 124 |
| 125 |
| 126 |
# There should be no need to edit this section in existing |
| 127 |
# config files. If you create a new file for a yet untested |
| 128 |
# platform, you may need to ask on the dev-list what will |
| 129 |
# work here. |
| 130 |
| 131 |
RAD_COMPAT: # theoretically obsolete (src/common/strcmp.c) |
| 132 |
RAD_MATHCOMPAT: # erf.c floating point error function |
| 133 |
RAD_ARGSCOMPAT: # fixargv0.c for Windows |
| 134 |
RAD_NETCOMPAT: # [win_]netproc.c for ranimate |
| 135 |
RAD_MLIB: # usually 'm', or any fastlib available |
| 136 |
RAD_SOCKETLIB: # ws_2_32 on Windows (VC links it automatically) |
| 137 |
RAD_PROCESS: # our process abstraction and win_popen() |
| 138 |
RAD_PCALLS: # more custom process abstraction |
| 139 |
| 140 |
| 141 |
