root/radiance/ray/platform/FreeBSD_32.cfg
Mon Sep 19 11:30:10 2005 UTC (19 years, 6 months ago) by schorsch
Diff to previous 1.4
Wed Feb 2 00:17:35 2005 UTC (20 years, 1 month ago) by schorsch
Diff to previous 1.3
Turned bmalloc.c into a standard module.
Thu Oct 21 15:47:12 2004 UTC (20 years, 4 months ago) by schorsch
Changes since 1.2: +6 -6 lines
Diff to previous 1.2
SCons build simplifications.
Mon Oct 27 10:35:41 2003 UTC (21 years, 4 months ago) by schorsch
Changes since 1.1: +7 -1 lines
Diff to previous 1.1
Tue Oct 21 19:27:28 2003 UTC (21 years, 5 months ago) by schorsch
