root/radiance/ray/platform/FreeBSD_32.cfg
Thu Mar 10 18:56:34 2016 UTC (9 years, 1 month ago) by schorsch
CVS Tags: HEAD, rad5R1, rad5R2, rad5R3, rad5R4
Diff to previous 1.7
everybody seems to have erf() and erfc() nowadays.
Revision 1.7 - (view) (download) (annotate) - [selected]
Thu Mar 10 01:44:51 2016 UTC (9 years, 1 month ago) by schorsch
Changes since 1.6: +4 -4 lines
Diff to previous 1.6
arch dependent config
Mon Apr 21 07:31:28 2008 UTC (17 years ago) by schorsch
CVS Tags: rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Changes since 1.5: +1 -0 lines
Scons update for mingw.
Mon Sep 19 11:30:10 2005 UTC (19 years, 7 months ago) by schorsch
Wed Feb 2 00:17:35 2005 UTC (20 years, 3 months ago) by schorsch
Turned bmalloc.c into a standard module.
Thu Oct 21 15:47:12 2004 UTC (20 years, 6 months ago) by schorsch
Changes since 1.2: +6 -6 lines
SCons build simplifications.
Mon Oct 27 10:35:41 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 1.1: +7 -1 lines
Tue Oct 21 19:27:28 2003 UTC (21 years, 6 months ago) by schorsch
Diff to selected 1.7
