root/radiance/ray/platform/Darwin_32.cfg
Mon Apr 21 07:31:28 2008 UTC (17 years, 2 months ago) by schorsch
CVS Tags: rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Changes since 1.6: +1 -0 lines
Scons update for mingw.
Mon Sep 19 11:30:10 2005 UTC (19 years, 9 months ago) by schorsch
Wed Feb 2 00:17:35 2005 UTC (20 years, 5 months ago) by schorsch
Turned bmalloc.c into a standard module.
Thu Oct 21 15:47:12 2004 UTC (20 years, 8 months ago) by schorsch
Changes since 1.3: +7 -7 lines
SCons build simplifications.
Sun Jul 4 12:08:47 2004 UTC (21 years ago) by schorsch
Diff to previous 1.2
Mon Oct 27 10:35:41 2003 UTC (21 years, 8 months ago) by schorsch
Changes since 1.1: +6 -1 lines
Diff to previous 1.1
Tue Oct 21 19:27:28 2003 UTC (21 years, 8 months ago) by schorsch
Diff to selected 1.2
