root/radiance/ray/noX11.help
Revision: 1.1
Committed: Sat Mar 15 17:55:48 2003 UTC (21 years ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R5, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1
1 SCCSid "@(#)noX11.help 2.5 11/4/92 LBL"
2 This Radiance distribution assumes that you have X11 support
3 (ie. a /usr/include/X11 directory and /usr/lib/libX11.a library).
4 If you have X11 installed but in a non-standard location, you only
5 need to edit the rmake script to add the needed -I and -L options.
6 If this is not the case, you will have to make a couple of changes
7 to the files in the src/rt directory to make "rview" compile properly.
8 If you are a thorough person, you can also make changes to the Rmakefile's
9 in the src/util and src/px directory to avoid some other spurious but
10 unimportant errors. If you do not, you will have to copy the executable
11 files from those directories manually since rmake will not do so.
12
13 The following diffs should be applied to Rmakefile and devtable.c in the
14 src/rt subdirectory:
15
16 ============= rt/Rmakefile =============
17 35c35
18 < DOBJS = devtable.o devcomm.o editline.o x11.o x11twind.o \
19 ---
20 > DOBJS = devtable.o devcomm.o editline.o \
21 37c37
22 < DSRC = devtable.c devcomm.c editline.c x11.c x11twind.c \
23 ---
24 > DSRC = devtable.c devcomm.c editline.c \
25 39c39
26 < DLIBS = -lX11
27 ---
28 > DLIBS =
29
30 ============= rt/devtable.c =============
31 15c15
32 < char dev_default[] = "x11";
33 ---
34 > char dev_default[] = "sun"; /* or "news" for SGI */
35 17,18d16
36 < extern struct driver *x11_init();
37 <
38 23c21
39 < {"x11", "X11 color or greyscale display", x11_init},
40 ---
41 > {"x11", "X11 color or greyscale display", comm_init},
42
43 These changes may be applied to the Rmakefile's in the src/util and
44 src/px subdirectories for cleaner compilation:
45
46 =============== px/Rmakefile =============
47 19c19
48 < ra_t8 ra_bn ra_t16 pcomb pinterp ximage xshowtrace pflip
49 ---
50 > ra_t8 ra_bn ra_t16 pcomb pinterp pflip
51
52 =============== util/Rmakefile ============
53 13c13
54 < PROGS = rpiece findglare xglaresrc glarendx
55 ---
56 > PROGS = rpiece findglare glarendx
