root/Development/ray/noX11.help
Revision: 1.2
Committed: Fri Apr 6 17:52:33 2018 UTC (7 years, 8 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, HEAD
Changes since 1.1: +2 -11 lines
Made excluding X11 a little simpler
# User Rev Content
1 greg 1.1 SCCSid "@(#)noX11.help 2.5 11/4/92 LBL"
2     This Radiance distribution assumes that you have X11 support
3     (ie. a /usr/include/X11 directory and /usr/lib/libX11.a library).
4     If you have X11 installed but in a non-standard location, you only
5     need to edit the rmake script to add the needed -I and -L options.
6     If this is not the case, you will have to make a couple of changes
7     to the files in the src/rt directory to make "rview" compile properly.
8     If you are a thorough person, you can also make changes to the Rmakefile's
9     in the src/util and src/px directory to avoid some other spurious but
10     unimportant errors. If you do not, you will have to copy the executable
11     files from those directories manually since rmake will not do so.
12
13     The following diffs should be applied to Rmakefile and devtable.c in the
14     src/rt subdirectory:
15
16     ============= rt/Rmakefile =============
17     35c35
18     < DOBJS = devtable.o devcomm.o editline.o x11.o x11twind.o \
19     ---
20     > DOBJS = devtable.o devcomm.o editline.o \
21     37c37
22     < DSRC = devtable.c devcomm.c editline.c x11.c x11twind.c \
23     ---
24     > DSRC = devtable.c devcomm.c editline.c \
25     39c39
26     < DLIBS = -lX11
27     ---
28     > DLIBS =
29
30     ============= rt/devtable.c =============
31 greg 1.2 11i
32     > #define X11 0
33 greg 1.1
34     These changes may be applied to the Rmakefile's in the src/util and
35     src/px subdirectories for cleaner compilation:
36
37     =============== px/Rmakefile =============
38     19c19
39     < ra_t8 ra_bn ra_t16 pcomb pinterp ximage xshowtrace pflip
40     ---
41     > ra_t8 ra_bn ra_t16 pcomb pinterp pflip
42
43     =============== util/Rmakefile ============
44     13c13
45     < PROGS = rpiece findglare xglaresrc glarendx
46     ---
47     > PROGS = rpiece findglare glarendx
