Fixed instructions regarding Bourne shell
Fixed library removal during clean
Fixed build problem related to programs using raycalls.a (mksource)
Changed all of malloc.o to bmalloc.o (could make that a regular compile now).
Removed mention of retired getpagesize.c compatibility module
Changed to using new license text from src/common/copyright.h
Added comment about setting path variable to end of install script
Added Cygwin build configuration (not fully functional yet).
Added installation of source *.cal files to "makeall library"
Large file support on Linux, suggested by Randolph Fritz.
Attempted fix to AIX compile problems
Took "ogl" special compile away for Solaris, which doesn't seem to support it
Portability fixes immediately following 3.5 release
Added missing installib script required by makeall
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
