root/radiance/ray/makeall
Revision: 1.5
Committed: Thu May 15 05:13:35 2003 UTC (21 years, 11 months ago) by greg
Changes since 1.4: +1 -31 lines
1 #!/bin/csh -f
2 # RCSid $Id$
3 #
4 #Added macosX 2001-04-11 by Jean Brange
5 #Deleted obsolete systems 2001-04-18 by Greg Ward
6 #
7 # Make all the Radiance programs
8 #
9 if ( $#argv < 1 ) then
10 echo "Usage: makeall install [clean] [make options]"
11 echo " or: makeall clean"
12 echo " or: makeall library"
13 exit 1
14 endif
15 if ( "$1" == library ) then
16 source installib
17 echo ""
18 echo "Set the environment variable RAYPATH=.:$ldir"
19 echo 'For C-shell users, put the following into ~/.cshrc'
20 echo " setenv RAYPATH .:$ldir"
21 echo 'For Bourne shell users, put the following into $HOME/profile'
22 echo " RAYPATH=.:$ldir"
23 echo " export RAYPATH"
24 echo ""
25 exit 0
26 endif
27 set srcdirs=( common meta cv gen ot rt px hd util cal )
28 if ( "$1" == install ) then
29 cat << _EOF_
30
31 `cat src/rt/VERSION` INSTALLATION
32
33 This script rebuilds all of the Radiance programs and installs
34 them on your system. You should read the file README before running
35 this script. You can type ^C (followed by return) at any time to abort.
36
37 You must first answer the following questions.
38
39 _EOF_
40 if ( ! $?EDITOR ) then
41 echo -n "What is your preferred editor [vi]? "
42 set ans="$<"
43 if ( "$ans" != "" ) then
44 setenv EDITOR "$ans"
45 else
46 setenv EDITOR vi
47 endif
48 endif
49 again1:
50 echo -n "Where do you want the executables [/usr/local/bin]? "
51 set idir=$<
52 (echo $idir) >/dev/null
53 if ( $status ) then
54 goto again1
55 endif
56 set idir=$idir
57 if ( "$idir" == "" ) then
58 set idir=/usr/local/bin
59 else if ( "$idir" !~ /* ) then
60 echo "Directory must be relative to root, please reenter"
61 goto again1
62 endif
63 if ( ! -d $idir ) then
64 mkdir $idir
65 if ( $status ) then
66 echo "Cannot create directory, please reenter"
67 goto again1
68 endif
69 endif
70 if ( ! -d $idir/dev ) then
71 mkdir $idir/dev
72 if ( $status ) then
73 echo "Cannot create subdirectory, please reenter"
74 goto again1
75 endif
76 endif
77 set rmake=$idir/rmake
78 if ( "`ls -tL $rmake $0 |& head -1`" == $rmake ) then
79 goto gotrmake
80 endif
81 set newrmake
82 goto skiplicense
83 cat << _EOF_
84
85 RADIANCE LICENSE AGREEMENT
86
87 Radiance is a registered copyright of The Regents of the University of
88 California ("The Regents"). The Regents grant to you a nonexclusive,
89 nontransferable license ("License") to use Radiance source code without
90 fee. You may not sell or distribute Radiance to others without the
91 prior express written permission of The Regents. You may compile and
92 use this software on any machines to which you have personal access,
93 and may share its use with others who have access to the same machines.
94
95 NEITHER THE UNITED STATES NOR THE UNITED STATES DEPARTMENT OF ENERGY, NOR ANY
96 OF THEIR EMPLOYEES, MAKES ANY WARRANTY, EXPRESS OR IMPLIED, OR ASSUMES ANY
97 LEGAL LIABILITY OR RESPONSIBILITY FOR THE ACCURACY, COMPLETENESS, OR USEFULNESS
98 OF ANY INFORMATION, APPARATUS, PRODUCT, OR PROCESS DISCLOSED, OR REPRESENTS
99 THAT ITS USE WOULD NOT INFRINGE PRIVATELY OWNED RIGHTS. By downloading, using
100 or copying this software, you agree to abide by the intellectual property laws
101 and all other applicable laws of the United States, and by the terms of this
102 License Agreement. Ownership of the software shall remain solely in The
103 Regents. The Regents shall have the right to terminate this License
104 immediately by written notice upon your breach of, or noncompliance with, any
105 of its terms. You shall be liable for any infringement or damages resulting
106 from your failure to abide by the terms of this License Agreement.
107
108 _EOF_
109 echo -n "Do you understand and accept the terms of this agreement [n]? "
110 set ans="$<"
111 if ( "$ans" !~ [yY]* ) exit
112 echo -n "Are you a new Radiance user or with a new address [y]? "
113 set ans="$<"
114 if ( "$ans" !~ [nN]* ) then
115 csh -f newuser
116 else
117 echo `cat src/rt/VERSION` compiled by `whoami` | mail [email protected]
118 endif
119 skiplicense:
120 set special=
121 set arch=
122 set opt=
123 set mach=
124 set compat=
125 set extras=
126 cat << _EOF_
127
128 Please select your system type from the following list:
129
130 1) Sun Solaris
131 2) HP workstation
132 3) Silicon Graphics
133 4) AIX (RS/6000)
134 5) BSDI BSD/386
135 6) Linux
136 7) MacOS X
137 8) FreeBSD
138 9) Other
139
140 _EOF_
141 echo -n "Choice? "
142 set arch="$<"
143 switch ("$arch")
144 case 1: # SPARC Station
145 set arch=sun
146 set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO"
147 set opt="-O -DSPEED=80"
148 set compat="bmalloc.o strcmp.o getpagesize.o"
149 breaksw
150 case 2: # HP workstation
151 set mach=""
152 set opt="-O -DSPEED=80 -Aa -D_HPUX_SOURCE"
153 set compat="bmalloc.o getpagesize.o strcmp.o"
154 set arch=hpux
155 breaksw
156 case 3: # Silicon Graphics
157 set arch=sgi
158 switch (`uname -r`)
159 case 3.*:
160 set mach="-noprototypes"
161 set opt="-O -DSPEED=80"
162 set special="sgi"
163 set compat="malloc.o strcmp.o"
164 breaksw
165 case 4.*:
166 set mach=""
167 set opt="-O2 -DSPEED=100"
168 set compat="malloc.o strcmp.o"
169 set extras='"MLIB=-lfastm -lm"'
170 breaksw
171 default: # 5.x or later
172 ln -s `which wish` $idir/wish4.0
173 set path=($idir $path)
174 set mach="-w"
175 set opt="-O2 -DSPEED=200"
176 set special="ogl"
177 set compat="bmalloc.o strcmp.o"
178 breaksw
179 endsw
180 breaksw
181 case 4: # AIX
182 set mach="-Dvoid=char -DNOPROTO -DINCL_SEL_H"
183 set opt="-O"
184 set compat="bmalloc.o erf.o"
185 breaksw
186 case 5: # BSDI BSD/386
187 set mach="-DBSD -L/usr/X11/lib -I/usr/X11/include"
188 set opt="-O -DSPEED=100"
189 set arch=IBMPC
190 set compat="malloc.o erf.o strcmp.o"
191 breaksw
192 case 6: # Linux
193 set mach="-Dlinux -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO"
194 set opt="-O2 -DSPEED=200"
195 set arch=IBMPC
196 set compat="bmalloc.o erf.o getpagesize.o"
197 set extras=CC=gcc
198 breaksw
199 case 7: # MacOS X
200 set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib"
201 set opt="-O2 -DSPEED=200"
202 set arch=PowerPC
203 set compat="bmalloc.o"
204 set extras="CC=cc CONFIGURE_ARCH=powerpc"
205 set special="ogl"
206 breaksw
207 case 8: # FreeBSD
208 set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib"
209 set opt="-O -DSPEED=200"
210 set compat="bmalloc.o erf.o"
211 set extras="CC=cc"
212 set arch=IBMPC
213 breaksw
214 case 9: # Other
215 set opt="-O"
216 set compat="bmalloc.o erf.o strcmp.o"
217 echo -n "Are you using the GNU C compiler [n]? "
218 if ( "$<" =~ [yY]* ) then
219 set extras="CC=gcc"
220 endif
221 breaksw
222 default:
223 echo "Illegal choice\!"
224 echo "Installation aborted."
225 exit 1
226 breaksw
227 endsw
228 source installib
229 sed 's/[ ]*$//' > $rmake << _EOF_
230 #!/bin/sh
231 exec make "SPECIAL=$special" \
232 "OPT=$opt" \
233 "MACH=$mach" \
234 ARCH=$arch "COMPAT=$compat" \
235 INSTDIR=$idir \
236 LIBDIR=$ldir \
237 $extras "\$@" -f Rmakefile
238 _EOF_
239 chmod 755 $rmake
240 chmod 644 src/*/Rmakefile src/rt/devtable.c
241 gotrmake:
242 echo "Current rmake command is:"
243 cat $rmake
244 echo -n "Do you want to change it? "
245 set ans="$<"
246 if ( "$ans" =~ [yY]* ) then
247 cp $rmake /tmp/rmake$$
248 $EDITOR $rmake
249 if ( `cat $rmake /tmp/rmake$$ | grep OPT= | uniq | wc -l` == 2 ) set newrmake
250 rm -f /tmp/rmake$$
251 endif
252 if ( ! -d src/lib ) then
253 mkdir src/lib
254 endif
255 if ( $?newrmake ) then
256 echo 'New rmake command -- running "makeall clean"...'
257 csh -f $0 clean
258 endif
259 cd src
260 echo "Making programs..."
261 set errs=0
262 foreach i ( $srcdirs )
263 pushd $i
264 echo "In directory $i..."
265 $rmake -k $*
266 @ errs += $status
267 popd
268 end
269 if ( $errs ) then
270 echo "There were some errors."
271 else
272 echo "Done."
273 endif
274 cd ..
275 if (! -d /usr/tmp) then
276 ln -s /tmp /usr/tmp
277 if ($status) then
278 echo ""
279 echo "IMPORTANT: Execute 'sudo ln -s /tmp /usr/tmp'"
280 echo ""
281 endif
282 endif
283 else
284 cd src
285 foreach i ( $srcdirs )
286 pushd $i
287 echo "In directory $i..."
288 make -f Rmakefile $*
289 popd
290 end
291 echo "Done."
292 cd ..
293 endif
294 foreach i ( $* )
295 if ( "$i" == clean ) then
296 echo "Removing library archives..."
297 rm -f src/lib/*.[ao]
298 endif
299 end
300 exit 0
