| 1 |
#!/bin/csh -f
| 2 |
# RCSid $Id$
| 3 |
| 4 |
#Added macosX 2001-04-11 by Jean Brange
| 5 |
#Deleted obsolete systems 2001-04-18 by Greg Ward
| 6 |
| 7 |
# Make all the Radiance programs
| 8 |
| 9 |
if ( $#argv < 1 ) then
| 10 |
echo "Usage: makeall install [clean] [make options]"
| 11 |
echo " or: makeall clean"
| 12 |
echo " or: makeall library"
| 13 |
exit 1
| 14 |
endif
| 15 |
if ( "$1" == library ) then
| 16 |
source installib
| 17 |
echo ""
| 18 |
echo "Set the environment variable RAYPATH=.:$ldir"
| 19 |
echo 'For C-shell users, put the following into ~/.cshrc'
| 20 |
echo " setenv RAYPATH .:$ldir"
| 21 |
echo 'For Bourne shell users, put the following into $HOME/profile'
| 22 |
echo " RAYPATH=.:$ldir"
| 23 |
echo " export RAYPATH"
| 24 |
echo ""
| 25 |
exit 0
| 26 |
endif
| 27 |
set srcdirs=( common meta cv gen ot rt px hd util cal )
| 28 |
if ( "$1" == install ) then
| 29 |
cat << _EOF_
| 30 |
| 31 |
`cat src/rt/VERSION` INSTALLATION
| 32 |
| 33 |
This script rebuilds all of the Radiance programs and installs
| 34 |
them on your system. You should read the file README before running
| 35 |
this script. You can type ^C (followed by return) at any time to abort.
| 36 |
| 37 |
You must first answer the following questions.
| 38 |
| 39 |
_EOF_
| 40 |
if ( ! $?EDITOR ) then
| 41 |
echo -n "What is your preferred editor [vi]? "
| 42 |
set ans="$<"
| 43 |
if ( "$ans" != "" ) then
| 44 |
setenv EDITOR "$ans"
| 45 |
else
| 46 |
setenv EDITOR vi
| 47 |
endif
| 48 |
endif
| 49 |
again1:
| 50 |
echo -n "Where do you want the executables [/usr/local/bin]? "
| 51 |
set idir=$<
| 52 |
(echo $idir) >/dev/null
| 53 |
if ( $status ) then
| 54 |
goto again1
| 55 |
endif
| 56 |
set idir=$idir
| 57 |
if ( "$idir" == "" ) then
| 58 |
set idir=/usr/local/bin
| 59 |
else if ( "$idir" !~ /* ) then
| 60 |
echo "Directory must be relative to root, please reenter"
| 61 |
goto again1
| 62 |
endif
| 63 |
if ( ! -d $idir ) then
| 64 |
mkdir $idir
| 65 |
if ( $status ) then
| 66 |
echo "Cannot create directory, please reenter"
| 67 |
goto again1
| 68 |
endif
| 69 |
endif
| 70 |
if ( ! -d $idir/dev ) then
| 71 |
mkdir $idir/dev
| 72 |
if ( $status ) then
| 73 |
echo "Cannot create subdirectory, please reenter"
| 74 |
goto again1
| 75 |
endif
| 76 |
endif
| 77 |
set rmake=$idir/rmake
| 78 |
if ( "`ls -tL $rmake $0 |& head -1`" == $rmake ) then
| 79 |
goto gotrmake
| 80 |
endif
| 81 |
set newrmake
| 82 |
goto skiplicense
| 83 |
cat << _EOF_
| 84 |
| 85 |
RADIANCE LICENSE AGREEMENT
| 86 |
| 87 |
Radiance is a registered copyright of The Regents of the University of
| 88 |
California ("The Regents"). The Regents grant to you a nonexclusive,
| 89 |
nontransferable license ("License") to use Radiance source code without
| 90 |
fee. You may not sell or distribute Radiance to others without the
| 91 |
prior express written permission of The Regents. You may compile and
| 92 |
use this software on any machines to which you have personal access,
| 93 |
and may share its use with others who have access to the same machines.
| 94 |
| 95 |
NEITHER THE UNITED STATES NOR THE UNITED STATES DEPARTMENT OF ENERGY, NOR ANY
| 96 |
OF THEIR EMPLOYEES, MAKES ANY WARRANTY, EXPRESS OR IMPLIED, OR ASSUMES ANY
| 97 |
LEGAL LIABILITY OR RESPONSIBILITY FOR THE ACCURACY, COMPLETENESS, OR USEFULNESS
| 98 |
OF ANY INFORMATION, APPARATUS, PRODUCT, OR PROCESS DISCLOSED, OR REPRESENTS
| 99 |
THAT ITS USE WOULD NOT INFRINGE PRIVATELY OWNED RIGHTS. By downloading, using
| 100 |
or copying this software, you agree to abide by the intellectual property laws
| 101 |
and all other applicable laws of the United States, and by the terms of this
| 102 |
License Agreement. Ownership of the software shall remain solely in The
| 103 |
Regents. The Regents shall have the right to terminate this License
| 104 |
immediately by written notice upon your breach of, or noncompliance with, any
| 105 |
of its terms. You shall be liable for any infringement or damages resulting
| 106 |
from your failure to abide by the terms of this License Agreement.
| 107 |
| 108 |
_EOF_
| 109 |
echo -n "Do you understand and accept the terms of this agreement [n]? "
| 110 |
set ans="$<"
| 111 |
if ( "$ans" !~ [yY]* ) exit
| 112 |
echo -n "Are you a new Radiance user or with a new address [y]? "
| 113 |
set ans="$<"
| 114 |
if ( "$ans" !~ [nN]* ) then
| 115 |
csh -f newuser
| 116 |
else
| 117 |
echo `cat src/rt/VERSION` compiled by `whoami` | mail [email protected]
| 118 |
endif
| 119 |
skiplicense:
| 120 |
set special=
| 121 |
set arch=
| 122 |
set opt=
| 123 |
set mach=
| 124 |
set compat=
| 125 |
set extras=
| 126 |
cat << _EOF_
| 127 |
| 128 |
Please select your system type from the following list:
| 129 |
| 130 |
1) Sun Solaris
| 131 |
2) HP workstation
| 132 |
3) Silicon Graphics
| 133 |
4) AIX (RS/6000)
| 134 |
5) BSDI BSD/386
| 135 |
6) Linux
| 136 |
7) MacOS X
| 137 |
8) FreeBSD
| 138 |
9) Other
| 139 |
| 140 |
_EOF_
| 141 |
echo -n "Choice? "
| 142 |
set arch="$<"
| 143 |
switch ("$arch")
| 144 |
case 1: # SPARC Station
| 145 |
set arch=sun
| 146 |
set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO"
| 147 |
set opt="-O -DSPEED=80"
| 148 |
set compat="bmalloc.o strcmp.o getpagesize.o"
| 149 |
breaksw
| 150 |
case 2: # HP workstation
| 151 |
set mach=""
| 152 |
set opt="-O -DSPEED=80 -Aa -D_HPUX_SOURCE"
| 153 |
set compat="bmalloc.o getpagesize.o strcmp.o"
| 154 |
set arch=hpux
| 155 |
breaksw
| 156 |
case 3: # Silicon Graphics
| 157 |
set arch=sgi
| 158 |
switch (`uname -r`)
| 159 |
case 3.*:
| 160 |
set mach="-noprototypes"
| 161 |
| 162 |
set special="sgi"
| 163 |
set compat="malloc.o strcmp.o"
| 164 |
breaksw
| 165 |
case 4.*:
| 166 |
set mach=""
| 167 |
set opt="-O2 -DSPEED=100"
| 168 |
| 169 |
set extras='"MLIB=-lfastm -lm"'
| 170 |
breaksw
| 171 |
default: # 5.x or later
| 172 |
ln -s `which wish` $idir/wish4.0
| 173 |
set path=($idir $path)
| 174 |
set mach="-w"
| 175 |
set opt="-O2 -DSPEED=200"
| 176 |
set special="ogl"
| 177 |
set compat="bmalloc.o strcmp.o"
| 178 |
breaksw
| 179 |
endsw
| 180 |
breaksw
| 181 |
case 4: # AIX
| 182 |
set mach="-Dvoid=char -D_NO_PROTO -DINCL_SEL_H"
| 183 |
set opt="-O"
| 184 |
set compat="bmalloc.o erf.o"
| 185 |
breaksw
| 186 |
case 5: # BSDI BSD/386
| 187 |
set mach="-DBSD -L/usr/X11/lib -I/usr/X11/include"
| 188 |
set opt="-O -DSPEED=100"
| 189 |
set arch=IBMPC
| 190 |
set compat="malloc.o erf.o strcmp.o"
| 191 |
breaksw
| 192 |
case 6: # Linux
| 193 |
set mach="-Dlinux -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO"
| 194 |
| 195 |
set arch=IBMPC
| 196 |
set compat="bmalloc.o erf.o getpagesize.o"
| 197 |
set extras=CC=gcc
| 198 |
breaksw
| 199 |
case 7: # MacOS X
| 200 |
set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib"
| 201 |
| 202 |
set arch=PowerPC
| 203 |
set compat="bmalloc.o"
| 204 |
set extras="CC=cc CONFIGURE_ARCH=powerpc"
| 205 |
set special="ogl"
| 206 |
breaksw
| 207 |
case 8: # FreeBSD
| 208 |
| 209 |
set opt="-O -DSPEED=200"
| 210 |
| 211 |
set extras="CC=cc"
| 212 |
set arch=IBMPC
| 213 |
breaksw
| 214 |
case 9: # Other
| 215 |
set opt="-O"
| 216 |
set compat="bmalloc.o erf.o strcmp.o"
| 217 |
echo -n "Are you using the GNU C compiler [n]? "
| 218 |
if ( "$<" =~ [yY]* ) then
| 219 |
set extras="CC=gcc"
| 220 |
endif
| 221 |
breaksw
| 222 |
default:
| 223 |
echo "Illegal choice\!"
| 224 |
echo "Installation aborted."
| 225 |
exit 1
| 226 |
breaksw
| 227 |
endsw
| 228 |
# We don't seem to have any more cramped machines out there, so...
| 229 |
set mem="-DBIGMEM"
| 230 |
if ( $?mem ) then
| 231 |
set mach="$mach $mem"
| 232 |
else
| 233 |
echo -n "Does the target machine have more than 24 Mbytes of RAM? "
| 234 |
set ans="$<"
| 235 |
if ( "$ans" =~ [yY]* ) then
| 236 |
echo -n "More than 96 Mbytes? "
| 237 |
set ans="$<"
| 238 |
| 239 |
set mach="$mach -DBIGMEM"
| 240 |
set sizemod="huge models (100,000+ surfaces)"
| 241 |
else
| 242 |
set sizemod="very large models (30,000+ surfaces)"
| 243 |
endif
| 244 |
else
| 245 |
set sizemod="large models (10,000+ surfaces)"
| 246 |
endif
| 247 |
endif
| 248 |
# echo "Do you expect to be rendering $sizemod?"
| 249 |
# echo -n '(Answering "yes" may adversly affect rendering time and geometric accuracy) '
| 250 |
# set ans="$<"
| 251 |
# if ( "$ans" =~ [yY]* ) then
| 252 |
# set opt="$opt -DSMLFLT"
| 253 |
# endif
| 254 |
# echo -n "Do you have X10 support [n]? "
| 255 |
# if ( "$<" =~ [yY]* ) then
| 256 |
# set special="$special x10"
| 257 |
# endif
| 258 |
source installib
| 259 |
sed 's/[ ]*$//' > $rmake << _EOF_
| 260 |
#!/bin/sh
| 261 |
exec make "SPECIAL=$special" \
| 262 |
"OPT=$opt" \
| 263 |
"MACH=$mach" \
| 264 |
ARCH=$arch "COMPAT=$compat" \
| 265 |
INSTDIR=$idir \
| 266 |
LIBDIR=$ldir \
| 267 |
$extras "\$@" -f Rmakefile
| 268 |
_EOF_
| 269 |
chmod 755 $rmake
| 270 |
chmod 644 src/*/Rmakefile src/rt/devtable.c
| 271 |
gotrmake:
| 272 |
echo "Current rmake command is:"
| 273 |
cat $rmake
| 274 |
echo -n "Do you want to change it? "
| 275 |
set ans="$<"
| 276 |
| 277 |
cp $rmake /tmp/rmake$$
| 278 |
$EDITOR $rmake
| 279 |
if ( `cat $rmake /tmp/rmake$$ | grep OPT= | uniq | wc -l` == 2 ) set newrmake
| 280 |
rm -f /tmp/rmake$$
| 281 |
endif
| 282 |
if ( ! -d src/lib ) then
| 283 |
mkdir src/lib
| 284 |
endif
| 285 |
if ( $?newrmake ) then
| 286 |
echo 'New rmake command -- running "makeall clean"...'
| 287 |
csh -f $0 clean
| 288 |
endif
| 289 |
cd src
| 290 |
echo "Making programs..."
| 291 |
set errs=0
| 292 |
foreach i ( $srcdirs )
| 293 |
pushd $i
| 294 |
echo "In directory $i..."
| 295 |
$rmake -k $*
| 296 |
@ errs += $status
| 297 |
popd
| 298 |
end
| 299 |
if ( $errs ) then
| 300 |
echo "There were some errors."
| 301 |
else
| 302 |
echo "Done."
| 303 |
endif
| 304 |
cd ..
| 305 |
if (! -d /usr/tmp) then
| 306 |
ln -s /tmp /usr/tmp
| 307 |
if ($status) then
| 308 |
echo ""
| 309 |
echo "IMPORTANT: Execute 'sudo ln -s /tmp /usr/tmp'"
| 310 |
echo ""
| 311 |
endif
| 312 |
endif
| 313 |
else
| 314 |
cd src
| 315 |
| 316 |
pushd $i
| 317 |
| 318 |
make -f Rmakefile $*
| 319 |
popd
| 320 |
end
| 321 |
echo "Done."
| 322 |
cd ..
| 323 |
endif
| 324 |
foreach i ( $* )
| 325 |
if ( "$i" == clean ) then
| 326 |
echo "Removing library archives..."
| 327 |
rm -f src/lib/*.[ao]
| 328 |
endif
| 329 |
end
| 330 |
exit 0
