root/radiance/ray/makeall
Revision: 1.30
Committed: Fri Sep 11 20:38:46 2020 UTC (3 years, 8 months ago) by greg
Changes since 1.29: +19 -1 lines
chore(makeall): Added "makeall test" to run unit tests and report success
1 #!/bin/csh -f
2 # RCSid $Id: makeall,v 1.29 2018/05/30 14:14:55 greg Exp $
3 #
4 # Make all the Radiance programs
5 #
6 if ( $#argv < 1 ) then
7 echo "Usage: makeall install [clean] [make options]"
8 echo " or: makeall clean"
9 echo " or: makeall library"
10 echo " or: makeall test"
11 exit 1
12 endif
13 if ( "$1" == library ) then
14 source installib
15 cp -f src/*/*.{cal,tab,hex,dat} $ldir
16 echo ""
17 echo "Set the environment variable RAYPATH=.:$ldir"
18 echo 'For C-shell users, put the following into ~/.cshrc'
19 echo " setenv RAYPATH .:$ldir"
20 echo 'For Bourne shell users, put the following into $HOME/.profile'
21 echo " RAYPATH=.:$ldir"
22 echo " export RAYPATH"
23 echo ""
24 exit 0
25 endif
26 if ( "$1" == test ) then
27 cd test
28 set fails=()
29 foreach d (cal gen util px renders)
30 cd $d
31 make -k clean all && make clean
32 if ($status) set fails=($fails $d)
33 cd ..
34 end
35 if ($#fails) then
36 echo "Unit tests failed in $#fails directories"
37 echo "Run 'make' manually in test/ subfolders: $fails"
38 exit 1
39 endif
40 echo "All tests passed successfully."
41 exit 0
42 endif
43 set srcdirs=( common rt meta cv gen ot px hd util cal )
44 if ( "$1" == install ) then
45 cat << _EOF_
46
47 `cat src/rt/VERSION` INSTALLATION
48
49 This script rebuilds all of the Radiance programs and installs
50 them on your system. You should read the file README before running
51 this script. You can type ^C (followed by return) at any time to abort.
52
53 You must first answer the following questions.
54
55 _EOF_
56 if ( ! $?EDITOR ) then
57 echo -n "What is your preferred editor [vi]? "
58 set ans="$<"
59 if ( "$ans" != "" ) then
60 setenv EDITOR "$ans"
61 else
62 setenv EDITOR vi
63 endif
64 endif
65 again1:
66 echo -n "Where do you want the executables [/usr/local/bin]? "
67 set idir=$<
68 (echo $idir) >/dev/null
69 if ( $status ) then
70 goto again1
71 endif
72 set idir=$idir
73 if ( "$idir" == "" ) then
74 set idir=/usr/local/bin
75 else if ( "$idir" !~ /* ) then
76 echo "Directory must be relative to root, please reenter"
77 goto again1
78 endif
79 if ( ! -d $idir ) then
80 mkdir $idir
81 if ( $status ) then
82 echo "Cannot create directory, please reenter"
83 goto again1
84 endif
85 endif
86 set inpath=0
87 foreach i ( $path )
88 if ( "$i" == "$idir" ) then
89 set inpath=1
90 break
91 endif
92 end
93 set rmake=$idir/rmake
94 if ( "`ls -tL $rmake $0 |& head -1`" == $rmake ) then
95 goto gotrmake
96 endif
97 set newrmake
98 more License.txt
99 echo -n "Do you understand and accept the terms of this agreement [n]? "
100 set ans="$<"
101 if ( "$ans" !~ [yY]* ) exit
102 set special=
103 set arch=
104 set opt=
105 set mach=
106 set compat=
107 set extras=
108 set esuffix=
109 cat << _EOF_
110
111 Please select your system type from the following list:
112
113 1) Sun Solaris
114 2) Linux
115 3) MacOS X
116 4) FreeBSD
117 5) Cygwin
118 6) Other
119
120 _EOF_
121 echo -n "Choice? "
122 set arch="$<"
123 switch ("$arch")
124 case 1: # SPARC Station
125 set arch=sun
126 set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO"
127 set opt="-O"
128 set compat="strcmp.o timegm.o"
129 breaksw
130 case 2: # Linux
131 set mach="-Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO"
132 set opt="-O2"
133 set arch=IBMPC
134 set compat="strlcpy.o"
135 set extras=CC=gcc
136 breaksw
137 case 3: # MacOS X
138 set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib"
139 set opt="-O2"
140 set arch=Intel
141 set extras="CC=cc CONFIGURE_ARCH=i386"
142 set special="ogl"
143 breaksw
144 case 4: # FreeBSD
145 set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib"
146 set opt="-O"
147 set compat="erf.o"
148 set extras='CC=cc MLIB="-lcompat -lm"'
149 set arch=IBMPC
150 breaksw
151 case 5: # Cygwin
152 set mach="-Dfreebsd -L/usr/lib -L/usr/X11R6/lib -I/usr/include/X11 -I/usr/X11R6/include -DNOSTEREO"
153 set opt="-O2"
154 set arch=IBMPC
155 set compat="erf.o strlcpy.o"
156 set extras="CC=gcc"
157 set special="ogl"
158 set esuffix=".exe"
159 breaksw
160 case 6: # Other
161 set opt="-O"
162 set compat="erf.o strcmp.o strlcpy.o"
163 echo -n "Are you using the GNU C compiler [n]? "
164 if ( "$<" =~ [yY]* ) then
165 set extras="CC=gcc"
166 else
167 set compat="$compat timegm.o"
168 endif
169 set arch=other
170 breaksw
171 default:
172 echo "Illegal choice\!"
173 echo "Installation aborted."
174 exit 1
175 breaksw
176 endsw
177 source installib
178 sed 's/[ ]*$//' > $rmake << _EOF_
179 #!/bin/sh
180 exec make "SPECIAL=$special" \
181 "OPT=$opt" \
182 "MACH=$mach" \
183 ARCH=$arch "COMPAT=$compat" \
184 INSTDIR=$idir \
185 LIBDIR=$ldir \
186 ESUFFIX=$esuffix \
187 $extras "\$@" -f Rmakefile
188 _EOF_
189 chmod 755 $rmake
190 chmod 644 src/*/Rmakefile src/rt/devtable.c
191 gotrmake:
192 echo "Current rmake command is:"
193 cat $rmake
194 echo -n "Do you want to change it? "
195 set ans="$<"
196 if ( "$ans" =~ [yY]* ) then
197 cp $rmake /tmp/rmake$$
198 $EDITOR $rmake
199 if ( `cat $rmake /tmp/rmake$$ | grep OPT= | uniq | wc -l` == 2 ) set newrmake
200 rm -f /tmp/rmake$$
201 endif
202 if ( ! -d src/lib ) then
203 mkdir src/lib
204 endif
205 if ( $?newrmake ) then
206 echo 'New rmake command -- running "makeall clean"...'
207 csh -f $0 clean
208 endif
209 cd src
210 echo "Making programs..."
211 set errs=0
212 foreach i ( $srcdirs )
213 pushd $i
214 echo "In directory $i..."
215 $rmake -k $*
216 @ errs += $status
217 popd
218 end
219 if ( $errs ) then
220 echo "There were some errors."
221 else
222 echo "Done."
223 endif
224 cd ..
225 if (! $inpath ) then
226 echo ""
227 echo "Add $idir to the beginning of your execution path:"
228 echo 'For C-shell users, put the following into ~/.cshrc'
229 echo " set path=( $idir "'$path )'
230 echo 'For Bourne shell users, put the following into $HOME/.profile'
231 echo " PATH=$idir"':$PATH'
232 echo " export PATH"
233 endif
234 else
235 cd src
236 foreach i ( $srcdirs )
237 pushd $i
238 echo "In directory $i..."
239 make -f Rmakefile $*
240 popd
241 end
242 cd ..
243 foreach i ( $* )
244 if ( "$i" == clean ) then
245 echo "Removing library archives..."
246 rm -f src/lib/*.{a,o,la}
247 endif
248 end
249 echo "Done."
250 endif
251 exit 0
