1 |
#!/bin/csh -f |
2 |
# RCSid $Id: makeall,v 1.27 2012/04/25 22:21:06 greg Exp $ |
3 |
4 |
# Make all the Radiance programs |
5 |
6 |
if ( $#argv < 1 ) then |
7 |
echo "Usage: makeall install [clean] [make options]" |
8 |
echo " or: makeall clean" |
9 |
echo " or: makeall library" |
10 |
exit 1 |
11 |
endif |
12 |
if ( "$1" == library ) then |
13 |
source installib |
14 |
cp -f src/*/*.{cal,tab,hex,dat} $ldir |
15 |
echo "" |
16 |
echo "Set the environment variable RAYPATH=.:$ldir" |
17 |
echo 'For C-shell users, put the following into ~/.cshrc' |
18 |
echo " setenv RAYPATH .:$ldir" |
19 |
echo 'For Bourne shell users, put the following into $HOME/.profile' |
20 |
echo " RAYPATH=.:$ldir" |
21 |
echo " export RAYPATH" |
22 |
echo "" |
23 |
exit 0 |
24 |
endif |
25 |
set srcdirs=( common rt meta cv gen ot px hd util cal ) |
26 |
if ( "$1" == install ) then |
27 |
cat << _EOF_ |
28 |
29 |
`cat src/rt/VERSION` INSTALLATION |
30 |
31 |
This script rebuilds all of the Radiance programs and installs |
32 |
them on your system. You should read the file README before running |
33 |
this script. You can type ^C (followed by return) at any time to abort. |
34 |
35 |
You must first answer the following questions. |
36 |
37 |
_EOF_ |
38 |
if ( ! $?EDITOR ) then |
39 |
echo -n "What is your preferred editor [vi]? " |
40 |
set ans="$<" |
41 |
if ( "$ans" != "" ) then |
42 |
setenv EDITOR "$ans" |
43 |
else |
44 |
setenv EDITOR vi |
45 |
endif |
46 |
endif |
47 |
again1: |
48 |
echo -n "Where do you want the executables [/usr/local/bin]? " |
49 |
set idir=$< |
50 |
(echo $idir) >/dev/null |
51 |
if ( $status ) then |
52 |
goto again1 |
53 |
endif |
54 |
set idir=$idir |
55 |
if ( "$idir" == "" ) then |
56 |
set idir=/usr/local/bin |
57 |
else if ( "$idir" !~ /* ) then |
58 |
echo "Directory must be relative to root, please reenter" |
59 |
goto again1 |
60 |
endif |
61 |
if ( ! -d $idir ) then |
62 |
mkdir $idir |
63 |
64 |
echo "Cannot create directory, please reenter" |
65 |
goto again1 |
66 |
endif |
67 |
endif |
68 |
set inpath=0 |
69 |
foreach i ( $path ) |
70 |
if ( "$i" == "$idir" ) then |
71 |
set inpath=1 |
72 |
break |
73 |
endif |
74 |
end |
75 |
set rmake=$idir/rmake |
76 |
if ( "`ls -tL $rmake $0 |& head -1`" == $rmake ) then |
77 |
goto gotrmake |
78 |
endif |
79 |
set newrmake |
80 |
more License.txt |
81 |
echo -n "Do you understand and accept the terms of this agreement [n]? " |
82 |
set ans="$<" |
83 |
if ( "$ans" !~ [yY]* ) exit |
84 |
set special= |
85 |
set arch= |
86 |
set opt= |
87 |
set mach= |
88 |
set compat= |
89 |
set extras= |
90 |
set esuffix= |
91 |
cat << _EOF_ |
92 |
93 |
Please select your system type from the following list: |
94 |
95 |
1) Sun Solaris |
96 |
2) Linux |
97 |
3) MacOS X |
98 |
4) FreeBSD |
99 |
5) Cygwin |
100 |
6) Other |
101 |
102 |
_EOF_ |
103 |
echo -n "Choice? " |
104 |
set arch="$<" |
105 |
switch ("$arch") |
106 |
case 1: # SPARC Station |
107 |
set arch=sun |
108 |
set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO" |
109 |
set opt="-O" |
110 |
set compat="strcmp.o timegm.o" |
111 |
breaksw |
112 |
case 2: # Linux |
113 |
set mach="-Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO" |
114 |
set opt="-O2" |
115 |
set arch=IBMPC |
116 |
set compat="erf.o" |
117 |
set extras=CC=gcc |
118 |
breaksw |
119 |
case 3: # MacOS X |
120 |
set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib" |
121 |
set opt="-O2" |
122 |
set arch=Intel |
123 |
set extras="CC=cc CONFIGURE_ARCH=i386" |
124 |
set special="ogl" |
125 |
breaksw |
126 |
case 4: # FreeBSD |
127 |
128 |
set opt="-O" |
129 |
130 |
set extras='CC=cc MLIB="-lcompat -lm"' |
131 |
set arch=IBMPC |
132 |
breaksw |
133 |
case 5: # Cygwin |
134 |
set mach="-Dfreebsd -L/usr/lib -L/usr/X11R6/lib -I/usr/include/X11 -I/usr/X11R6/include -DNOSTEREO" |
135 |
set opt="-O2" |
136 |
set arch=IBMPC |
137 |
138 |
set extras="CC=gcc" |
139 |
set special="ogl" |
140 |
set esuffix=".exe" |
141 |
breaksw |
142 |
case 6: # Other |
143 |
set opt="-O" |
144 |
set compat="erf.o strcmp.o" |
145 |
echo -n "Are you using the GNU C compiler [n]? " |
146 |
if ( "$<" =~ [yY]* ) then |
147 |
148 |
else |
149 |
set compat="$compat timegm.o" |
150 |
endif |
151 |
set arch=other |
152 |
breaksw |
153 |
default: |
154 |
echo "Illegal choice\!" |
155 |
echo "Installation aborted." |
156 |
exit 1 |
157 |
breaksw |
158 |
endsw |
159 |
source installib |
160 |
sed 's/[ ]*$//' > $rmake << _EOF_ |
161 |
#!/bin/sh |
162 |
exec make "SPECIAL=$special" \ |
163 |
"OPT=$opt" \ |
164 |
"MACH=$mach" \ |
165 |
ARCH=$arch "COMPAT=$compat" \ |
166 |
INSTDIR=$idir \ |
167 |
LIBDIR=$ldir \ |
168 |
ESUFFIX=$esuffix \ |
169 |
$extras "\$@" -f Rmakefile |
170 |
_EOF_ |
171 |
chmod 755 $rmake |
172 |
chmod 644 src/*/Rmakefile src/rt/devtable.c |
173 |
gotrmake: |
174 |
echo "Current rmake command is:" |
175 |
cat $rmake |
176 |
echo -n "Do you want to change it? " |
177 |
set ans="$<" |
178 |
if ( "$ans" =~ [yY]* ) then |
179 |
cp $rmake /tmp/rmake$$ |
180 |
$EDITOR $rmake |
181 |
if ( `cat $rmake /tmp/rmake$$ | grep OPT= | uniq | wc -l` == 2 ) set newrmake |
182 |
rm -f /tmp/rmake$$ |
183 |
endif |
184 |
if ( ! -d src/lib ) then |
185 |
mkdir src/lib |
186 |
endif |
187 |
if ( $?newrmake ) then |
188 |
echo 'New rmake command -- running "makeall clean"...' |
189 |
csh -f $0 clean |
190 |
endif |
191 |
cd src |
192 |
echo "Making programs..." |
193 |
set errs=0 |
194 |
foreach i ( $srcdirs ) |
195 |
pushd $i |
196 |
echo "In directory $i..." |
197 |
$rmake -k $* |
198 |
@ errs += $status |
199 |
popd |
200 |
end |
201 |
if ( $errs ) then |
202 |
echo "There were some errors." |
203 |
else |
204 |
echo "Done." |
205 |
endif |
206 |
cd .. |
207 |
if (! $inpath ) then |
208 |
echo "" |
209 |
echo "Add $idir to the beginning of your execution path:" |
210 |
211 |
echo " set path=( $idir "'$path )' |
212 |
213 |
echo " PATH=$idir"':$PATH' |
214 |
echo " export PATH" |
215 |
endif |
216 |
else |
217 |
cd src |
218 |
219 |
pushd $i |
220 |
221 |
make -f Rmakefile $* |
222 |
popd |
223 |
end |
224 |
cd .. |
225 |
foreach i ( $* ) |
226 |
if ( "$i" == clean ) then |
227 |
echo "Removing library archives..." |
228 |
rm -f src/lib/*.{a,o,la} |
229 |
endif |
230 |
end |
231 |
echo "Done." |
232 |
endif |
233 |
exit 0 |
