1 |
#!/bin/csh -f |
2 |
# RCSid $Id$ |
3 |
4 |
#Added macosX 2001-04-11 by Jean Brange |
5 |
#Deleted obsolete systems 2001-04-18 by Greg Ward |
6 |
7 |
# Make all the Radiance programs |
8 |
9 |
if ( $#argv < 1 ) then |
10 |
echo "Usage: makeall install [clean] [make options]" |
11 |
echo " or: makeall clean" |
12 |
echo " or: makeall library" |
13 |
exit 1 |
14 |
endif |
15 |
if ( "$1" == library ) then |
16 |
source installib |
17 |
echo "" |
18 |
echo "Set the environment variable RAYPATH=.:$ldir" |
19 |
echo 'For C-shell users, put the following into ~/.cshrc' |
20 |
echo " setenv RAYPATH .:$ldir" |
21 |
echo 'For Bourne shell users, put the following into $HOME/profile' |
22 |
echo " RAYPATH=.:$ldir" |
23 |
echo " export RAYPATH" |
24 |
echo "" |
25 |
exit 0 |
26 |
endif |
27 |
set srcdirs=( common meta cv gen ot rt px hd util cal ) |
28 |
if ( "$1" == install ) then |
29 |
cat << _EOF_ |
30 |
31 |
`cat src/rt/VERSION` INSTALLATION |
32 |
33 |
This script rebuilds all of the Radiance programs and installs |
34 |
them on your system. You should read the file README before running |
35 |
this script. You can type ^C (followed by return) at any time to abort. |
36 |
37 |
You must first answer the following questions. |
38 |
39 |
_EOF_ |
40 |
if ( ! $?EDITOR ) then |
41 |
echo -n "What is your preferred editor [vi]? " |
42 |
set ans="$<" |
43 |
if ( "$ans" != "" ) then |
44 |
setenv EDITOR "$ans" |
45 |
else |
46 |
setenv EDITOR vi |
47 |
endif |
48 |
endif |
49 |
again1: |
50 |
echo -n "Where do you want the executables [/usr/local/bin]? " |
51 |
set idir=$< |
52 |
(echo $idir) >/dev/null |
53 |
if ( $status ) goto again1 |
54 |
set idir=$idir |
55 |
if ( "$idir" == "" ) then |
56 |
set idir=/usr/local/bin |
57 |
else if ( "$idir" !~ /* ) then |
58 |
echo "Directory must be relative to root, please reenter" |
59 |
goto again1 |
60 |
endif |
61 |
if ( ! -d $idir ) then |
62 |
mkdir $idir |
63 |
if ( $status ) then |
64 |
echo "Cannot create directory, please reenter" |
65 |
goto again1 |
66 |
endif |
67 |
endif |
68 |
if ( ! -d $idir/dev ) then |
69 |
mkdir $idir/dev |
70 |
71 |
echo "Cannot create subdirectory, please reenter" |
72 |
goto again1 |
73 |
endif |
74 |
endif |
75 |
set rmake=$idir/rmake |
76 |
if ( "`ls -tL $rmake $0 |& head -1`" == $rmake ) goto gotrmake |
77 |
set newrmake |
78 |
goto skiplicense |
79 |
cat << _EOF_ |
80 |
81 |
RADIANCE LICENSE AGREEMENT |
82 |
83 |
Radiance is a registered copyright of The Regents of the University of |
84 |
California ("The Regents"). The Regents grant to you a nonexclusive, |
85 |
nontransferable license ("License") to use Radiance source code without |
86 |
fee. You may not sell or distribute Radiance to others without the |
87 |
prior express written permission of The Regents. You may compile and |
88 |
use this software on any machines to which you have personal access, |
89 |
and may share its use with others who have access to the same machines. |
90 |
91 |
NEITHER THE UNITED STATES NOR THE UNITED STATES DEPARTMENT OF ENERGY, NOR ANY |
92 |
OF THEIR EMPLOYEES, MAKES ANY WARRANTY, EXPRESS OR IMPLIED, OR ASSUMES ANY |
93 |
LEGAL LIABILITY OR RESPONSIBILITY FOR THE ACCURACY, COMPLETENESS, OR USEFULNESS |
94 |
OF ANY INFORMATION, APPARATUS, PRODUCT, OR PROCESS DISCLOSED, OR REPRESENTS |
95 |
THAT ITS USE WOULD NOT INFRINGE PRIVATELY OWNED RIGHTS. By downloading, using |
96 |
or copying this software, you agree to abide by the intellectual property laws |
97 |
and all other applicable laws of the United States, and by the terms of this |
98 |
License Agreement. Ownership of the software shall remain solely in The |
99 |
Regents. The Regents shall have the right to terminate this License |
100 |
immediately by written notice upon your breach of, or noncompliance with, any |
101 |
of its terms. You shall be liable for any infringement or damages resulting |
102 |
from your failure to abide by the terms of this License Agreement. |
103 |
104 |
_EOF_ |
105 |
echo -n "Do you understand and accept the terms of this agreement [n]? " |
106 |
set ans="$<" |
107 |
if ( "$ans" !~ [yY]* ) exit |
108 |
echo -n "Are you a new Radiance user or with a new address [y]? " |
109 |
set ans="$<" |
110 |
if ( "$ans" !~ [nN]* ) then |
111 |
csh -f newuser |
112 |
else |
113 |
echo `cat src/rt/VERSION` compiled by `whoami` | mail [email protected] |
114 |
endif |
115 |
skiplicense: |
116 |
set special= |
117 |
set arch= |
118 |
set opt= |
119 |
set mach= |
120 |
set compat= |
121 |
set extras= |
122 |
cat << _EOF_ |
123 |
124 |
Please select your system type from the following list: |
125 |
126 |
1) Sun Solaris |
127 |
2) HP workstation |
128 |
3) Silicon Graphics |
129 |
4) AIX (RS/6000) |
130 |
5) BSDI BSD/386 |
131 |
6) Linux |
132 |
7) MacOS X |
133 |
8) FreeBSD |
134 |
9) Other |
135 |
136 |
_EOF_ |
137 |
echo -n "Choice? " |
138 |
set arch="$<" |
139 |
switch ("$arch") |
140 |
case 1: # SPARC Station |
141 |
set arch=sun |
142 |
if ( `uname -r` =~ 4.* ) then |
143 |
set mach="-fsingle -DBSD /usr/lib/libm.il -I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO" |
144 |
set opt="-O -pipe -DSPEED=12" |
145 |
set special="sun" |
146 |
set compat="bmalloc.o strcmp.o" |
147 |
else |
148 |
set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO" |
149 |
set opt="-O -DSPEED=80" |
150 |
set special="ogl" |
151 |
set compat="bmalloc.o strcmp.o getpagesize.o" |
152 |
endif |
153 |
breaksw |
154 |
case 2: # HP workstation |
155 |
set mach="" |
156 |
set opt="-O -DSPEED=80 -Aa -D_HPUX_SOURCE" |
157 |
set compat="malloc.o getpagesize.o strcmp.o" |
158 |
set arch=hpux |
159 |
breaksw |
160 |
case 3: # Silicon Graphics |
161 |
set arch=sgi |
162 |
switch (`uname -r`) |
163 |
case 3.*: |
164 |
set mach="-noprototypes" |
165 |
166 |
set special="sgi" |
167 |
set compat="malloc.o strcmp.o" |
168 |
breaksw |
169 |
case 4.*: |
170 |
set mach="" |
171 |
set opt="-O2 -DSPEED=100" |
172 |
173 |
set extras='"MLIB=-lfastm -lm"' |
174 |
breaksw |
175 |
default: # 5.x or later |
176 |
ln -s `which wish` $idir/wish4.0 |
177 |
set path=($idir $path) |
178 |
set mach="-w" |
179 |
set opt="-O2 -DSPEED=200" |
180 |
set special="ogl" |
181 |
182 |
breaksw |
183 |
endsw |
184 |
breaksw |
185 |
case 4: # AIX |
186 |
set mach="-Dvoid=char -D_NO_PROTO -DINCL_SEL_H" |
187 |
set opt="-O" |
188 |
set compat="bmalloc.o erf.o" |
189 |
breaksw |
190 |
case 5: # BSDI BSD/386 |
191 |
set mach="-DBSD -L/usr/X11/lib -I/usr/X11/include" |
192 |
set opt="-O -DSPEED=100" |
193 |
set arch=IBMPC |
194 |
set compat="malloc.o erf.o strcmp.o" |
195 |
breaksw |
196 |
case 6: # Linux |
197 |
set mach="-Dlinux -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO" |
198 |
199 |
set arch=IBMPC |
200 |
set compat="bmalloc.o erf.o getpagesize.o" |
201 |
set extras=CC=gcc |
202 |
breaksw |
203 |
case 7: # MacOS X |
204 |
set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib" |
205 |
206 |
set arch=PowerPC |
207 |
set compat="bmalloc.o" |
208 |
set extras="CC=cc CONFIGURE_ARCH=powerpc" |
209 |
set special="ogl" |
210 |
breaksw |
211 |
case 8: # FreeBSD |
212 |
213 |
set opt="-O -DSPEED=200" |
214 |
215 |
set extras="CC=cc" |
216 |
set arch=IBMPC |
217 |
breaksw |
218 |
case 9: # Other |
219 |
set opt="-O" |
220 |
set compat="bmalloc.o erf.o strcmp.o" |
221 |
echo -n "Are you using the GNU C compiler [n]? " |
222 |
if ( "$<" =~ [yY]* ) then |
223 |
set extras="CC=gcc" |
224 |
endif |
225 |
breaksw |
226 |
default: |
227 |
echo "Illegal choice\!" |
228 |
echo "Installation aborted." |
229 |
exit 1 |
230 |
breaksw |
231 |
endsw |
232 |
# We don't seem to have any more cramped machines out there, so... |
233 |
set mem="-DBIGMEM" |
234 |
if ( $?mem ) then |
235 |
set mach="$mach $mem" |
236 |
else |
237 |
echo -n "Does the target machine have more than 24 Mbytes of RAM? " |
238 |
set ans="$<" |
239 |
if ( "$ans" =~ [yY]* ) then |
240 |
echo -n "More than 96 Mbytes? " |
241 |
set ans="$<" |
242 |
243 |
set mach="$mach -DBIGMEM" |
244 |
set sizemod="huge models (100,000+ surfaces)" |
245 |
else |
246 |
set sizemod="very large models (30,000+ surfaces)" |
247 |
endif |
248 |
else |
249 |
set sizemod="large models (10,000+ surfaces)" |
250 |
endif |
251 |
endif |
252 |
# echo "Do you expect to be rendering $sizemod?" |
253 |
# echo -n '(Answering "yes" may adversly affect rendering time and geometric accuracy) ' |
254 |
# set ans="$<" |
255 |
# if ( "$ans" =~ [yY]* ) then |
256 |
# set opt="$opt -DSMLFLT" |
257 |
# endif |
258 |
# echo -n "Do you have X10 support [n]? " |
259 |
# if ( "$<" =~ [yY]* ) then |
260 |
# set special="$special x10" |
261 |
# endif |
262 |
source installib |
263 |
sed 's/[ ]*$//' > $rmake << _EOF_ |
264 |
#!/bin/sh |
265 |
exec make "SPECIAL=$special" \ |
266 |
"OPT=$opt" \ |
267 |
"MACH=$mach" \ |
268 |
ARCH=$arch "COMPAT=$compat" \ |
269 |
INSTDIR=$idir \ |
270 |
LIBDIR=$ldir \ |
271 |
$extras "\$@" -f Rmakefile |
272 |
_EOF_ |
273 |
chmod 755 $rmake |
274 |
chmod 644 src/*/Rmakefile src/rt/devtable.c |
275 |
gotrmake: |
276 |
echo "Current rmake command is:" |
277 |
cat $rmake |
278 |
echo -n "Do you want to change it? " |
279 |
set ans="$<" |
280 |
281 |
cp $rmake /tmp/rmake$$ |
282 |
$EDITOR $rmake |
283 |
if ( `cat $rmake /tmp/rmake$$ | grep OPT= | uniq | wc -l` == 2 ) set newrmake |
284 |
rm -f /tmp/rmake$$ |
285 |
endif |
286 |
if ( ! -d src/lib ) then |
287 |
mkdir src/lib |
288 |
endif |
289 |
if ( $?newrmake ) then |
290 |
echo 'New rmake command -- running "makeall clean"...' |
291 |
csh -f $0 clean |
292 |
endif |
293 |
cd src |
294 |
echo "Making programs..." |
295 |
set errs=0 |
296 |
foreach i ( $srcdirs ) |
297 |
pushd $i |
298 |
echo "In directory $i..." |
299 |
$rmake -k $* |
300 |
@ errs += $status |
301 |
popd |
302 |
end |
303 |
if ( $errs ) then |
304 |
echo "There were some errors." |
305 |
else |
306 |
echo "Done." |
307 |
endif |
308 |
cd .. |
309 |
if (! -d /usr/tmp) then |
310 |
ln -s /tmp /usr/tmp |
311 |
if ($status) then |
312 |
echo "" |
313 |
echo "IMPORTANT: Execute 'sudo ln -s /tmp /usr/tmp'" |
314 |
echo "" |
315 |
endif |
316 |
endif |
317 |
else |
318 |
cd src |
319 |
320 |
pushd $i |
321 |
322 |
make -f Rmakefile $* |
323 |
popd |
324 |
end |
325 |
echo "Done." |
326 |
cd .. |
327 |
endif |
328 |
foreach i ( $* ) |
329 |
if ( "$i" == clean ) then |
330 |
echo "Removing library archives..." |
331 |
rm -f src/lib/*.a |
332 |
endif |
333 |
end |
334 |
exit 0 |
