1 |
#!/bin/csh -f |
2 |
# RCSid $Id: makeall,v 1.14 2005/02/02 00:05:20 schorsch Exp $ |
3 |
4 |
# Make all the Radiance programs |
5 |
6 |
if ( $#argv < 1 ) then |
7 |
echo "Usage: makeall install [clean] [make options]" |
8 |
echo " or: makeall clean" |
9 |
echo " or: makeall library" |
10 |
exit 1 |
11 |
endif |
12 |
if ( "$1" == library ) then |
13 |
source installib |
14 |
cp -f src/*/*.{cal,tab,hex} $ldir |
15 |
echo "" |
16 |
echo "Set the environment variable RAYPATH=.:$ldir" |
17 |
echo 'For C-shell users, put the following into ~/.cshrc' |
18 |
echo " setenv RAYPATH .:$ldir" |
19 |
echo 'For Bourne shell users, put the following into $HOME/profile' |
20 |
echo " RAYPATH=.:$ldir" |
21 |
echo " export RAYPATH" |
22 |
echo "" |
23 |
exit 0 |
24 |
endif |
25 |
set srcdirs=( common meta cv gen ot rt px hd util cal ) |
26 |
if ( "$1" == install ) then |
27 |
cat << _EOF_ |
28 |
29 |
`cat src/rt/VERSION` INSTALLATION |
30 |
31 |
This script rebuilds all of the Radiance programs and installs |
32 |
them on your system. You should read the file README before running |
33 |
this script. You can type ^C (followed by return) at any time to abort. |
34 |
35 |
You must first answer the following questions. |
36 |
37 |
_EOF_ |
38 |
if ( ! $?EDITOR ) then |
39 |
echo -n "What is your preferred editor [vi]? " |
40 |
set ans="$<" |
41 |
if ( "$ans" != "" ) then |
42 |
setenv EDITOR "$ans" |
43 |
else |
44 |
setenv EDITOR vi |
45 |
endif |
46 |
endif |
47 |
again1: |
48 |
echo -n "Where do you want the executables [/usr/local/bin]? " |
49 |
set idir=$< |
50 |
(echo $idir) >/dev/null |
51 |
if ( $status ) then |
52 |
goto again1 |
53 |
endif |
54 |
set idir=$idir |
55 |
if ( "$idir" == "" ) then |
56 |
set idir=/usr/local/bin |
57 |
else if ( "$idir" !~ /* ) then |
58 |
echo "Directory must be relative to root, please reenter" |
59 |
goto again1 |
60 |
endif |
61 |
if ( ! -d $idir ) then |
62 |
mkdir $idir |
63 |
64 |
echo "Cannot create directory, please reenter" |
65 |
goto again1 |
66 |
endif |
67 |
endif |
68 |
if ( ! -d $idir/dev ) then |
69 |
mkdir $idir/dev |
70 |
71 |
echo "Cannot create subdirectory, please reenter" |
72 |
goto again1 |
73 |
endif |
74 |
endif |
75 |
set inpath=0 |
76 |
foreach i ( $path ) |
77 |
if ( "$i" == "$idir" ) then |
78 |
set inpath=1 |
79 |
break |
80 |
endif |
81 |
end |
82 |
set rmake=$idir/rmake |
83 |
if ( "`ls -tL $rmake $0 |& head -1`" == $rmake ) then |
84 |
goto gotrmake |
85 |
endif |
86 |
set newrmake |
87 |
more src/common/copyright.h |
88 |
echo -n "Do you understand and accept the terms of this agreement [n]? " |
89 |
set ans="$<" |
90 |
if ( "$ans" !~ [yY]* ) exit |
91 |
set special= |
92 |
set arch= |
93 |
set opt= |
94 |
set mach= |
95 |
set compat= |
96 |
set extras= |
97 |
set esuffix= |
98 |
cat << _EOF_ |
99 |
100 |
Please select your system type from the following list: |
101 |
102 |
1) Sun Solaris |
103 |
2) HP workstation |
104 |
3) Silicon Graphics |
105 |
4) AIX (RS/6000) |
106 |
5) BSDI BSD/386 |
107 |
6) Linux |
108 |
7) MacOS X |
109 |
8) FreeBSD |
110 |
9) Cygwin |
111 |
10) Other |
112 |
113 |
_EOF_ |
114 |
echo -n "Choice? " |
115 |
set arch="$<" |
116 |
switch ("$arch") |
117 |
case 1: # SPARC Station |
118 |
set arch=sun |
119 |
set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO" |
120 |
set opt="-O -DSPEED=80" |
121 |
set compat="strcmp.o" |
122 |
breaksw |
123 |
case 2: # HP workstation |
124 |
set mach="" |
125 |
set opt="-O -DSPEED=80 -Aa -D_HPUX_SOURCE" |
126 |
127 |
set arch=hpux |
128 |
breaksw |
129 |
case 3: # Silicon Graphics |
130 |
set arch=sgi |
131 |
switch (`uname -r`) |
132 |
case 3.*: |
133 |
set mach="-noprototypes" |
134 |
135 |
set special="sgi" |
136 |
137 |
breaksw |
138 |
case 4.*: |
139 |
set mach="" |
140 |
set opt="-O2 -DSPEED=100" |
141 |
142 |
set extras='"MLIB=-lfastm -lm"' |
143 |
breaksw |
144 |
default: # 5.x or later |
145 |
ln -s `which wish` $idir/wish4.0 |
146 |
set path=($idir $path) |
147 |
set mach="-w" |
148 |
set opt="-O2 -DSPEED=200" |
149 |
set special="ogl" |
150 |
151 |
breaksw |
152 |
endsw |
153 |
breaksw |
154 |
case 4: # AIX |
155 |
set opt="-O" |
156 |
set compat="erf.o strcmp.o" |
157 |
set arch=PowerPC |
158 |
breaksw |
159 |
case 5: # BSDI BSD/386 |
160 |
set mach="-DBSD -L/usr/X11/lib -I/usr/X11/include" |
161 |
set opt="-O -DSPEED=100" |
162 |
set arch=IBMPC |
163 |
164 |
breaksw |
165 |
case 6: # Linux |
166 |
set mach="-Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO" |
167 |
168 |
set arch=IBMPC |
169 |
set compat="erf.o" |
170 |
set extras=CC=gcc |
171 |
breaksw |
172 |
case 7: # MacOS X |
173 |
set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib" |
174 |
175 |
set arch=PowerPC |
176 |
set extras="CC=cc CONFIGURE_ARCH=powerpc" |
177 |
set special="ogl" |
178 |
breaksw |
179 |
case 8: # FreeBSD |
180 |
181 |
set opt="-O -DSPEED=200" |
182 |
183 |
set extras="CC=cc" |
184 |
set arch=IBMPC |
185 |
breaksw |
186 |
case 9: # Cygwin |
187 |
set mach="-Dfreebsd -L/usr/lib -L/usr/X11R6/lib -I/usr/include/X11 -I/usr/X11R6/include -DNOSTEREO" |
188 |
189 |
set arch=IBMPC |
190 |
191 |
set extras="CC=gcc" |
192 |
set special="ogl" |
193 |
set esuffix=".exe" |
194 |
breaksw |
195 |
case 10: # Other |
196 |
set opt="-O" |
197 |
198 |
echo -n "Are you using the GNU C compiler [n]? " |
199 |
if ( "$<" =~ [yY]* ) then |
200 |
201 |
endif |
202 |
set arch=other |
203 |
breaksw |
204 |
default: |
205 |
echo "Illegal choice\!" |
206 |
echo "Installation aborted." |
207 |
exit 1 |
208 |
breaksw |
209 |
endsw |
210 |
source installib |
211 |
sed 's/[ ]*$//' > $rmake << _EOF_ |
212 |
#!/bin/sh |
213 |
exec make "SPECIAL=$special" \ |
214 |
"OPT=$opt" \ |
215 |
"MACH=$mach" \ |
216 |
ARCH=$arch "COMPAT=$compat" \ |
217 |
INSTDIR=$idir \ |
218 |
LIBDIR=$ldir \ |
219 |
ESUFFIX=$esuffix \ |
220 |
$extras "\$@" -f Rmakefile |
221 |
_EOF_ |
222 |
chmod 755 $rmake |
223 |
chmod 644 src/*/Rmakefile src/rt/devtable.c |
224 |
gotrmake: |
225 |
echo "Current rmake command is:" |
226 |
cat $rmake |
227 |
echo -n "Do you want to change it? " |
228 |
set ans="$<" |
229 |
if ( "$ans" =~ [yY]* ) then |
230 |
cp $rmake /tmp/rmake$$ |
231 |
$EDITOR $rmake |
232 |
if ( `cat $rmake /tmp/rmake$$ | grep OPT= | uniq | wc -l` == 2 ) set newrmake |
233 |
rm -f /tmp/rmake$$ |
234 |
endif |
235 |
if ( ! -d src/lib ) then |
236 |
mkdir src/lib |
237 |
endif |
238 |
if ( $?newrmake ) then |
239 |
echo 'New rmake command -- running "makeall clean"...' |
240 |
csh -f $0 clean |
241 |
endif |
242 |
cd src |
243 |
echo "Making programs..." |
244 |
set errs=0 |
245 |
foreach i ( $srcdirs ) |
246 |
pushd $i |
247 |
echo "In directory $i..." |
248 |
$rmake -k $* |
249 |
@ errs += $status |
250 |
popd |
251 |
end |
252 |
if ( $errs ) then |
253 |
echo "There were some errors." |
254 |
else |
255 |
echo "Done." |
256 |
endif |
257 |
cd .. |
258 |
if (! $inpath ) then |
259 |
echo "" |
260 |
echo "Add $idir to the beginning of your execution path:" |
261 |
262 |
echo " set path=( $idir "'$path )' |
263 |
264 |
echo " PATH=$idir"':$PATH' |
265 |
echo " export PATH" |
266 |
endif |
267 |
else |
268 |
cd src |
269 |
270 |
pushd $i |
271 |
272 |
make -f Rmakefile $* |
273 |
popd |
274 |
end |
275 |
cd .. |
276 |
foreach i ( $* ) |
277 |
if ( "$i" == clean ) then |
278 |
echo "Removing library archives..." |
279 |
rm -f src/lib/*.[ao] |
280 |
endif |
281 |
end |
282 |
echo "Done." |
283 |
endif |
284 |
exit 0 |
