root/Development/ray/makeall
Revision: 1.13
Committed: Tue Feb 1 16:05:38 2005 UTC (20 years, 10 months ago) by greg
Removed mention of retired getpagesize.c compatibility module
1 #!/bin/csh -f
2 # RCSid $Id: makeall,v 1.12 2004/10/30 04:59:40 greg Exp $
3 #
4 # Make all the Radiance programs
5 #
6 if ( $#argv < 1 ) then
7 echo "Usage: makeall install [clean] [make options]"
8 echo " or: makeall clean"
9 echo " or: makeall library"
10 exit 1
11 endif
12 if ( "$1" == library ) then
13 source installib
14 cp -f src/*/*.{cal,tab,hex} $ldir
15 echo ""
16 echo "Set the environment variable RAYPATH=.:$ldir"
17 echo 'For C-shell users, put the following into ~/.cshrc'
18 echo " setenv RAYPATH .:$ldir"
19 echo 'For Bourne shell users, put the following into $HOME/profile'
20 echo " RAYPATH=.:$ldir"
21 echo " export RAYPATH"
22 echo ""
23 exit 0
24 endif
25 set srcdirs=( common meta cv gen ot rt px hd util cal )
26 if ( "$1" == install ) then
27 cat << _EOF_
28
29 `cat src/rt/VERSION` INSTALLATION
30
31 This script rebuilds all of the Radiance programs and installs
32 them on your system. You should read the file README before running
33 this script. You can type ^C (followed by return) at any time to abort.
34
35 You must first answer the following questions.
36
37 _EOF_
38 if ( ! $?EDITOR ) then
39 echo -n "What is your preferred editor [vi]? "
40 set ans="$<"
41 if ( "$ans" != "" ) then
42 setenv EDITOR "$ans"
43 else
44 setenv EDITOR vi
45 endif
46 endif
47 again1:
48 echo -n "Where do you want the executables [/usr/local/bin]? "
49 set idir=$<
50 (echo $idir) >/dev/null
51 if ( $status ) then
52 goto again1
53 endif
54 set idir=$idir
55 if ( "$idir" == "" ) then
56 set idir=/usr/local/bin
57 else if ( "$idir" !~ /* ) then
58 echo "Directory must be relative to root, please reenter"
59 goto again1
60 endif
61 if ( ! -d $idir ) then
62 mkdir $idir
63 if ( $status ) then
64 echo "Cannot create directory, please reenter"
65 goto again1
66 endif
67 endif
68 if ( ! -d $idir/dev ) then
69 mkdir $idir/dev
70 if ( $status ) then
71 echo "Cannot create subdirectory, please reenter"
72 goto again1
73 endif
74 endif
75 set inpath=0
76 foreach i ( $path )
77 if ( "$i" == "$idir" ) then
78 set inpath=1
79 break
80 endif
81 end
82 set rmake=$idir/rmake
83 if ( "`ls -tL $rmake $0 |& head -1`" == $rmake ) then
84 goto gotrmake
85 endif
86 set newrmake
87 more src/common/copyright.h
88 echo -n "Do you understand and accept the terms of this agreement [n]? "
89 set ans="$<"
90 if ( "$ans" !~ [yY]* ) exit
91 set special=
92 set arch=
93 set opt=
94 set mach=
95 set compat=
96 set extras=
97 set esuffix=
98 cat << _EOF_
99
100 Please select your system type from the following list:
101
102 1) Sun Solaris
103 2) HP workstation
104 3) Silicon Graphics
105 4) AIX (RS/6000)
106 5) BSDI BSD/386
107 6) Linux
108 7) MacOS X
109 8) FreeBSD
110 9) Cygwin
111 10) Other
112
113 _EOF_
114 echo -n "Choice? "
115 set arch="$<"
116 switch ("$arch")
117 case 1: # SPARC Station
118 set arch=sun
119 set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO"
120 set opt="-O -DSPEED=80"
121 set compat="bmalloc.o strcmp.o"
122 breaksw
123 case 2: # HP workstation
124 set mach=""
125 set opt="-O -DSPEED=80 -Aa -D_HPUX_SOURCE"
126 set compat="bmalloc.o strcmp.o"
127 set arch=hpux
128 breaksw
129 case 3: # Silicon Graphics
130 set arch=sgi
131 switch (`uname -r`)
132 case 3.*:
133 set mach="-noprototypes"
134 set opt="-O -DSPEED=80"
135 set special="sgi"
136 set compat="malloc.o strcmp.o"
137 breaksw
138 case 4.*:
139 set mach=""
140 set opt="-O2 -DSPEED=100"
141 set compat="malloc.o strcmp.o"
142 set extras='"MLIB=-lfastm -lm"'
143 breaksw
144 default: # 5.x or later
145 ln -s `which wish` $idir/wish4.0
146 set path=($idir $path)
147 set mach="-w"
148 set opt="-O2 -DSPEED=200"
149 set special="ogl"
150 set compat="bmalloc.o strcmp.o"
151 breaksw
152 endsw
153 breaksw
154 case 4: # AIX
155 set opt="-O"
156 set compat="bmalloc.o erf.o strcmp.o"
157 set arch=PowerPC
158 breaksw
159 case 5: # BSDI BSD/386
160 set mach="-DBSD -L/usr/X11/lib -I/usr/X11/include"
161 set opt="-O -DSPEED=100"
162 set arch=IBMPC
163 set compat="malloc.o erf.o strcmp.o"
164 breaksw
165 case 6: # Linux
166 set mach="-Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO"
167 set opt="-O2 -DSPEED=200"
168 set arch=IBMPC
169 set compat="bmalloc.o erf.o"
170 set extras=CC=gcc
171 breaksw
172 case 7: # MacOS X
173 set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib"
174 set opt="-O2 -DSPEED=200"
175 set arch=PowerPC
176 set compat="bmalloc.o"
177 set extras="CC=cc CONFIGURE_ARCH=powerpc"
178 set special="ogl"
179 breaksw
180 case 8: # FreeBSD
181 set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib"
182 set opt="-O -DSPEED=200"
183 set compat="bmalloc.o erf.o"
184 set extras="CC=cc"
185 set arch=IBMPC
186 breaksw
187 case 9: # Cygwin
188 set mach="-Dfreebsd -L/usr/lib -L/usr/X11R6/lib -I/usr/include/X11 -I/usr/X11R6/include -DNOSTEREO"
189 set opt="-O2 -DSPEED=200"
190 set arch=IBMPC
191 set compat="bmalloc.o erf.o"
192 set extras="CC=gcc"
193 set special="ogl"
194 set esuffix=".exe"
195 breaksw
196 case 10: # Other
197 set opt="-O"
198 set compat="bmalloc.o erf.o strcmp.o"
199 echo -n "Are you using the GNU C compiler [n]? "
200 if ( "$<" =~ [yY]* ) then
201 set extras="CC=gcc"
202 endif
203 set arch=other
204 breaksw
205 default:
206 echo "Illegal choice\!"
207 echo "Installation aborted."
208 exit 1
209 breaksw
210 endsw
211 source installib
212 sed 's/[ ]*$//' > $rmake << _EOF_
213 #!/bin/sh
214 exec make "SPECIAL=$special" \
215 "OPT=$opt" \
216 "MACH=$mach" \
217 ARCH=$arch "COMPAT=$compat" \
218 INSTDIR=$idir \
219 LIBDIR=$ldir \
220 ESUFFIX=$esuffix \
221 $extras "\$@" -f Rmakefile
222 _EOF_
223 chmod 755 $rmake
224 chmod 644 src/*/Rmakefile src/rt/devtable.c
225 gotrmake:
226 echo "Current rmake command is:"
227 cat $rmake
228 echo -n "Do you want to change it? "
229 set ans="$<"
230 if ( "$ans" =~ [yY]* ) then
231 cp $rmake /tmp/rmake$$
232 $EDITOR $rmake
233 if ( `cat $rmake /tmp/rmake$$ | grep OPT= | uniq | wc -l` == 2 ) set newrmake
234 rm -f /tmp/rmake$$
235 endif
236 if ( ! -d src/lib ) then
237 mkdir src/lib
238 endif
239 if ( $?newrmake ) then
240 echo 'New rmake command -- running "makeall clean"...'
241 csh -f $0 clean
242 endif
243 cd src
244 echo "Making programs..."
245 set errs=0
246 foreach i ( $srcdirs )
247 pushd $i
248 echo "In directory $i..."
249 $rmake -k $*
250 @ errs += $status
251 popd
252 end
253 if ( $errs ) then
254 echo "There were some errors."
255 else
256 echo "Done."
257 endif
258 cd ..
259 if (! $inpath ) then
260 echo ""
261 echo "Add $idir to the beginning of your execution path:"
262 echo 'For C-shell users, put the following into ~/.cshrc'
263 echo " set path=( $idir "'$path )'
264 echo 'For Bourne shell users, put the following into $HOME/profile'
265 echo " PATH=$idir"':$PATH'
266 echo " export PATH"
267 endif
268 else
269 cd src
270 foreach i ( $srcdirs )
271 pushd $i
272 echo "In directory $i..."
273 make -f Rmakefile $*
274 popd
275 end
276 cd ..
277 foreach i ( $* )
278 if ( "$i" == clean ) then
279 echo "Removing library archives..."
280 rm -f src/lib/*.[ao]
281 endif
282 end
283 echo "Done."
284 endif
285 exit 0
