root/radiance/ray/makeall
Revision: 1.10
Committed: Tue Nov 25 18:23:11 2003 UTC (21 years, 5 months ago) by greg
Changes since 1.9: +19 -4 lines
Added comment about setting path variable to end of install script
1 #!/bin/csh -f
2 # RCSid $Id: makeall,v 1.9 2003/08/30 08:22:47 schorsch Exp $
3 #
4 # Make all the Radiance programs
5 #
6 if ( $#argv < 1 ) then
7 echo "Usage: makeall install [clean] [make options]"
8 echo " or: makeall clean"
9 echo " or: makeall library"
10 exit 1
11 endif
12 if ( "$1" == library ) then
13 source installib
14 cp -f src/*/*.{cal,tab,hex} $ldir
15 echo ""
16 echo "Set the environment variable RAYPATH=.:$ldir"
17 echo 'For C-shell users, put the following into ~/.cshrc'
18 echo " setenv RAYPATH .:$ldir"
19 echo 'For Bourne shell users, put the following into $HOME/profile'
20 echo " RAYPATH=.:$ldir"
21 echo " export RAYPATH"
22 echo ""
23 exit 0
24 endif
25 set srcdirs=( common meta cv gen ot rt px hd util cal )
26 if ( "$1" == install ) then
27 cat << _EOF_
28
29 `cat src/rt/VERSION` INSTALLATION
30
31 This script rebuilds all of the Radiance programs and installs
32 them on your system. You should read the file README before running
33 this script. You can type ^C (followed by return) at any time to abort.
34
35 You must first answer the following questions.
36
37 _EOF_
38 if ( ! $?EDITOR ) then
39 echo -n "What is your preferred editor [vi]? "
40 set ans="$<"
41 if ( "$ans" != "" ) then
42 setenv EDITOR "$ans"
43 else
44 setenv EDITOR vi
45 endif
46 endif
47 again1:
48 echo -n "Where do you want the executables [/usr/local/bin]? "
49 set idir=$<
50 (echo $idir) >/dev/null
51 if ( $status ) then
52 goto again1
53 endif
54 set idir=$idir
55 if ( "$idir" == "" ) then
56 set idir=/usr/local/bin
57 else if ( "$idir" !~ /* ) then
58 echo "Directory must be relative to root, please reenter"
59 goto again1
60 endif
61 if ( ! -d $idir ) then
62 mkdir $idir
63 if ( $status ) then
64 echo "Cannot create directory, please reenter"
65 goto again1
66 endif
67 endif
68 if ( ! -d $idir/dev ) then
69 mkdir $idir/dev
70 if ( $status ) then
71 echo "Cannot create subdirectory, please reenter"
72 goto again1
73 endif
74 endif
75 set inpath=0
76 foreach i ( $path )
77 if ( "$i" == "$idir" ) then
78 set inpath=1
79 break
80 endif
81 end
82 set rmake=$idir/rmake
83 if ( "`ls -tL $rmake $0 |& head -1`" == $rmake ) then
84 goto gotrmake
85 endif
86 set newrmake
87 goto skiplicense
88 cat << _EOF_
89
90 RADIANCE LICENSE AGREEMENT
91
92 Radiance is a registered copyright of The Regents of the University of
93 California ("The Regents"). The Regents grant to you a nonexclusive,
94 nontransferable license ("License") to use Radiance source code without
95 fee. You may not sell or distribute Radiance to others without the
96 prior express written permission of The Regents. You may compile and
97 use this software on any machines to which you have personal access,
98 and may share its use with others who have access to the same machines.
99
100 NEITHER THE UNITED STATES NOR THE UNITED STATES DEPARTMENT OF ENERGY, NOR ANY
101 OF THEIR EMPLOYEES, MAKES ANY WARRANTY, EXPRESS OR IMPLIED, OR ASSUMES ANY
102 LEGAL LIABILITY OR RESPONSIBILITY FOR THE ACCURACY, COMPLETENESS, OR USEFULNESS
103 OF ANY INFORMATION, APPARATUS, PRODUCT, OR PROCESS DISCLOSED, OR REPRESENTS
104 THAT ITS USE WOULD NOT INFRINGE PRIVATELY OWNED RIGHTS. By downloading, using
105 or copying this software, you agree to abide by the intellectual property laws
106 and all other applicable laws of the United States, and by the terms of this
107 License Agreement. Ownership of the software shall remain solely in The
108 Regents. The Regents shall have the right to terminate this License
109 immediately by written notice upon your breach of, or noncompliance with, any
110 of its terms. You shall be liable for any infringement or damages resulting
111 from your failure to abide by the terms of this License Agreement.
112
113 _EOF_
114 echo -n "Do you understand and accept the terms of this agreement [n]? "
115 set ans="$<"
116 if ( "$ans" !~ [yY]* ) exit
117 echo -n "Are you a new Radiance user or with a new address [y]? "
118 set ans="$<"
119 if ( "$ans" !~ [nN]* ) then
120 csh -f newuser
121 else
122 echo `cat src/rt/VERSION` compiled by `whoami` | mail [email protected]
123 endif
124 skiplicense:
125 set special=
126 set arch=
127 set opt=
128 set mach=
129 set compat=
130 set extras=
131 set esuffix=
132 cat << _EOF_
133
134 Please select your system type from the following list:
135
136 1) Sun Solaris
137 2) HP workstation
138 3) Silicon Graphics
139 4) AIX (RS/6000)
140 5) BSDI BSD/386
141 6) Linux
142 7) MacOS X
143 8) FreeBSD
144 9) Cygwin
145 10) Other
146
147 _EOF_
148 echo -n "Choice? "
149 set arch="$<"
150 switch ("$arch")
151 case 1: # SPARC Station
152 set arch=sun
153 set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO"
154 set opt="-O -DSPEED=80"
155 set compat="bmalloc.o strcmp.o getpagesize.o"
156 breaksw
157 case 2: # HP workstation
158 set mach=""
159 set opt="-O -DSPEED=80 -Aa -D_HPUX_SOURCE"
160 set compat="bmalloc.o getpagesize.o strcmp.o"
161 set arch=hpux
162 breaksw
163 case 3: # Silicon Graphics
164 set arch=sgi
165 switch (`uname -r`)
166 case 3.*:
167 set mach="-noprototypes"
168 set opt="-O -DSPEED=80"
169 set special="sgi"
170 set compat="malloc.o strcmp.o"
171 breaksw
172 case 4.*:
173 set mach=""
174 set opt="-O2 -DSPEED=100"
175 set compat="malloc.o strcmp.o"
176 set extras='"MLIB=-lfastm -lm"'
177 breaksw
178 default: # 5.x or later
179 ln -s `which wish` $idir/wish4.0
180 set path=($idir $path)
181 set mach="-w"
182 set opt="-O2 -DSPEED=200"
183 set special="ogl"
184 set compat="bmalloc.o strcmp.o"
185 breaksw
186 endsw
187 breaksw
188 case 4: # AIX
189 set opt="-O"
190 set compat="bmalloc.o erf.o strcmp.o"
191 set arch=PowerPC
192 breaksw
193 case 5: # BSDI BSD/386
194 set mach="-DBSD -L/usr/X11/lib -I/usr/X11/include"
195 set opt="-O -DSPEED=100"
196 set arch=IBMPC
197 set compat="malloc.o erf.o strcmp.o"
198 breaksw
199 case 6: # Linux
200 set mach="-Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO"
201 set opt="-O2 -DSPEED=200"
202 set arch=IBMPC
203 set compat="bmalloc.o erf.o getpagesize.o"
204 set extras=CC=gcc
205 breaksw
206 case 7: # MacOS X
207 set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib"
208 set opt="-O2 -DSPEED=200"
209 set arch=PowerPC
210 set compat="bmalloc.o"
211 set extras="CC=cc CONFIGURE_ARCH=powerpc"
212 set special="ogl"
213 breaksw
214 case 8: # FreeBSD
215 set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib"
216 set opt="-O -DSPEED=200"
217 set compat="bmalloc.o erf.o"
218 set extras="CC=cc"
219 set arch=IBMPC
220 breaksw
221 case 9: # Cygwin
222 set mach="-Dfreebsd -L/usr/lib -L/usr/X11R6/lib -I/usr/include/X11 -I/usr/X11R6/include -DNOSTEREO"
223 set opt="-O2 -DSPEED=200"
224 set arch=IBMPC
225 set compat="bmalloc.o erf.o getpagesize.o"
226 set extras="CC=gcc"
227 set special="ogl"
228 set esuffix=".exe"
229 breaksw
230 case 10: # Other
231 set opt="-O"
232 set compat="bmalloc.o erf.o strcmp.o"
233 echo -n "Are you using the GNU C compiler [n]? "
234 if ( "$<" =~ [yY]* ) then
235 set extras="CC=gcc"
236 endif
237 set arch=other
238 breaksw
239 default:
240 echo "Illegal choice\!"
241 echo "Installation aborted."
242 exit 1
243 breaksw
244 endsw
245 source installib
246 sed 's/[ ]*$//' > $rmake << _EOF_
247 #!/bin/sh
248 exec make "SPECIAL=$special" \
249 "OPT=$opt" \
250 "MACH=$mach" \
251 ARCH=$arch "COMPAT=$compat" \
252 INSTDIR=$idir \
253 LIBDIR=$ldir \
254 ESUFFIX=$esuffix \
255 $extras "\$@" -f Rmakefile
256 _EOF_
257 chmod 755 $rmake
258 chmod 644 src/*/Rmakefile src/rt/devtable.c
259 gotrmake:
260 echo "Current rmake command is:"
261 cat $rmake
262 echo -n "Do you want to change it? "
263 set ans="$<"
264 if ( "$ans" =~ [yY]* ) then
265 cp $rmake /tmp/rmake$$
266 $EDITOR $rmake
267 if ( `cat $rmake /tmp/rmake$$ | grep OPT= | uniq | wc -l` == 2 ) set newrmake
268 rm -f /tmp/rmake$$
269 endif
270 if ( ! -d src/lib ) then
271 mkdir src/lib
272 endif
273 if ( $?newrmake ) then
274 echo 'New rmake command -- running "makeall clean"...'
275 csh -f $0 clean
276 endif
277 cd src
278 echo "Making programs..."
279 set errs=0
280 foreach i ( $srcdirs )
281 pushd $i
282 echo "In directory $i..."
283 $rmake -k $*
284 @ errs += $status
285 popd
286 end
287 if ( $errs ) then
288 echo "There were some errors."
289 else
290 echo "Done."
291 endif
292 cd ..
293 if (! $inpath ) then
294 echo ""
295 echo "Add $idir to the beginning of your execution path:"
296 echo 'For C-shell users, put the following into ~/.cshrc'
297 echo " set path=( $idir "'$path )'
298 echo 'For Bourne shell users, put the following into $HOME/profile'
299 echo " PATH=$idir"':$PATH'
300 echo " export PATH"
301 endif
302 if (! -d /usr/tmp) then
303 ln -s /tmp /usr/tmp
304 if ($status) then
305 echo ""
306 echo "IMPORTANT: Execute 'sudo ln -s /tmp /usr/tmp'"
307 endif
308 endif
309 else
310 cd src
311 foreach i ( $srcdirs )
312 pushd $i
313 echo "In directory $i..."
314 make -f Rmakefile $*
315 popd
316 end
317 cd ..
318 foreach i ( $* )
319 if ( "$i" == clean ) then
320 echo "Removing library archives..."
321 rm -f src/lib/*.[ao]
322 endif
323 end
324 echo "Done."
325 endif
326 exit 0
