root/radiance/ray/makeall
Revision: 1.1
Committed: Sat Feb 22 02:07:20 2003 UTC (22 years ago) by greg
1 #!/bin/csh -f
2 # SCCSid "@(#)makeall 2.81 6/12/99 SGI"
3 #
4 #Added macosX 2001-04-11 by Jean Brange
5 #Deleted obsolete systems 2001-04-18 by Greg Ward
6 #
7 # Make all the Radiance programs
8 #
9 if ( $#argv < 1 ) then
10 echo "Usage: makeall install [clean] [make options]"
11 echo " or: makeall clean"
12 echo " or: makeall library"
13 exit 1
14 endif
15 if ( "$1" == library ) then
16 source installib
17 echo ""
18 echo "Set the environment variable RAYPATH=.:$ldir"
19 echo 'For C-shell users, put the following into ~/.cshrc'
20 echo " setenv RAYPATH .:$ldir"
21 echo 'For Bourne shell users, put the following into $HOME/profile'
22 echo " RAYPATH=.:$ldir"
23 echo " export RAYPATH"
24 echo ""
25 exit 0
26 endif
27 set srcdirs=( common meta cv gen ot rt px hd util cal )
28 if ( "$1" == install ) then
29 cat << _EOF_
30
31 `cat src/rt/VERSION` INSTALLATION
32
33 This script rebuilds all of the Radiance programs and installs
34 them on your system. You should read the file README before running
35 this script. You can type ^C (followed by return) at any time to abort.
36
37 You must first answer the following questions.
38
39 _EOF_
40 if ( ! $?EDITOR ) then
41 echo -n "What is your preferred editor [vi]? "
42 set ans="$<"
43 if ( "$ans" != "" ) then
44 setenv EDITOR "$ans"
45 else
46 setenv EDITOR vi
47 endif
48 endif
49 again1:
50 echo -n "Where do you want the executables [/usr/local/bin]? "
51 set idir=$<
52 (echo $idir) >/dev/null
53 if ( $status ) goto again1
54 set idir=$idir
55 if ( "$idir" == "" ) then
56 set idir=/usr/local/bin
57 else if ( "$idir" !~ /* ) then
58 echo "Directory must be relative to root, please reenter"
59 goto again1
60 endif
61 if ( ! -d $idir ) then
62 mkdir $idir
63 if ( $status ) then
64 echo "Cannot create directory, please reenter"
65 goto again1
66 endif
67 endif
68 if ( ! -d $idir/dev ) then
69 mkdir $idir/dev
70 if ( $status ) then
71 echo "Cannot create subdirectory, please reenter"
72 goto again1
73 endif
74 endif
75 set rmake=$idir/rmake
76 if ( "`ls -tL $rmake $0 |& head -1`" == $rmake ) goto gotrmake
77 set newrmake
78 goto skiplicense
79 cat << _EOF_
80
81 RADIANCE LICENSE AGREEMENT
82
83 Radiance is a registered copyright of The Regents of the University of
84 California ("The Regents"). The Regents grant to you a nonexclusive,
85 nontransferable license ("License") to use Radiance source code without
86 fee. You may not sell or distribute Radiance to others without the
87 prior express written permission of The Regents. You may compile and
88 use this software on any machines to which you have personal access,
89 and may share its use with others who have access to the same machines.
90
91 NEITHER THE UNITED STATES NOR THE UNITED STATES DEPARTMENT OF ENERGY, NOR ANY
92 OF THEIR EMPLOYEES, MAKES ANY WARRANTY, EXPRESS OR IMPLIED, OR ASSUMES ANY
93 LEGAL LIABILITY OR RESPONSIBILITY FOR THE ACCURACY, COMPLETENESS, OR USEFULNESS
94 OF ANY INFORMATION, APPARATUS, PRODUCT, OR PROCESS DISCLOSED, OR REPRESENTS
95 THAT ITS USE WOULD NOT INFRINGE PRIVATELY OWNED RIGHTS. By downloading, using
96 or copying this software, you agree to abide by the intellectual property laws
97 and all other applicable laws of the United States, and by the terms of this
98 License Agreement. Ownership of the software shall remain solely in The
99 Regents. The Regents shall have the right to terminate this License
100 immediately by written notice upon your breach of, or noncompliance with, any
101 of its terms. You shall be liable for any infringement or damages resulting
102 from your failure to abide by the terms of this License Agreement.
103
104 _EOF_
105 echo -n "Do you understand and accept the terms of this agreement [n]? "
106 set ans="$<"
107 if ( "$ans" !~ [yY]* ) exit
108 echo -n "Are you a new Radiance user or with a new address [y]? "
109 set ans="$<"
110 if ( "$ans" !~ [nN]* ) then
111 csh -f newuser
112 else
113 echo `cat src/rt/VERSION` compiled by `whoami` | mail [email protected]
114 endif
115 skiplicense:
116 set special=
117 set arch=
118 set opt=
119 set mach=
120 set compat=
121 set extras=
122 cat << _EOF_
123
124 Please select your system type from the following list:
125
126 1) Sun Solaris
127 2) HP workstation
128 3) Silicon Graphics
129 4) AIX (RS/6000)
130 5) BSDI BSD/386
131 6) Linux
132 7) MacOS X
133 8) FreeBSD
134 9) Other
135
136 _EOF_
137 echo -n "Choice? "
138 set arch="$<"
139 switch ("$arch")
140 case 1: # SPARC Station
141 set arch=sun
142 if ( `uname -r` =~ 4.* ) then
143 set mach="-fsingle -DBSD /usr/lib/libm.il -I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO"
144 set opt="-O -pipe -DSPEED=12"
145 set special="sun"
146 set compat="bmalloc.o strcmp.o"
147 else
148 set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO"
149 set opt="-O -DSPEED=80"
150 set special="ogl"
151 set compat="bmalloc.o strcmp.o getpagesize.o"
152 endif
153 breaksw
154 case 2: # HP workstation
155 set mach=""
156 set opt="-O -DSPEED=80 -Aa -D_HPUX_SOURCE"
157 set compat="malloc.o getpagesize.o strcmp.o"
158 set arch=hpux
159 breaksw
160 case 3: # Silicon Graphics
161 set arch=sgi
162 switch (`uname -r`)
163 case 3.*:
164 set mach="-noprototypes"
165 set opt="-O -DSPEED=80"
166 set special="sgi"
167 set compat="malloc.o strcmp.o"
168 breaksw
169 case 4.*:
170 set mach=""
171 set opt="-O2 -DSPEED=100"
172 set compat="malloc.o strcmp.o"
173 set extras='"MLIB=-lfastm -lm"'
174 breaksw
175 default: # 5.x or later
176 ln -s `which wish` $idir/wish4.0
177 set path=($idir $path)
178 set mach="-w"
179 set opt="-O2 -DSPEED=200"
180 set special="ogl"
181 set compat="malloc.o strcmp.o"
182 breaksw
183 endsw
184 breaksw
185 case 4: # AIX
186 set mach="-Dvoid=char -D_NO_PROTO -DINCL_SEL_H"
187 set opt="-O"
188 set compat="bmalloc.o erf.o"
189 breaksw
190 case 5: # BSDI BSD/386
191 set mach="-DBSD -L/usr/X11/lib -I/usr/X11/include"
192 set opt="-O -DSPEED=100"
193 set arch=IBMPC
194 set compat="malloc.o erf.o strcmp.o"
195 breaksw
196 case 6: # Linux
197 set mach="-Dlinux -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO"
198 set opt="-O2 -DSPEED=200"
199 set arch=IBMPC
200 set compat="bmalloc.o erf.o getpagesize.o"
201 set extras=CC=gcc
202 breaksw
203 case 7: # MacOS X
204 set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib"
205 set opt="-O2 -DSPEED=200"
206 set arch=PowerPC
207 set compat="bmalloc.o"
208 set extras="CC=cc CONFIGURE_ARCH=powerpc"
209 set special="ogl"
210 breaksw
211 case 8: # FreeBSD
212 set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib"
213 set opt="-O -DSPEED=200"
214 set compat="bmalloc.o erf.o"
215 set extras="CC=cc"
216 set arch=IBMPC
217 breaksw
218 case 9: # Other
219 set opt="-O"
220 set compat="bmalloc.o erf.o strcmp.o"
221 echo -n "Are you using the GNU C compiler [n]? "
222 if ( "$<" =~ [yY]* ) then
223 set extras="CC=gcc"
224 endif
225 breaksw
226 default:
227 echo "Illegal choice\!"
228 echo "Installation aborted."
229 exit 1
230 breaksw
231 endsw
232 # We don't seem to have any more cramped machines out there, so...
233 set mem="-DBIGMEM"
234 if ( $?mem ) then
235 set mach="$mach $mem"
236 else
237 echo -n "Does the target machine have more than 24 Mbytes of RAM? "
238 set ans="$<"
239 if ( "$ans" =~ [yY]* ) then
240 echo -n "More than 96 Mbytes? "
241 set ans="$<"
242 if ( "$ans" =~ [yY]* ) then
243 set mach="$mach -DBIGMEM"
244 set sizemod="huge models (100,000+ surfaces)"
245 else
246 set sizemod="very large models (30,000+ surfaces)"
247 endif
248 else
249 set sizemod="large models (10,000+ surfaces)"
250 endif
251 endif
252 # echo "Do you expect to be rendering $sizemod?"
253 # echo -n '(Answering "yes" may adversly affect rendering time and geometric accuracy) '
254 # set ans="$<"
255 # if ( "$ans" =~ [yY]* ) then
256 # set opt="$opt -DSMLFLT"
257 # endif
258 # echo -n "Do you have X10 support [n]? "
259 # if ( "$<" =~ [yY]* ) then
260 # set special="$special x10"
261 # endif
262 source installib
263 sed 's/[ ]*$//' > $rmake << _EOF_
264 #!/bin/sh
265 exec make "SPECIAL=$special" \
266 "OPT=$opt" \
267 "MACH=$mach" \
268 ARCH=$arch "COMPAT=$compat" \
269 INSTDIR=$idir \
270 LIBDIR=$ldir \
271 $extras "\$@" -f Rmakefile
272 _EOF_
273 chmod 755 $rmake
274 chmod 644 src/*/Rmakefile src/rt/devtable.c
275 gotrmake:
276 echo "Current rmake command is:"
277 cat $rmake
278 echo -n "Do you want to change it? "
279 set ans="$<"
280 if ( "$ans" =~ [yY]* ) then
281 cp $rmake /tmp/rmake$$
282 $EDITOR $rmake
283 if ( `cat $rmake /tmp/rmake$$ | grep OPT= | uniq | wc -l` == 2 ) set newrmake
284 rm -f /tmp/rmake$$
285 endif
286 if ( ! -d src/lib ) then
287 mkdir src/lib
288 endif
289 if ( $?newrmake ) then
290 echo 'New rmake command -- running "makeall clean"...'
291 csh -f $0 clean
292 endif
293 cd src
294 echo "Making programs..."
295 set errs=0
296 foreach i ( $srcdirs )
297 pushd $i
298 echo "In directory $i..."
299 $rmake -k $*
300 @ errs += $status
301 popd
302 end
303 if ( $errs ) then
304 echo "There were some errors."
305 else
306 echo "Done."
307 endif
308 cd ..
309 if (! -d /usr/tmp) then
310 ln -s /tmp /usr/tmp
311 if ($status) then
312 echo ""
313 echo "IMPORTANT: Execute 'sudo ln -s /tmp /usr/tmp'"
314 echo ""
315 endif
316 endif
317 else
318 cd src
319 foreach i ( $srcdirs )
320 pushd $i
321 echo "In directory $i..."
322 make -f Rmakefile $*
323 popd
324 end
325 echo "Done."
326 cd ..
327 endif
328 foreach i ( $* )
329 if ( "$i" == clean ) then
330 echo "Removing library archives..."
331 rm -f src/lib/*.a
332 endif
333 end
334 exit 0
