--- ray/makeall 2005/07/26 01:20:36 1.17 +++ ray/makeall 2009/10/31 22:29:06 1.24 @@ -1,5 +1,5 @@ #!/bin/csh -f -# RCSid $Id: makeall,v 1.17 2005/07/26 01:20:36 greg Exp $ +# RCSid $Id: makeall,v 1.24 2009/10/31 22:29:06 greg Exp $ # # Make all the Radiance programs # @@ -16,7 +16,7 @@ if ( "$1" == library ) then echo "Set the environment variable RAYPATH=.:$ldir" echo 'For C-shell users, put the following into ~/.cshrc' echo " setenv RAYPATH .:$ldir" - echo 'For Bourne shell users, put the following into $HOME/profile' + echo 'For Bourne shell users, put the following into $HOME/.profile' echo " RAYPATH=.:$ldir" echo " export RAYPATH" echo "" @@ -100,15 +100,11 @@ cat << _EOF_ Please select your system type from the following list: 1) Sun Solaris - 2) HP workstation - 3) Silicon Graphics - 4) AIX (RS/6000) - 5) BSDI BSD/386 - 6) Linux - 7) MacOS X - 8) FreeBSD - 9) Cygwin - 10) Other + 2) Linux + 3) MacOS X + 4) FreeBSD + 5) Cygwin + 6) Other _EOF_ echo -n "Choice? " @@ -117,82 +113,40 @@ switch ("$arch") case 1: # SPARC Station set arch=sun set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO" - set opt="-O -DSPEED=80" + set opt="-O" set compat="strcmp.o" breaksw -case 2: # HP workstation - set mach="" - set opt="-O -DSPEED=80 -Aa -D_HPUX_SOURCE" - set compat="strcmp.o" - set arch=hpux - breaksw -case 3: # Silicon Graphics - set arch=sgi - switch (`uname -r`) - case 3.*: - set mach="-noprototypes" - set opt="-O -DSPEED=80" - set special="sgi" - set compat="strcmp.o" - breaksw - case 4.*: - set mach="" - set opt="-O2 -DSPEED=100" - set compat="strcmp.o" - set extras='"MLIB=-lfastm -lm"' - breaksw - default: # 5.x or later - ln -s `which wish` $idir/wish4.0 - set path=($idir $path) - set mach="-w" - set opt="-O2 -DSPEED=200" - set special="ogl" - set compat="strcmp.o" - breaksw - endsw - breaksw -case 4: # AIX - set opt="-O" - set compat="erf.o strcmp.o" - set arch=PowerPC - breaksw -case 5: # BSDI BSD/386 - set mach="-DBSD -L/usr/X11/lib -I/usr/X11/include" - set opt="-O -DSPEED=100" - set arch=IBMPC - set compat="erf.o strcmp.o" - breaksw -case 6: # Linux +case 2: # Linux set mach="-Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO" - set opt="-O2 -DSPEED=200" + set opt="-O2" set arch=IBMPC set compat="erf.o" set extras=CC=gcc breaksw -case 7: # MacOS X +case 3: # MacOS X set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib" - set opt="-O2 -DSPEED=200" - set arch=PowerPC - set extras="CC=cc CONFIGURE_ARCH=powerpc" + set opt="-O2" + set arch=Intel + set extras="CC=cc CONFIGURE_ARCH=i386" set special="ogl" breaksw -case 8: # FreeBSD +case 4: # FreeBSD set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib" - set opt="-O -DSPEED=200" + set opt="-O" set compat="erf.o" - set extras="CC=cc" + set extras='CC=cc MLIB="-lcompat -lm"' set arch=IBMPC breaksw -case 9: # Cygwin +case 5: # Cygwin set mach="-Dfreebsd -L/usr/lib -L/usr/X11R6/lib -I/usr/include/X11 -I/usr/X11R6/include -DNOSTEREO" - set opt="-O2 -DSPEED=200" + set opt="-O2" set arch=IBMPC set compat="erf.o" set extras="CC=gcc" set special="ogl" set esuffix=".exe" breaksw -case 10: # Other +case 6: # Other set opt="-O" set compat="erf.o strcmp.o" echo -n "Are you using the GNU C compiler [n]? " @@ -260,7 +214,7 @@ if (! $inpath ) then echo "Add $idir to the beginning of your execution path:" echo 'For C-shell users, put the following into ~/.cshrc' echo " set path=( $idir "'$path )' - echo 'For Bourne shell users, put the following into $HOME/profile' + echo 'For Bourne shell users, put the following into $HOME/.profile' echo " PATH=$idir"':$PATH' echo " export PATH" endif
