--- ray/makeall 2005/02/01 16:05:38 1.13 +++ ray/makeall 2008/04/17 14:58:57 1.23 @@ -1,5 +1,5 @@ #!/bin/csh -f -# RCSid $Id: makeall,v 1.13 2005/02/01 16:05:38 greg Exp $ +# RCSid $Id: makeall,v 1.23 2008/04/17 14:58:57 greg Exp $ # # Make all the Radiance programs # @@ -16,13 +16,13 @@ if ( "$1" == library ) then echo "Set the environment variable RAYPATH=.:$ldir" echo 'For C-shell users, put the following into ~/.cshrc' echo " setenv RAYPATH .:$ldir" - echo 'For Bourne shell users, put the following into $HOME/profile' + echo 'For Bourne shell users, put the following into $HOME/.profile' echo " RAYPATH=.:$ldir" echo " export RAYPATH" echo "" exit 0 endif -set srcdirs=( common meta cv gen ot rt px hd util cal ) +set srcdirs=( common rt meta cv gen ot px hd util cal ) if ( "$1" == install ) then cat << _EOF_ @@ -117,13 +117,13 @@ switch ("$arch") case 1: # SPARC Station set arch=sun set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO" - set opt="-O -DSPEED=80" - set compat="bmalloc.o strcmp.o" + set opt="-O" + set compat="strcmp.o" breaksw case 2: # HP workstation set mach="" - set opt="-O -DSPEED=80 -Aa -D_HPUX_SOURCE" - set compat="bmalloc.o strcmp.o" + set opt="-O -Aa -D_HPUX_SOURCE" + set compat="strcmp.o" set arch=hpux breaksw case 3: # Silicon Graphics @@ -131,71 +131,72 @@ case 3: # Silicon Graphics switch (`uname -r`) case 3.*: set mach="-noprototypes" - set opt="-O -DSPEED=80" + set opt="-O" set special="sgi" - set compat="malloc.o strcmp.o" + set compat="strcmp.o" breaksw case 4.*: set mach="" - set opt="-O2 -DSPEED=100" - set compat="malloc.o strcmp.o" + set opt="-O2" + set compat="strcmp.o" set extras='"MLIB=-lfastm -lm"' breaksw default: # 5.x or later ln -s `which wish` $idir/wish4.0 set path=($idir $path) set mach="-w" - set opt="-O2 -DSPEED=200" + set opt="-O2" set special="ogl" - set compat="bmalloc.o strcmp.o" + set compat="strcmp.o" breaksw endsw breaksw case 4: # AIX set opt="-O" - set compat="bmalloc.o erf.o strcmp.o" + set compat="erf.o strcmp.o" set arch=PowerPC breaksw case 5: # BSDI BSD/386 set mach="-DBSD -L/usr/X11/lib -I/usr/X11/include" - set opt="-O -DSPEED=100" + set opt="-O" set arch=IBMPC - set compat="malloc.o erf.o strcmp.o" + set compat="erf.o strcmp.o" breaksw case 6: # Linux set mach="-Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO" - set opt="-O2 -DSPEED=200" + set opt="-O2" set arch=IBMPC - set compat="bmalloc.o erf.o" + set compat="erf.o" set extras=CC=gcc breaksw case 7: # MacOS X set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib" - set opt="-O2 -DSPEED=200" + # Ugly fix for Leopard OpenGL link bug: + if (`uname -r` =~ 9.*) set mach="$mach -Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib" + set opt="-O2" set arch=PowerPC - set compat="bmalloc.o" set extras="CC=cc CONFIGURE_ARCH=powerpc" set special="ogl" breaksw case 8: # FreeBSD set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib" - set opt="-O -DSPEED=200" - set compat="bmalloc.o erf.o" - set extras="CC=cc" + set opt="-O" + set compat="erf.o" + set extras='CC=cc MLIB="-lcompat -lm"' set arch=IBMPC breaksw case 9: # Cygwin set mach="-Dfreebsd -L/usr/lib -L/usr/X11R6/lib -I/usr/include/X11 -I/usr/X11R6/include -DNOSTEREO" - set opt="-O2 -DSPEED=200" + set opt="-O2" set arch=IBMPC - set compat="bmalloc.o erf.o" + set compat="erf.o" set extras="CC=gcc" set special="ogl" set esuffix=".exe" breaksw case 10: # Other set opt="-O" - set compat="bmalloc.o erf.o strcmp.o" + set compat="erf.o strcmp.o" echo -n "Are you using the GNU C compiler [n]? " if ( "$<" =~ [yY]* ) then set extras="CC=gcc" @@ -261,7 +262,7 @@ if (! $inpath ) then echo "Add $idir to the beginning of your execution path:" echo 'For C-shell users, put the following into ~/.cshrc' echo " set path=( $idir "'$path )' - echo 'For Bourne shell users, put the following into $HOME/profile' + echo 'For Bourne shell users, put the following into $HOME/.profile' echo " PATH=$idir"':$PATH' echo " export PATH" endif @@ -277,7 +278,7 @@ cd .. foreach i ( $* ) if ( "$i" == clean ) then echo "Removing library archives..." - rm -f src/lib/*.[ao] + rm -f src/lib/*.{a,o,la} endif end echo "Done."
