--- ray/makeall 2003/11/25 18:23:11 1.10 +++ ray/makeall 2005/08/09 21:21:14 1.19 @@ -1,5 +1,5 @@ #!/bin/csh -f -# RCSid $Id: makeall,v 1.10 2003/11/25 18:23:11 greg Exp $ +# RCSid $Id: makeall,v 1.19 2005/08/09 21:21:14 greg Exp $ # # Make all the Radiance programs # @@ -16,13 +16,13 @@ if ( "$1" == library ) then echo "Set the environment variable RAYPATH=.:$ldir" echo 'For C-shell users, put the following into ~/.cshrc' echo " setenv RAYPATH .:$ldir" - echo 'For Bourne shell users, put the following into $HOME/profile' + echo 'For Bourne shell users, put the following into $HOME/.profile' echo " RAYPATH=.:$ldir" echo " export RAYPATH" echo "" exit 0 endif -set srcdirs=( common meta cv gen ot rt px hd util cal ) +set srcdirs=( common rt meta cv gen ot px hd util cal ) if ( "$1" == install ) then cat << _EOF_ @@ -84,44 +84,10 @@ if ( "`ls -tL $rmake $0 |& head -1`" == $rmake ) then goto gotrmake endif set newrmake -goto skiplicense -cat << _EOF_ - - RADIANCE LICENSE AGREEMENT - -Radiance is a registered copyright of The Regents of the University of -California ("The Regents"). The Regents grant to you a nonexclusive, -nontransferable license ("License") to use Radiance source code without -fee. You may not sell or distribute Radiance to others without the -prior express written permission of The Regents. You may compile and -use this software on any machines to which you have personal access, -and may share its use with others who have access to the same machines. - -NEITHER THE UNITED STATES NOR THE UNITED STATES DEPARTMENT OF ENERGY, NOR ANY -OF THEIR EMPLOYEES, MAKES ANY WARRANTY, EXPRESS OR IMPLIED, OR ASSUMES ANY -LEGAL LIABILITY OR RESPONSIBILITY FOR THE ACCURACY, COMPLETENESS, OR USEFULNESS -OF ANY INFORMATION, APPARATUS, PRODUCT, OR PROCESS DISCLOSED, OR REPRESENTS -THAT ITS USE WOULD NOT INFRINGE PRIVATELY OWNED RIGHTS. By downloading, using -or copying this software, you agree to abide by the intellectual property laws -and all other applicable laws of the United States, and by the terms of this -License Agreement. Ownership of the software shall remain solely in The -Regents. The Regents shall have the right to terminate this License -immediately by written notice upon your breach of, or noncompliance with, any -of its terms. You shall be liable for any infringement or damages resulting -from your failure to abide by the terms of this License Agreement. - -_EOF_ +more src/common/copyright.h echo -n "Do you understand and accept the terms of this agreement [n]? " set ans="$<" if ( "$ans" !~ [yY]* ) exit -echo -n "Are you a new Radiance user or with a new address [y]? " -set ans="$<" -if ( "$ans" !~ [nN]* ) then - csh -f newuser -else - echo `cat src/rt/VERSION` compiled by `whoami` | mail radiance-request@floyd.lbl.gov -endif -skiplicense: set special= set arch= set opt= @@ -152,12 +118,12 @@ case 1: # SPARC Station set arch=sun set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO" set opt="-O -DSPEED=80" - set compat="bmalloc.o strcmp.o getpagesize.o" + set compat="strcmp.o" breaksw case 2: # HP workstation set mach="" set opt="-O -DSPEED=80 -Aa -D_HPUX_SOURCE" - set compat="bmalloc.o getpagesize.o strcmp.o" + set compat="strcmp.o" set arch=hpux breaksw case 3: # Silicon Graphics @@ -167,12 +133,12 @@ case 3: # Silicon Graphics set mach="-noprototypes" set opt="-O -DSPEED=80" set special="sgi" - set compat="malloc.o strcmp.o" + set compat="strcmp.o" breaksw case 4.*: set mach="" set opt="-O2 -DSPEED=100" - set compat="malloc.o strcmp.o" + set compat="strcmp.o" set extras='"MLIB=-lfastm -lm"' breaksw default: # 5.x or later @@ -181,55 +147,54 @@ case 3: # Silicon Graphics set mach="-w" set opt="-O2 -DSPEED=200" set special="ogl" - set compat="bmalloc.o strcmp.o" + set compat="strcmp.o" breaksw endsw breaksw case 4: # AIX set opt="-O" - set compat="bmalloc.o erf.o strcmp.o" + set compat="erf.o strcmp.o" set arch=PowerPC breaksw case 5: # BSDI BSD/386 set mach="-DBSD -L/usr/X11/lib -I/usr/X11/include" set opt="-O -DSPEED=100" set arch=IBMPC - set compat="malloc.o erf.o strcmp.o" + set compat="erf.o strcmp.o" breaksw case 6: # Linux set mach="-Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO" set opt="-O2 -DSPEED=200" set arch=IBMPC - set compat="bmalloc.o erf.o getpagesize.o" + set compat="erf.o" set extras=CC=gcc breaksw case 7: # MacOS X set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib" set opt="-O2 -DSPEED=200" set arch=PowerPC - set compat="bmalloc.o" set extras="CC=cc CONFIGURE_ARCH=powerpc" set special="ogl" breaksw case 8: # FreeBSD set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib" set opt="-O -DSPEED=200" - set compat="bmalloc.o erf.o" - set extras="CC=cc" + set compat="erf.o" + set extras='CC=cc MLIB="-lcompat -lm"' set arch=IBMPC breaksw case 9: # Cygwin set mach="-Dfreebsd -L/usr/lib -L/usr/X11R6/lib -I/usr/include/X11 -I/usr/X11R6/include -DNOSTEREO" set opt="-O2 -DSPEED=200" set arch=IBMPC - set compat="bmalloc.o erf.o getpagesize.o" + set compat="erf.o" set extras="CC=gcc" set special="ogl" set esuffix=".exe" breaksw case 10: # Other set opt="-O" - set compat="bmalloc.o erf.o strcmp.o" + set compat="erf.o strcmp.o" echo -n "Are you using the GNU C compiler [n]? " if ( "$<" =~ [yY]* ) then set extras="CC=gcc" @@ -295,17 +260,10 @@ if (! $inpath ) then echo "Add $idir to the beginning of your execution path:" echo 'For C-shell users, put the following into ~/.cshrc' echo " set path=( $idir "'$path )' - echo 'For Bourne shell users, put the following into $HOME/profile' + echo 'For Bourne shell users, put the following into $HOME/.profile' echo " PATH=$idir"':$PATH' echo " export PATH" endif -if (! -d /usr/tmp) then - ln -s /tmp /usr/tmp - if ($status) then - echo "" - echo "IMPORTANT: Execute 'sudo ln -s /tmp /usr/tmp'" - endif -endif else cd src foreach i ( $srcdirs ) @@ -318,7 +276,7 @@ cd .. foreach i ( $* ) if ( "$i" == clean ) then echo "Removing library archives..." - rm -f src/lib/*.[ao] + rm -f src/lib/*.{a,o,la} endif end echo "Done."
