--- ray/makeall 2005/02/02 00:09:13 1.15 +++ ray/makeall 2005/09/19 02:23:58 1.20 @@ -1,5 +1,5 @@ #!/bin/csh -f -# RCSid $Id: makeall,v 1.15 2005/02/02 00:09:13 greg Exp $ +# RCSid $Id: makeall,v 1.20 2005/09/19 02:23:58 greg Exp $ # # Make all the Radiance programs # @@ -16,13 +16,13 @@ if ( "$1" == library ) then echo "Set the environment variable RAYPATH=.:$ldir" echo 'For C-shell users, put the following into ~/.cshrc' echo " setenv RAYPATH .:$ldir" - echo 'For Bourne shell users, put the following into $HOME/profile' + echo 'For Bourne shell users, put the following into $HOME/.profile' echo " RAYPATH=.:$ldir" echo " export RAYPATH" echo "" exit 0 endif -set srcdirs=( common meta cv gen ot rt px hd util cal ) +set srcdirs=( common rt meta cv gen ot px hd util cal ) if ( "$1" == install ) then cat << _EOF_ @@ -117,12 +117,12 @@ switch ("$arch") case 1: # SPARC Station set arch=sun set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO" - set opt="-O -DSPEED=80" + set opt="-O" set compat="strcmp.o" breaksw case 2: # HP workstation set mach="" - set opt="-O -DSPEED=80 -Aa -D_HPUX_SOURCE" + set opt="-O -Aa -D_HPUX_SOURCE" set compat="strcmp.o" set arch=hpux breaksw @@ -131,13 +131,13 @@ case 3: # Silicon Graphics switch (`uname -r`) case 3.*: set mach="-noprototypes" - set opt="-O -DSPEED=80" + set opt="-O" set special="sgi" set compat="strcmp.o" breaksw case 4.*: set mach="" - set opt="-O2 -DSPEED=100" + set opt="-O2" set compat="strcmp.o" set extras='"MLIB=-lfastm -lm"' breaksw @@ -145,7 +145,7 @@ case 3: # Silicon Graphics ln -s `which wish` $idir/wish4.0 set path=($idir $path) set mach="-w" - set opt="-O2 -DSPEED=200" + set opt="-O2" set special="ogl" set compat="strcmp.o" breaksw @@ -158,34 +158,34 @@ case 4: # AIX breaksw case 5: # BSDI BSD/386 set mach="-DBSD -L/usr/X11/lib -I/usr/X11/include" - set opt="-O -DSPEED=100" + set opt="-O" set arch=IBMPC set compat="erf.o strcmp.o" breaksw case 6: # Linux set mach="-Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO" - set opt="-O2 -DSPEED=200" + set opt="-O2" set arch=IBMPC set compat="erf.o" set extras=CC=gcc breaksw case 7: # MacOS X set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib" - set opt="-O2 -DSPEED=200" + set opt="-O2" set arch=PowerPC set extras="CC=cc CONFIGURE_ARCH=powerpc" set special="ogl" breaksw case 8: # FreeBSD set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib" - set opt="-O -DSPEED=200" + set opt="-O" set compat="erf.o" - set extras="CC=cc" + set extras='CC=cc MLIB="-lcompat -lm"' set arch=IBMPC breaksw case 9: # Cygwin set mach="-Dfreebsd -L/usr/lib -L/usr/X11R6/lib -I/usr/include/X11 -I/usr/X11R6/include -DNOSTEREO" - set opt="-O2 -DSPEED=200" + set opt="-O2" set arch=IBMPC set compat="erf.o" set extras="CC=gcc" @@ -260,7 +260,7 @@ if (! $inpath ) then echo "Add $idir to the beginning of your execution path:" echo 'For C-shell users, put the following into ~/.cshrc' echo " set path=( $idir "'$path )' - echo 'For Bourne shell users, put the following into $HOME/profile' + echo 'For Bourne shell users, put the following into $HOME/.profile' echo " PATH=$idir"':$PATH' echo " export PATH" endif @@ -276,7 +276,7 @@ cd .. foreach i ( $* ) if ( "$i" == clean ) then echo "Removing library archives..." - rm -f src/lib/*.[ao] + rm -f src/lib/*.{a,o,la} endif end echo "Done."
