--- ray/makeall 2003/02/22 02:07:20 1.1 +++ ray/makeall 2003/11/25 18:23:11 1.10 @@ -1,9 +1,6 @@ #!/bin/csh -f -# SCCSid "@(#)makeall 2.81 6/12/99 SGI" +# RCSid $Id: makeall,v 1.10 2003/11/25 18:23:11 greg Exp $ # -#Added macosX 2001-04-11 by Jean Brange -#Deleted obsolete systems 2001-04-18 by Greg Ward -# # Make all the Radiance programs # if ( $#argv < 1 ) then @@ -14,6 +11,7 @@ if ( $#argv < 1 ) then endif if ( "$1" == library ) then source installib + cp -f src/*/*.{cal,tab,hex} $ldir echo "" echo "Set the environment variable RAYPATH=.:$ldir" echo 'For C-shell users, put the following into ~/.cshrc' @@ -50,7 +48,9 @@ again1: echo -n "Where do you want the executables [/usr/local/bin]? " set idir=$< (echo $idir) >/dev/null -if ( $status ) goto again1 +if ( $status ) then + goto again1 +endif set idir=$idir if ( "$idir" == "" ) then set idir=/usr/local/bin @@ -72,8 +72,17 @@ if ( ! -d $idir/dev ) then goto again1 endif endif +set inpath=0 +foreach i ( $path ) + if ( "$i" == "$idir" ) then + set inpath=1 + break + endif +end set rmake=$idir/rmake -if ( "`ls -tL $rmake $0 |& head -1`" == $rmake ) goto gotrmake +if ( "`ls -tL $rmake $0 |& head -1`" == $rmake ) then + goto gotrmake +endif set newrmake goto skiplicense cat << _EOF_ @@ -119,6 +128,7 @@ set opt= set mach= set compat= set extras= +set esuffix= cat << _EOF_ Please select your system type from the following list: @@ -129,9 +139,10 @@ Please select your system type from the following list 4) AIX (RS/6000) 5) BSDI BSD/386 6) Linux - 7) MacOS X + 7) MacOS X 8) FreeBSD - 9) Other + 9) Cygwin + 10) Other _EOF_ echo -n "Choice? " @@ -139,22 +150,14 @@ set arch="$<" switch ("$arch") case 1: # SPARC Station set arch=sun - if ( `uname -r` =~ 4.* ) then - set mach="-fsingle -DBSD /usr/lib/libm.il -I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO" - set opt="-O -pipe -DSPEED=12" - set special="sun" - set compat="bmalloc.o strcmp.o" - else - set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO" - set opt="-O -DSPEED=80" - set special="ogl" - set compat="bmalloc.o strcmp.o getpagesize.o" - endif + set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO" + set opt="-O -DSPEED=80" + set compat="bmalloc.o strcmp.o getpagesize.o" breaksw case 2: # HP workstation set mach="" set opt="-O -DSPEED=80 -Aa -D_HPUX_SOURCE" - set compat="malloc.o getpagesize.o strcmp.o" + set compat="bmalloc.o getpagesize.o strcmp.o" set arch=hpux breaksw case 3: # Silicon Graphics @@ -178,14 +181,14 @@ case 3: # Silicon Graphics set mach="-w" set opt="-O2 -DSPEED=200" set special="ogl" - set compat="malloc.o strcmp.o" + set compat="bmalloc.o strcmp.o" breaksw endsw breaksw case 4: # AIX - set mach="-Dvoid=char -D_NO_PROTO -DINCL_SEL_H" set opt="-O" - set compat="bmalloc.o erf.o" + set compat="bmalloc.o erf.o strcmp.o" + set arch=PowerPC breaksw case 5: # BSDI BSD/386 set mach="-DBSD -L/usr/X11/lib -I/usr/X11/include" @@ -194,34 +197,44 @@ case 5: # BSDI BSD/386 set compat="malloc.o erf.o strcmp.o" breaksw case 6: # Linux - set mach="-Dlinux -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO" + set mach="-Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO" set opt="-O2 -DSPEED=200" set arch=IBMPC set compat="bmalloc.o erf.o getpagesize.o" set extras=CC=gcc breaksw -case 7: # MacOS X - set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib" - set opt="-O2 -DSPEED=200" - set arch=PowerPC - set compat="bmalloc.o" - set extras="CC=cc CONFIGURE_ARCH=powerpc" +case 7: # MacOS X + set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib" + set opt="-O2 -DSPEED=200" + set arch=PowerPC + set compat="bmalloc.o" + set extras="CC=cc CONFIGURE_ARCH=powerpc" set special="ogl" - breaksw + breaksw case 8: # FreeBSD - set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib" - set opt="-O -DSPEED=200" - set compat="bmalloc.o erf.o" - set extras="CC=cc" + set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib" + set opt="-O -DSPEED=200" + set compat="bmalloc.o erf.o" + set extras="CC=cc" set arch=IBMPC - breaksw -case 9: # Other + breaksw +case 9: # Cygwin + set mach="-Dfreebsd -L/usr/lib -L/usr/X11R6/lib -I/usr/include/X11 -I/usr/X11R6/include -DNOSTEREO" + set opt="-O2 -DSPEED=200" + set arch=IBMPC + set compat="bmalloc.o erf.o getpagesize.o" + set extras="CC=gcc" + set special="ogl" + set esuffix=".exe" + breaksw +case 10: # Other set opt="-O" set compat="bmalloc.o erf.o strcmp.o" echo -n "Are you using the GNU C compiler [n]? " if ( "$<" =~ [yY]* ) then set extras="CC=gcc" endif + set arch=other breaksw default: echo "Illegal choice\!" @@ -229,36 +242,6 @@ default: exit 1 breaksw endsw -# We don't seem to have any more cramped machines out there, so... -set mem="-DBIGMEM" -if ( $?mem ) then - set mach="$mach $mem" -else - echo -n "Does the target machine have more than 24 Mbytes of RAM? " - set ans="$<" - if ( "$ans" =~ [yY]* ) then - echo -n "More than 96 Mbytes? " - set ans="$<" - if ( "$ans" =~ [yY]* ) then - set mach="$mach -DBIGMEM" - set sizemod="huge models (100,000+ surfaces)" - else - set sizemod="very large models (30,000+ surfaces)" - endif - else - set sizemod="large models (10,000+ surfaces)" - endif -endif -# echo "Do you expect to be rendering $sizemod?" -# echo -n '(Answering "yes" may adversly affect rendering time and geometric accuracy) ' -# set ans="$<" -# if ( "$ans" =~ [yY]* ) then -# set opt="$opt -DSMLFLT" -# endif -# echo -n "Do you have X10 support [n]? " -# if ( "$<" =~ [yY]* ) then -# set special="$special x10" -# endif source installib sed 's/[ ]*$//' > $rmake << _EOF_ #!/bin/sh @@ -268,6 +251,7 @@ exec make "SPECIAL=$special" \ ARCH=$arch "COMPAT=$compat" \ INSTDIR=$idir \ LIBDIR=$ldir \ + ESUFFIX=$esuffix \ $extras "\$@" -f Rmakefile _EOF_ chmod 755 $rmake @@ -306,12 +290,20 @@ else echo "Done." endif cd .. +if (! $inpath ) then + echo "" + echo "Add $idir to the beginning of your execution path:" + echo 'For C-shell users, put the following into ~/.cshrc' + echo " set path=( $idir "'$path )' + echo 'For Bourne shell users, put the following into $HOME/profile' + echo " PATH=$idir"':$PATH' + echo " export PATH" +endif if (! -d /usr/tmp) then ln -s /tmp /usr/tmp if ($status) then echo "" echo "IMPORTANT: Execute 'sudo ln -s /tmp /usr/tmp'" - echo "" endif endif else @@ -322,13 +314,13 @@ foreach i ( $srcdirs ) make -f Rmakefile $* popd end -echo "Done." cd .. -endif foreach i ( $* ) if ( "$i" == clean ) then echo "Removing library archives..." - rm -f src/lib/*.a + rm -f src/lib/*.[ao] endif end +echo "Done." +endif exit 0
