root/Development/ray/makeall
Revision: 1.32
Committed: Tue Dec 3 01:11:43 2024 UTC (11 months, 3 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 1.31: +14 -21 lines
# User Rev Content
1 greg 1.1 #!/bin/csh -f
2 greg 1.32 # RCSid $Id: makeall,v 1.31 2022/02/16 18:56:32 greg Exp $
3 greg 1.1 #
4     # Make all the Radiance programs
5     #
6     if ( $#argv < 1 ) then
7     echo "Usage: makeall install [clean] [make options]"
8     echo " or: makeall clean"
9     echo " or: makeall library"
10 greg 1.30 echo " or: makeall test"
11 greg 1.1 exit 1
12     endif
13     if ( "$1" == library ) then
14     source installib
15 greg 1.28 cp -f src/*/*.{cal,tab,hex,dat} $ldir
16 greg 1.1 echo ""
17     echo "Set the environment variable RAYPATH=.:$ldir"
18     echo 'For C-shell users, put the following into ~/.cshrc'
19     echo " setenv RAYPATH .:$ldir"
20 greg 1.19 echo 'For Bourne shell users, put the following into $HOME/.profile'
21 greg 1.1 echo " RAYPATH=.:$ldir"
22     echo " export RAYPATH"
23     echo ""
24     exit 0
25     endif
26 greg 1.30 if ( "$1" == test ) then
27     cd test
28     set fails=()
29 greg 1.31 foreach d (cv cal gen util px renders)
30 greg 1.30 cd $d
31     make -k clean all && make clean
32     if ($status) set fails=($fails $d)
33     cd ..
34     end
35     if ($#fails) then
36     echo "Unit tests failed in $#fails directories"
37     echo "Run 'make' manually in test/ subfolders: $fails"
38     exit 1
39     endif
40     echo "All tests passed successfully."
41     exit 0
42     endif
43 greg 1.16 set srcdirs=( common rt meta cv gen ot px hd util cal )
44 greg 1.1 if ( "$1" == install ) then
45     cat << _EOF_
46
47     `cat src/rt/VERSION` INSTALLATION
48
49     This script rebuilds all of the Radiance programs and installs
50     them on your system. You should read the file README before running
51     this script. You can type ^C (followed by return) at any time to abort.
52
53     You must first answer the following questions.
54
55     _EOF_
56     if ( ! $?EDITOR ) then
57     echo -n "What is your preferred editor [vi]? "
58     set ans="$<"
59     if ( "$ans" != "" ) then
60     setenv EDITOR "$ans"
61     else
62     setenv EDITOR vi
63     endif
64     endif
65     again1:
66     echo -n "Where do you want the executables [/usr/local/bin]? "
67     set idir=$<
68     (echo $idir) >/dev/null
69 greg 1.4 if ( $status ) then
70     goto again1
71     endif
72 greg 1.1 set idir=$idir
73     if ( "$idir" == "" ) then
74     set idir=/usr/local/bin
75     else if ( "$idir" !~ /* ) then
76     echo "Directory must be relative to root, please reenter"
77     goto again1
78     endif
79     if ( ! -d $idir ) then
80     mkdir $idir
81     if ( $status ) then
82     echo "Cannot create directory, please reenter"
83     goto again1
84     endif
85     endif
86 greg 1.10 set inpath=0
87     foreach i ( $path )
88     if ( "$i" == "$idir" ) then
89     set inpath=1
90     break
91     endif
92     end
93 greg 1.1 set rmake=$idir/rmake
94 greg 1.4 if ( "`ls -tL $rmake $0 |& head -1`" == $rmake ) then
95     goto gotrmake
96     endif
97 greg 1.1 set newrmake
98 greg 1.26 more License.txt
99 greg 1.1 echo -n "Do you understand and accept the terms of this agreement [n]? "
100     set ans="$<"
101     if ( "$ans" !~ [yY]* ) exit
102     set special=
103     set arch=
104     set opt=
105     set mach=
106     set compat=
107     set extras=
108 schorsch 1.9 set esuffix=
109 greg 1.1 cat << _EOF_
110
111     Please select your system type from the following list:
112
113 greg 1.32 1) Linux
114     2) MacOS X
115     3) FreeBSD
116     4) Cygwin
117     5) Other
118 greg 1.1
119     _EOF_
120     echo -n "Choice? "
121     set arch="$<"
122     switch ("$arch")
123 greg 1.32 case 1: # Linux
124 greg 1.22 set mach="-Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO"
125 greg 1.20 set opt="-O2"
126 greg 1.1 set arch=IBMPC
127 greg 1.32 set compat="strnstr.o strlcpy.o"
128 greg 1.1 set extras=CC=gcc
129     breaksw
130 greg 1.32 case 2: # MacOS X
131 schorsch 1.9 set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib"
132 greg 1.20 set opt="-O2"
133 greg 1.24 set arch=Intel
134     set extras="CC=cc CONFIGURE_ARCH=i386"
135 greg 1.1 set special="ogl"
136 schorsch 1.9 breaksw
137 greg 1.32 case 3: # FreeBSD
138 schorsch 1.9 set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib"
139 greg 1.20 set opt="-O"
140 greg 1.15 set compat="erf.o"
141 greg 1.18 set extras='CC=cc MLIB="-lcompat -lm"'
142 greg 1.1 set arch=IBMPC
143 schorsch 1.9 breaksw
144 greg 1.32 case 4: # Cygwin
145 schorsch 1.9 set mach="-Dfreebsd -L/usr/lib -L/usr/X11R6/lib -I/usr/include/X11 -I/usr/X11R6/include -DNOSTEREO"
146 greg 1.20 set opt="-O2"
147 schorsch 1.9 set arch=IBMPC
148 greg 1.32 set compat="erf.o strnstr.o strlcpy.o"
149 schorsch 1.9 set extras="CC=gcc"
150     set special="ogl"
151     set esuffix=".exe"
152     breaksw
153 greg 1.32 case 5: # Other
154 greg 1.1 set opt="-O"
155 greg 1.32 set compat="erf.o strcmp.o strnstr.o strlcpy.o"
156 greg 1.1 echo -n "Are you using the GNU C compiler [n]? "
157     if ( "$<" =~ [yY]* ) then
158     set extras="CC=gcc"
159 greg 1.25 else
160     set compat="$compat timegm.o"
161 greg 1.1 endif
162 greg 1.6 set arch=other
163 greg 1.1 breaksw
164     default:
165     echo "Illegal choice\!"
166     echo "Installation aborted."
167     exit 1
168     breaksw
169     endsw
170     source installib
171     sed 's/[ ]*$//' > $rmake << _EOF_
172     #!/bin/sh
173     exec make "SPECIAL=$special" \
174     "OPT=$opt" \
175     "MACH=$mach" \
176     ARCH=$arch "COMPAT=$compat" \
177     INSTDIR=$idir \
178     LIBDIR=$ldir \
179 schorsch 1.9 ESUFFIX=$esuffix \
180 greg 1.1 $extras "\$@" -f Rmakefile
181     _EOF_
182     chmod 755 $rmake
183     chmod 644 src/*/Rmakefile src/rt/devtable.c
184     gotrmake:
185     echo "Current rmake command is:"
186     cat $rmake
187     echo -n "Do you want to change it? "
188     set ans="$<"
189     if ( "$ans" =~ [yY]* ) then
190     cp $rmake /tmp/rmake$$
191     $EDITOR $rmake
192     if ( `cat $rmake /tmp/rmake$$ | grep OPT= | uniq | wc -l` == 2 ) set newrmake
193     rm -f /tmp/rmake$$
194     endif
195     if ( ! -d src/lib ) then
196     mkdir src/lib
197     endif
198     if ( $?newrmake ) then
199     echo 'New rmake command -- running "makeall clean"...'
200     csh -f $0 clean
201     endif
202     cd src
203     echo "Making programs..."
204     set errs=0
205     foreach i ( $srcdirs )
206     pushd $i
207     echo "In directory $i..."
208     $rmake -k $*
209     @ errs += $status
210     popd
211     end
212     if ( $errs ) then
213     echo "There were some errors."
214     else
215     echo "Done."
216     endif
217     cd ..
218 greg 1.10 if (! $inpath ) then
219     echo ""
220     echo "Add $idir to the beginning of your execution path:"
221     echo 'For C-shell users, put the following into ~/.cshrc'
222     echo " set path=( $idir "'$path )'
223 greg 1.19 echo 'For Bourne shell users, put the following into $HOME/.profile'
224 greg 1.10 echo " PATH=$idir"':$PATH'
225     echo " export PATH"
226     endif
227 greg 1.1 else
228     cd src
229     foreach i ( $srcdirs )
230     pushd $i
231     echo "In directory $i..."
232     make -f Rmakefile $*
233     popd
234     end
235     cd ..
236     foreach i ( $* )
237     if ( "$i" == clean ) then
238     echo "Removing library archives..."
239 greg 1.17 rm -f src/lib/*.{a,o,la}
240 greg 1.1 endif
241     end
242 greg 1.10 echo "Done."
243     endif
244 greg 1.1 exit 0
