| 1 |
#!/bin/csh -f
| 2 |
# RCSid $Id: makeall,v 1.28 2012/06/29 16:18:02 greg Exp $
| 3 |
| 4 |
# Make all the Radiance programs
| 5 |
| 6 |
if ( $#argv < 1 ) then
| 7 |
echo "Usage: makeall install [clean] [make options]"
| 8 |
echo " or: makeall clean"
| 9 |
echo " or: makeall library"
| 10 |
exit 1
| 11 |
endif
| 12 |
if ( "$1" == library ) then
| 13 |
source installib
| 14 |
cp -f src/*/*.{cal,tab,hex,dat} $ldir
| 15 |
echo ""
| 16 |
echo "Set the environment variable RAYPATH=.:$ldir"
| 17 |
echo 'For C-shell users, put the following into ~/.cshrc'
| 18 |
echo " setenv RAYPATH .:$ldir"
| 19 |
echo 'For Bourne shell users, put the following into $HOME/.profile'
| 20 |
echo " RAYPATH=.:$ldir"
| 21 |
echo " export RAYPATH"
| 22 |
echo ""
| 23 |
exit 0
| 24 |
endif
| 25 |
set srcdirs=( common rt meta cv gen ot px hd util cal )
| 26 |
if ( "$1" == install ) then
| 27 |
cat << _EOF_
| 28 |
| 29 |
`cat src/rt/VERSION` INSTALLATION
| 30 |
| 31 |
This script rebuilds all of the Radiance programs and installs
| 32 |
them on your system. You should read the file README before running
| 33 |
this script. You can type ^C (followed by return) at any time to abort.
| 34 |
| 35 |
You must first answer the following questions.
| 36 |
| 37 |
_EOF_
| 38 |
if ( ! $?EDITOR ) then
| 39 |
echo -n "What is your preferred editor [vi]? "
| 40 |
set ans="$<"
| 41 |
if ( "$ans" != "" ) then
| 42 |
setenv EDITOR "$ans"
| 43 |
else
| 44 |
setenv EDITOR vi
| 45 |
endif
| 46 |
endif
| 47 |
again1:
| 48 |
echo -n "Where do you want the executables [/usr/local/bin]? "
| 49 |
set idir=$<
| 50 |
(echo $idir) >/dev/null
| 51 |
if ( $status ) then
| 52 |
goto again1
| 53 |
endif
| 54 |
set idir=$idir
| 55 |
if ( "$idir" == "" ) then
| 56 |
set idir=/usr/local/bin
| 57 |
else if ( "$idir" !~ /* ) then
| 58 |
echo "Directory must be relative to root, please reenter"
| 59 |
goto again1
| 60 |
endif
| 61 |
if ( ! -d $idir ) then
| 62 |
mkdir $idir
| 63 |
if ( $status ) then
| 64 |
echo "Cannot create directory, please reenter"
| 65 |
goto again1
| 66 |
endif
| 67 |
endif
| 68 |
set inpath=0
| 69 |
foreach i ( $path )
| 70 |
if ( "$i" == "$idir" ) then
| 71 |
set inpath=1
| 72 |
break
| 73 |
endif
| 74 |
end
| 75 |
set rmake=$idir/rmake
| 76 |
if ( "`ls -tL $rmake $0 |& head -1`" == $rmake ) then
| 77 |
goto gotrmake
| 78 |
endif
| 79 |
set newrmake
| 80 |
more License.txt
| 81 |
echo -n "Do you understand and accept the terms of this agreement [n]? "
| 82 |
set ans="$<"
| 83 |
if ( "$ans" !~ [yY]* ) exit
| 84 |
set special=
| 85 |
set arch=
| 86 |
set opt=
| 87 |
set mach=
| 88 |
set compat=
| 89 |
set extras=
| 90 |
set esuffix=
| 91 |
cat << _EOF_
| 92 |
| 93 |
Please select your system type from the following list:
| 94 |
| 95 |
1) Sun Solaris
| 96 |
2) Linux
| 97 |
3) MacOS X
| 98 |
4) FreeBSD
| 99 |
5) Cygwin
| 100 |
6) Other
| 101 |
| 102 |
_EOF_
| 103 |
echo -n "Choice? "
| 104 |
set arch="$<"
| 105 |
switch ("$arch")
| 106 |
case 1: # SPARC Station
| 107 |
set arch=sun
| 108 |
set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO"
| 109 |
set opt="-O"
| 110 |
set compat="strcmp.o timegm.o"
| 111 |
breaksw
| 112 |
case 2: # Linux
| 113 |
set mach="-Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO"
| 114 |
set opt="-O2"
| 115 |
set arch=IBMPC
| 116 |
set compat="strlcpy.o"
| 117 |
set extras=CC=gcc
| 118 |
breaksw
| 119 |
case 3: # MacOS X
| 120 |
set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib"
| 121 |
set opt="-O2"
| 122 |
set arch=Intel
| 123 |
set extras="CC=cc CONFIGURE_ARCH=i386"
| 124 |
set special="ogl"
| 125 |
breaksw
| 126 |
case 4: # FreeBSD
| 127 |
| 128 |
set opt="-O"
| 129 |
set compat="erf.o"
| 130 |
set extras='CC=cc MLIB="-lcompat -lm"'
| 131 |
set arch=IBMPC
| 132 |
breaksw
| 133 |
case 5: # Cygwin
| 134 |
set mach="-Dfreebsd -L/usr/lib -L/usr/X11R6/lib -I/usr/include/X11 -I/usr/X11R6/include -DNOSTEREO"
| 135 |
set opt="-O2"
| 136 |
set arch=IBMPC
| 137 |
set compat="erf.o strlcpy.o"
| 138 |
set extras="CC=gcc"
| 139 |
set special="ogl"
| 140 |
set esuffix=".exe"
| 141 |
breaksw
| 142 |
case 6: # Other
| 143 |
set opt="-O"
| 144 |
set compat="erf.o strcmp.o strlcpy.o"
| 145 |
echo -n "Are you using the GNU C compiler [n]? "
| 146 |
if ( "$<" =~ [yY]* ) then
| 147 |
set extras="CC=gcc"
| 148 |
else
| 149 |
set compat="$compat timegm.o"
| 150 |
endif
| 151 |
set arch=other
| 152 |
breaksw
| 153 |
default:
| 154 |
echo "Illegal choice\!"
| 155 |
echo "Installation aborted."
| 156 |
exit 1
| 157 |
breaksw
| 158 |
endsw
| 159 |
source installib
| 160 |
sed 's/[ ]*$//' > $rmake << _EOF_
| 161 |
#!/bin/sh
| 162 |
exec make "SPECIAL=$special" \
| 163 |
"OPT=$opt" \
| 164 |
"MACH=$mach" \
| 165 |
ARCH=$arch "COMPAT=$compat" \
| 166 |
INSTDIR=$idir \
| 167 |
LIBDIR=$ldir \
| 168 |
ESUFFIX=$esuffix \
| 169 |
$extras "\$@" -f Rmakefile
| 170 |
_EOF_
| 171 |
chmod 755 $rmake
| 172 |
chmod 644 src/*/Rmakefile src/rt/devtable.c
| 173 |
gotrmake:
| 174 |
echo "Current rmake command is:"
| 175 |
cat $rmake
| 176 |
echo -n "Do you want to change it? "
| 177 |
set ans="$<"
| 178 |
if ( "$ans" =~ [yY]* ) then
| 179 |
cp $rmake /tmp/rmake$$
| 180 |
$EDITOR $rmake
| 181 |
if ( `cat $rmake /tmp/rmake$$ | grep OPT= | uniq | wc -l` == 2 ) set newrmake
| 182 |
rm -f /tmp/rmake$$
| 183 |
endif
| 184 |
if ( ! -d src/lib ) then
| 185 |
mkdir src/lib
| 186 |
endif
| 187 |
if ( $?newrmake ) then
| 188 |
echo 'New rmake command -- running "makeall clean"...'
| 189 |
csh -f $0 clean
| 190 |
endif
| 191 |
cd src
| 192 |
echo "Making programs..."
| 193 |
set errs=0
| 194 |
foreach i ( $srcdirs )
| 195 |
pushd $i
| 196 |
echo "In directory $i..."
| 197 |
$rmake -k $*
| 198 |
@ errs += $status
| 199 |
popd
| 200 |
end
| 201 |
if ( $errs ) then
| 202 |
echo "There were some errors."
| 203 |
else
| 204 |
echo "Done."
| 205 |
endif
| 206 |
cd ..
| 207 |
if (! $inpath ) then
| 208 |
echo ""
| 209 |
echo "Add $idir to the beginning of your execution path:"
| 210 |
| 211 |
echo " set path=( $idir "'$path )'
| 212 |
| 213 |
echo " PATH=$idir"':$PATH'
| 214 |
echo " export PATH"
| 215 |
endif
| 216 |
else
| 217 |
cd src
| 218 |
| 219 |
pushd $i
| 220 |
| 221 |
make -f Rmakefile $*
| 222 |
popd
| 223 |
end
| 224 |
cd ..
| 225 |
foreach i ( $* )
| 226 |
if ( "$i" == clean ) then
| 227 |
echo "Removing library archives..."
| 228 |
rm -f src/lib/*.{a,o,la}
| 229 |
endif
| 230 |
end
| 231 |
echo "Done."
| 232 |
endif
| 233 |
exit 0
