root/Development/ray/makeall
Revision: 1.9
Committed: Sat Aug 30 08:22:47 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 1.8: +28 -16 lines
Added Cygwin build configuration (not fully functional yet).
1 #!/bin/csh -f
2 # RCSid $Id: makeall,v 1.8 2003/07/17 15:31:26 greg Exp $
3 #
4 # Make all the Radiance programs
5 #
6 if ( $#argv < 1 ) then
7 echo "Usage: makeall install [clean] [make options]"
8 echo " or: makeall clean"
9 echo " or: makeall library"
10 exit 1
11 endif
12 if ( "$1" == library ) then
13 source installib
14 cp -f src/*/*.{cal,tab,hex} $ldir
15 echo ""
16 echo "Set the environment variable RAYPATH=.:$ldir"
17 echo 'For C-shell users, put the following into ~/.cshrc'
18 echo " setenv RAYPATH .:$ldir"
19 echo 'For Bourne shell users, put the following into $HOME/profile'
20 echo " RAYPATH=.:$ldir"
21 echo " export RAYPATH"
22 echo ""
23 exit 0
24 endif
25 set srcdirs=( common meta cv gen ot rt px hd util cal )
26 if ( "$1" == install ) then
27 cat << _EOF_
28
29 `cat src/rt/VERSION` INSTALLATION
30
31 This script rebuilds all of the Radiance programs and installs
32 them on your system. You should read the file README before running
33 this script. You can type ^C (followed by return) at any time to abort.
34
35 You must first answer the following questions.
36
37 _EOF_
38 if ( ! $?EDITOR ) then
39 echo -n "What is your preferred editor [vi]? "
40 set ans="$<"
41 if ( "$ans" != "" ) then
42 setenv EDITOR "$ans"
43 else
44 setenv EDITOR vi
45 endif
46 endif
47 again1:
48 echo -n "Where do you want the executables [/usr/local/bin]? "
49 set idir=$<
50 (echo $idir) >/dev/null
51 if ( $status ) then
52 goto again1
53 endif
54 set idir=$idir
55 if ( "$idir" == "" ) then
56 set idir=/usr/local/bin
57 else if ( "$idir" !~ /* ) then
58 echo "Directory must be relative to root, please reenter"
59 goto again1
60 endif
61 if ( ! -d $idir ) then
62 mkdir $idir
63 if ( $status ) then
64 echo "Cannot create directory, please reenter"
65 goto again1
66 endif
67 endif
68 if ( ! -d $idir/dev ) then
69 mkdir $idir/dev
70 if ( $status ) then
71 echo "Cannot create subdirectory, please reenter"
72 goto again1
73 endif
74 endif
75 set rmake=$idir/rmake
76 if ( "`ls -tL $rmake $0 |& head -1`" == $rmake ) then
77 goto gotrmake
78 endif
79 set newrmake
80 goto skiplicense
81 cat << _EOF_
82
83 RADIANCE LICENSE AGREEMENT
84
85 Radiance is a registered copyright of The Regents of the University of
86 California ("The Regents"). The Regents grant to you a nonexclusive,
87 nontransferable license ("License") to use Radiance source code without
88 fee. You may not sell or distribute Radiance to others without the
89 prior express written permission of The Regents. You may compile and
90 use this software on any machines to which you have personal access,
91 and may share its use with others who have access to the same machines.
92
93 NEITHER THE UNITED STATES NOR THE UNITED STATES DEPARTMENT OF ENERGY, NOR ANY
94 OF THEIR EMPLOYEES, MAKES ANY WARRANTY, EXPRESS OR IMPLIED, OR ASSUMES ANY
95 LEGAL LIABILITY OR RESPONSIBILITY FOR THE ACCURACY, COMPLETENESS, OR USEFULNESS
96 OF ANY INFORMATION, APPARATUS, PRODUCT, OR PROCESS DISCLOSED, OR REPRESENTS
97 THAT ITS USE WOULD NOT INFRINGE PRIVATELY OWNED RIGHTS. By downloading, using
98 or copying this software, you agree to abide by the intellectual property laws
99 and all other applicable laws of the United States, and by the terms of this
100 License Agreement. Ownership of the software shall remain solely in The
101 Regents. The Regents shall have the right to terminate this License
102 immediately by written notice upon your breach of, or noncompliance with, any
103 of its terms. You shall be liable for any infringement or damages resulting
104 from your failure to abide by the terms of this License Agreement.
105
106 _EOF_
107 echo -n "Do you understand and accept the terms of this agreement [n]? "
108 set ans="$<"
109 if ( "$ans" !~ [yY]* ) exit
110 echo -n "Are you a new Radiance user or with a new address [y]? "
111 set ans="$<"
112 if ( "$ans" !~ [nN]* ) then
113 csh -f newuser
114 else
115 echo `cat src/rt/VERSION` compiled by `whoami` | mail [email protected]
116 endif
117 skiplicense:
118 set special=
119 set arch=
120 set opt=
121 set mach=
122 set compat=
123 set extras=
124 set esuffix=
125 cat << _EOF_
126
127 Please select your system type from the following list:
128
129 1) Sun Solaris
130 2) HP workstation
131 3) Silicon Graphics
132 4) AIX (RS/6000)
133 5) BSDI BSD/386
134 6) Linux
135 7) MacOS X
136 8) FreeBSD
137 9) Cygwin
138 10) Other
139
140 _EOF_
141 echo -n "Choice? "
142 set arch="$<"
143 switch ("$arch")
144 case 1: # SPARC Station
145 set arch=sun
146 set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO"
147 set opt="-O -DSPEED=80"
148 set compat="bmalloc.o strcmp.o getpagesize.o"
149 breaksw
150 case 2: # HP workstation
151 set mach=""
152 set opt="-O -DSPEED=80 -Aa -D_HPUX_SOURCE"
153 set compat="bmalloc.o getpagesize.o strcmp.o"
154 set arch=hpux
155 breaksw
156 case 3: # Silicon Graphics
157 set arch=sgi
158 switch (`uname -r`)
159 case 3.*:
160 set mach="-noprototypes"
161 set opt="-O -DSPEED=80"
162 set special="sgi"
163 set compat="malloc.o strcmp.o"
164 breaksw
165 case 4.*:
166 set mach=""
167 set opt="-O2 -DSPEED=100"
168 set compat="malloc.o strcmp.o"
169 set extras='"MLIB=-lfastm -lm"'
170 breaksw
171 default: # 5.x or later
172 ln -s `which wish` $idir/wish4.0
173 set path=($idir $path)
174 set mach="-w"
175 set opt="-O2 -DSPEED=200"
176 set special="ogl"
177 set compat="bmalloc.o strcmp.o"
178 breaksw
179 endsw
180 breaksw
181 case 4: # AIX
182 set opt="-O"
183 set compat="bmalloc.o erf.o strcmp.o"
184 set arch=PowerPC
185 breaksw
186 case 5: # BSDI BSD/386
187 set mach="-DBSD -L/usr/X11/lib -I/usr/X11/include"
188 set opt="-O -DSPEED=100"
189 set arch=IBMPC
190 set compat="malloc.o erf.o strcmp.o"
191 breaksw
192 case 6: # Linux
193 set mach="-Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO"
194 set opt="-O2 -DSPEED=200"
195 set arch=IBMPC
196 set compat="bmalloc.o erf.o getpagesize.o"
197 set extras=CC=gcc
198 breaksw
199 case 7: # MacOS X
200 set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib"
201 set opt="-O2 -DSPEED=200"
202 set arch=PowerPC
203 set compat="bmalloc.o"
204 set extras="CC=cc CONFIGURE_ARCH=powerpc"
205 set special="ogl"
206 breaksw
207 case 8: # FreeBSD
208 set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib"
209 set opt="-O -DSPEED=200"
210 set compat="bmalloc.o erf.o"
211 set extras="CC=cc"
212 set arch=IBMPC
213 breaksw
214 case 9: # Cygwin
215 set mach="-Dfreebsd -L/usr/lib -L/usr/X11R6/lib -I/usr/include/X11 -I/usr/X11R6/include -DNOSTEREO"
216 set opt="-O2 -DSPEED=200"
217 set arch=IBMPC
218 set compat="bmalloc.o erf.o getpagesize.o"
219 set extras="CC=gcc"
220 set special="ogl"
221 set esuffix=".exe"
222 breaksw
223 case 10: # Other
224 set opt="-O"
225 set compat="bmalloc.o erf.o strcmp.o"
226 echo -n "Are you using the GNU C compiler [n]? "
227 if ( "$<" =~ [yY]* ) then
228 set extras="CC=gcc"
229 endif
230 set arch=other
231 breaksw
232 default:
233 echo "Illegal choice\!"
234 echo "Installation aborted."
235 exit 1
236 breaksw
237 endsw
238 source installib
239 sed 's/[ ]*$//' > $rmake << _EOF_
240 #!/bin/sh
241 exec make "SPECIAL=$special" \
242 "OPT=$opt" \
243 "MACH=$mach" \
244 ARCH=$arch "COMPAT=$compat" \
245 INSTDIR=$idir \
246 LIBDIR=$ldir \
247 ESUFFIX=$esuffix \
248 $extras "\$@" -f Rmakefile
249 _EOF_
250 chmod 755 $rmake
251 chmod 644 src/*/Rmakefile src/rt/devtable.c
252 gotrmake:
253 echo "Current rmake command is:"
254 cat $rmake
255 echo -n "Do you want to change it? "
256 set ans="$<"
257 if ( "$ans" =~ [yY]* ) then
258 cp $rmake /tmp/rmake$$
259 $EDITOR $rmake
260 if ( `cat $rmake /tmp/rmake$$ | grep OPT= | uniq | wc -l` == 2 ) set newrmake
261 rm -f /tmp/rmake$$
262 endif
263 if ( ! -d src/lib ) then
264 mkdir src/lib
265 endif
266 if ( $?newrmake ) then
267 echo 'New rmake command -- running "makeall clean"...'
268 csh -f $0 clean
269 endif
270 cd src
271 echo "Making programs..."
272 set errs=0
273 foreach i ( $srcdirs )
274 pushd $i
275 echo "In directory $i..."
276 $rmake -k $*
277 @ errs += $status
278 popd
279 end
280 if ( $errs ) then
281 echo "There were some errors."
282 else
283 echo "Done."
284 endif
285 cd ..
286 if (! -d /usr/tmp) then
287 ln -s /tmp /usr/tmp
288 if ($status) then
289 echo ""
290 echo "IMPORTANT: Execute 'sudo ln -s /tmp /usr/tmp'"
291 echo ""
292 endif
293 endif
294 else
295 cd src
296 foreach i ( $srcdirs )
297 pushd $i
298 echo "In directory $i..."
299 make -f Rmakefile $*
300 popd
301 end
302 echo "Done."
303 cd ..
304 endif
305 foreach i ( $* )
306 if ( "$i" == clean ) then
307 echo "Removing library archives..."
308 rm -f src/lib/*.[ao]
309 endif
310 end
311 exit 0
