--- ray/makeall 2005/09/19 02:23:58 1.20 +++ ray/makeall 2012/04/25 22:21:06 1.27 @@ -1,5 +1,5 @@ #!/bin/csh -f -# RCSid $Id: makeall,v 1.20 2005/09/19 02:23:58 greg Exp $ +# RCSid $Id: makeall,v 1.27 2012/04/25 22:21:06 greg Exp $ # # Make all the Radiance programs # @@ -65,13 +65,6 @@ if ( ! -d $idir ) then goto again1 endif endif -if ( ! -d $idir/dev ) then - mkdir $idir/dev - if ( $status ) then - echo "Cannot create subdirectory, please reenter" - goto again1 - endif -endif set inpath=0 foreach i ( $path ) if ( "$i" == "$idir" ) then @@ -84,7 +77,7 @@ if ( "`ls -tL $rmake $0 |& head -1`" == $rmake ) then goto gotrmake endif set newrmake -more src/common/copyright.h +more License.txt echo -n "Do you understand and accept the terms of this agreement [n]? " set ans="$<" if ( "$ans" !~ [yY]* ) exit @@ -100,15 +93,11 @@ cat << _EOF_ Please select your system type from the following list: 1) Sun Solaris - 2) HP workstation - 3) Silicon Graphics - 4) AIX (RS/6000) - 5) BSDI BSD/386 - 6) Linux - 7) MacOS X - 8) FreeBSD - 9) Cygwin - 10) Other + 2) Linux + 3) MacOS X + 4) FreeBSD + 5) Cygwin + 6) Other _EOF_ echo -n "Choice? " @@ -118,72 +107,30 @@ case 1: # SPARC Station set arch=sun set mach="-I/usr/openwin/include -L/usr/openwin/lib -DNOSTEREO" set opt="-O" - set compat="strcmp.o" + set compat="strcmp.o timegm.o" breaksw -case 2: # HP workstation - set mach="" - set opt="-O -Aa -D_HPUX_SOURCE" - set compat="strcmp.o" - set arch=hpux - breaksw -case 3: # Silicon Graphics - set arch=sgi - switch (`uname -r`) - case 3.*: - set mach="-noprototypes" - set opt="-O" - set special="sgi" - set compat="strcmp.o" - breaksw - case 4.*: - set mach="" - set opt="-O2" - set compat="strcmp.o" - set extras='"MLIB=-lfastm -lm"' - breaksw - default: # 5.x or later - ln -s `which wish` $idir/wish4.0 - set path=($idir $path) - set mach="-w" - set opt="-O2" - set special="ogl" - set compat="strcmp.o" - breaksw - endsw - breaksw -case 4: # AIX - set opt="-O" - set compat="erf.o strcmp.o" - set arch=PowerPC - breaksw -case 5: # BSDI BSD/386 - set mach="-DBSD -L/usr/X11/lib -I/usr/X11/include" - set opt="-O" - set arch=IBMPC - set compat="erf.o strcmp.o" - breaksw -case 6: # Linux +case 2: # Linux set mach="-Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO" set opt="-O2" set arch=IBMPC set compat="erf.o" set extras=CC=gcc breaksw -case 7: # MacOS X +case 3: # MacOS X set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib" set opt="-O2" - set arch=PowerPC - set extras="CC=cc CONFIGURE_ARCH=powerpc" + set arch=Intel + set extras="CC=cc CONFIGURE_ARCH=i386" set special="ogl" breaksw -case 8: # FreeBSD +case 4: # FreeBSD set mach="-DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib" set opt="-O" set compat="erf.o" set extras='CC=cc MLIB="-lcompat -lm"' set arch=IBMPC breaksw -case 9: # Cygwin +case 5: # Cygwin set mach="-Dfreebsd -L/usr/lib -L/usr/X11R6/lib -I/usr/include/X11 -I/usr/X11R6/include -DNOSTEREO" set opt="-O2" set arch=IBMPC @@ -192,12 +139,14 @@ case 9: # Cygwin set special="ogl" set esuffix=".exe" breaksw -case 10: # Other +case 6: # Other set opt="-O" set compat="erf.o strcmp.o" echo -n "Are you using the GNU C compiler [n]? " if ( "$<" =~ [yY]* ) then set extras="CC=gcc" + else + set compat="$compat timegm.o" endif set arch=other breaksw
