root/Development/ray/makeall
Thu Dec 11 23:42:54 2003 UTC (21 years, 11 months ago) by greg
Changes since 1.10: +2 -36 lines
Diff to previous 1.10
Changed to using new license text from src/common/copyright.h
Revision 1.10 - (view) (download) (annotate) - [selected]
Tue Nov 25 18:23:11 2003 UTC (22 years ago) by greg
Changes since 1.9: +19 -4 lines
Diff to previous 1.9
Added comment about setting path variable to end of install script
Sat Aug 30 08:22:47 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 1.8: +28 -16 lines
Diff to previous 1.8 , to selected 1.10
Added Cygwin build configuration (not fully functional yet).
Thu Jul 17 15:31:26 2003 UTC (22 years, 4 months ago) by greg
Changes since 1.7: +2 -4 lines
Diff to previous 1.7 , to selected 1.10
Added installation of source *.cal files to "makeall library"
Sat Jul 12 08:38:44 2003 UTC (22 years, 4 months ago) by schorsch
Diff to previous 1.6 , to selected 1.10
Large file support on Linux, suggested by Randolph Fritz.
Thu May 29 17:46:35 2003 UTC (22 years, 6 months ago) by greg
Diff to previous 1.5 , to selected 1.10
Attempted fix to AIX compile problems
Thu May 15 05:13:35 2003 UTC (22 years, 6 months ago) by greg
Changes since 1.4: +1 -31 lines
Diff to previous 1.4 , to selected 1.10
Tue Apr 29 15:27:49 2003 UTC (22 years, 7 months ago) by greg
Changes since 1.3: +9 -13 lines
Diff to previous 1.3 , to selected 1.10
Took "ogl" special compile away for Solaris, which doesn't seem to support it
Thu Mar 27 04:16:33 2003 UTC (22 years, 8 months ago) by greg
Diff to previous 1.2 , to selected 1.10
Portability fixes immediately following 3.5 release
Fri Feb 28 20:06:51 2003 UTC (22 years, 9 months ago) by greg
Diff to previous 1.1 , to selected 1.10
Added missing installib script required by makeall
Sat Feb 22 02:07:20 2003 UTC (22 years, 9 months ago) by greg
Diff to selected 1.10
