root/radiance/ray/makeall
Wed Feb 16 18:56:32 2022 UTC (2 years, 3 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 1.30: +2 -2 lines
Diff to previous 1.30 , to selected 1.13
test: Added test/cv to set of test directories
Fri Sep 11 20:38:46 2020 UTC (3 years, 8 months ago) by greg
Changes since 1.29: +19 -1 lines
Diff to previous 1.29 , to selected 1.13
chore(makeall): Added "makeall test" to run unit tests and report success
Wed May 30 14:14:55 2018 UTC (5 years, 11 months ago) by greg
CVS Tags: rad5R2, rad5R3
Changes since 1.28: +4 -4 lines
Diff to previous 1.28 , to selected 1.13
Avoid declaration complaints in OS X
Fri Jun 29 16:18:02 2012 UTC (11 years, 10 months ago) by greg
Diff to previous 1.27 , to selected 1.13
Added suffix to copy Perez files in "makeall library"
Wed Apr 25 22:21:06 2012 UTC (12 years ago) by greg
Changes since 1.26: +1 -8 lines
Diff to previous 1.26 , to selected 1.13
Tue Oct 25 22:53:14 2011 UTC (12 years, 7 months ago) by greg
Changes since 1.25: +2 -2 lines
Diff to previous 1.25 , to selected 1.13
Added files needed by cmake
Mon Nov 29 17:22:44 2010 UTC (13 years, 5 months ago) by greg
Changes since 1.24: +4 -2 lines
Diff to previous 1.24 , to selected 1.13
Modifications for Solaris
Sat Oct 31 22:29:06 2009 UTC (14 years, 6 months ago) by greg
Changes since 1.23: +13 -61 lines
Diff to previous 1.23 , to selected 1.13
Removed outdated operating systems and updated OS X entry
Thu Apr 17 14:58:57 2008 UTC (16 years, 1 month ago) by greg
Changes since 1.22: +3 -1 lines
Diff to previous 1.22 , to selected 1.13
Added fix for OpenGL link error under Leopard (thanks to J. Mardaljevic)
Sun Nov 5 01:51:16 2006 UTC (17 years, 6 months ago) by greg
Diff to previous 1.21 , to selected 1.13
Removed -Dfseeko=fseek from Linux MACH= setting
Wed Sep 21 17:17:23 2005 UTC (18 years, 8 months ago) by greg
Changes since 1.20: +2 -2 lines
Diff to previous 1.20 , to selected 1.13
Mon Sep 19 02:23:58 2005 UTC (18 years, 8 months ago) by greg
Changes since 1.19: +11 -11 lines
Diff to previous 1.19 , to selected 1.13
Tue Aug 9 21:21:14 2005 UTC (18 years, 9 months ago) by greg
CVS Tags: rad3R7P2
Changes since 1.18: +3 -3 lines
Diff to previous 1.18 , to selected 1.13
Fixed instructions regarding Bourne shell
Tue Jul 26 15:33:13 2005 UTC (18 years, 10 months ago) by greg
CVS Tags: rad3R7P1
Diff to previous 1.17 , to selected 1.13
Tue Jul 26 01:20:36 2005 UTC (18 years, 10 months ago) by greg
Diff to previous 1.16 , to selected 1.13
Fixed library removal during clean
Sat May 7 18:57:43 2005 UTC (19 years ago) by greg
Changes since 1.15: +2 -2 lines
Diff to previous 1.15 , to selected 1.13
Fixed build problem related to programs using raycalls.a (mksource)
Wed Feb 2 00:09:13 2005 UTC (19 years, 3 months ago) by greg
Changes since 1.14: +12 -13 lines
Diff to previous 1.14 , to selected 1.13
Wed Feb 2 00:05:20 2005 UTC (19 years, 3 months ago) by schorsch
Changes since 1.13: +4 -4 lines
Diff to previous 1.13
Changed all of malloc.o to bmalloc.o (could make that a regular compile now).
Revision 1.13 - (view) (download) (annotate) - [selected]
Tue Feb 1 16:05:38 2005 UTC (19 years, 3 months ago) by greg
Diff to previous 1.12
Removed mention of retired getpagesize.c compatibility module
Sat Oct 30 04:59:40 2004 UTC (19 years, 6 months ago) by greg
Changes since 1.11: +1 -8 lines
Diff to previous 1.11 , to selected 1.13
Thu Dec 11 23:42:54 2003 UTC (20 years, 5 months ago) by greg
Changes since 1.10: +2 -36 lines
Diff to previous 1.10 , to selected 1.13
Changed to using new license text from src/common/copyright.h
Tue Nov 25 18:23:11 2003 UTC (20 years, 6 months ago) by greg
Changes since 1.9: +19 -4 lines
Diff to previous 1.9 , to selected 1.13
Added comment about setting path variable to end of install script
Sat Aug 30 08:22:47 2003 UTC (20 years, 8 months ago) by schorsch
Changes since 1.8: +28 -16 lines
Diff to previous 1.8 , to selected 1.13
Added Cygwin build configuration (not fully functional yet).
Thu Jul 17 15:31:26 2003 UTC (20 years, 10 months ago) by greg
Changes since 1.7: +2 -4 lines
Diff to previous 1.7 , to selected 1.13
Added installation of source *.cal files to "makeall library"
Sat Jul 12 08:38:44 2003 UTC (20 years, 10 months ago) by schorsch
Diff to previous 1.6 , to selected 1.13
Large file support on Linux, suggested by Randolph Fritz.
Thu May 29 17:46:35 2003 UTC (20 years, 11 months ago) by greg
Diff to previous 1.5 , to selected 1.13
Attempted fix to AIX compile problems
Changes since 1.4: +1 -31 lines
Diff to previous 1.4 , to selected 1.13
Tue Apr 29 15:27:49 2003 UTC (21 years ago) by greg
Changes since 1.3: +9 -13 lines
Diff to previous 1.3 , to selected 1.13
Took "ogl" special compile away for Solaris, which doesn't seem to support it
Thu Mar 27 04:16:33 2003 UTC (21 years, 2 months ago) by greg
Diff to previous 1.2 , to selected 1.13
Portability fixes immediately following 3.5 release
Fri Feb 28 20:06:51 2003 UTC (21 years, 2 months ago) by greg
Diff to previous 1.1 , to selected 1.13
Added missing installib script required by makeall
Sat Feb 22 02:07:20 2003 UTC (21 years, 3 months ago) by greg
Diff to selected 1.13
