root/radiance/ray/lib/glazing.cal
Revision: 1.2
Committed: Tue Mar 18 17:30:17 2003 UTC (22 years, 1 month ago) by greg
Changes since 1.1: +0 -0 lines
State: FILE REMOVED
Decided to move ray/lib directory into non-CVS distribution
# User Rev Content
1 greg 1.1 {
2     The following calculation uses the BRTDfunc type to reproduce the
3     calculation used by LBL's Window 4 program for the transmittance
4     and reflectance of coated glazings. This calculation is based
5     on fits for the angular dependence for clear and bronze-coated
6     glazing, and is not terribly accurate.
7
8     5/20/93 Greg Ward
9
10     Arguments used for this material should look like:
11
12     mod BRTDfunc my_glazing
13     10 rrho grho brho
14     rtau gtau btau
15     0 0 0
16     glazing.cal
17     0
18     18 0 0 0
19     0 0 0
20     0 0 0
21     FRRHO FGRHO FBRHO
22     BRRHO BGRHO BBRHO
23     RTAU GTAU BTAU
24
25     where:
26     FRRHO FGRHO FBRHO is front normal spectral reflectance
27     BRRHO BGRHO BBRHO is back normal spectral reflectance
28     RTAU GTAU BTAU is normal spectral transmittance
29     }
30     { get normal reflectance }
31     rbase = if(Rdot,10,13); { different front and back }
32     Rred = arg(rbase)*CrP;
33     Rgrn = arg(rbase+1)*CgP;
34     Rblu = arg(rbase+2)*CbP;
35     { get normal transmittance }
36     Tred = arg(16)*CrP;
37     Tgrn = arg(17)*CgP;
38     Tblu = arg(18)*CbP;
39     { reflectance coefficients }
40     Rclear = .999 + RdotP*(-.563 + RdotP*(2.043 + RdotP*(-2.532 + RdotP*1.054)));
41     Rbronze = .997 + RdotP*(-1.868 + RdotP*(6.513 + RdotP*(-7.862 + RdotP*3.225)));
42
43     { transmittance coefficients }
44     Tclear = -.0015 + RdotP*(3.355 + RdotP*(-3.840 + RdotP*(1.460 + RdotP*.0288)));
45     Tbronze = -.002 + RdotP*(2.813 + RdotP*(-2.341 + RdotP*(-.05725 + RdotP*.599)));
46
47     Tcutoff : .645; { transmittance cutoff constant }
48     { returned spectral reflectance }
49     rrho = Rred*if(Tred-Tcutoff, Rclear, Rbronze);
50     grho = Rgrn*if(Tgrn-Tcutoff, Rclear, Rbronze);
51     brho = Rblu*if(Tblu-Tcutoff, Rclear, Rbronze);
52     { returned spectral transmittance }
53     rtau = Tred*if(Tred-Tcutoff, Tclear, Tbronze);
54     gtau = Tgrn*if(Tgrn-Tcutoff, Tclear, Tbronze);
55     btau = Tblu*if(Tblu-Tcutoff, Tclear, Tbronze);
