root/Development/ray/lib/glazing.cal
Revision: 1.2
Committed: Tue Mar 18 17:30:17 2003 UTC (22 years, 6 months ago) by greg
Changes since 1.1: +0 -0 lines
State: FILE REMOVED
Decided to move ray/lib directory into non-CVS distribution
1 {
2 The following calculation uses the BRTDfunc type to reproduce the
3 calculation used by LBL's Window 4 program for the transmittance
4 and reflectance of coated glazings. This calculation is based
5 on fits for the angular dependence for clear and bronze-coated
6 glazing, and is not terribly accurate.
7
8 5/20/93 Greg Ward
9
10 Arguments used for this material should look like:
11
12 mod BRTDfunc my_glazing
13 10 rrho grho brho
14 rtau gtau btau
15 0 0 0
16 glazing.cal
17 0
18 18 0 0 0
19 0 0 0
20 0 0 0
21 FRRHO FGRHO FBRHO
22 BRRHO BGRHO BBRHO
23 RTAU GTAU BTAU
24
25 where:
26 FRRHO FGRHO FBRHO is front normal spectral reflectance
27 BRRHO BGRHO BBRHO is back normal spectral reflectance
28 RTAU GTAU BTAU is normal spectral transmittance
29 }
30 { get normal reflectance }
31 rbase = if(Rdot,10,13); { different front and back }
32 Rred = arg(rbase)*CrP;
33 Rgrn = arg(rbase+1)*CgP;
34 Rblu = arg(rbase+2)*CbP;
35 { get normal transmittance }
36 Tred = arg(16)*CrP;
37 Tgrn = arg(17)*CgP;
38 Tblu = arg(18)*CbP;
39 { reflectance coefficients }
40 Rclear = .999 + RdotP*(-.563 + RdotP*(2.043 + RdotP*(-2.532 + RdotP*1.054)));
41 Rbronze = .997 + RdotP*(-1.868 + RdotP*(6.513 + RdotP*(-7.862 + RdotP*3.225)));
42
43 { transmittance coefficients }
44 Tclear = -.0015 + RdotP*(3.355 + RdotP*(-3.840 + RdotP*(1.460 + RdotP*.0288)));
45 Tbronze = -.002 + RdotP*(2.813 + RdotP*(-2.341 + RdotP*(-.05725 + RdotP*.599)));
46
47 Tcutoff : .645; { transmittance cutoff constant }
48 { returned spectral reflectance }
49 rrho = Rred*if(Tred-Tcutoff, Rclear, Rbronze);
50 grho = Rgrn*if(Tgrn-Tcutoff, Rclear, Rbronze);
51 brho = Rblu*if(Tblu-Tcutoff, Rclear, Rbronze);
52 { returned spectral transmittance }
53 rtau = Tred*if(Tred-Tcutoff, Tclear, Tbronze);
54 gtau = Tgrn*if(Tgrn-Tcutoff, Tclear, Tbronze);
55 btau = Tblu*if(Tblu-Tcutoff, Tclear, Tbronze);
