root/Development/ray/lib/fprism.cal
Revision: 1.2
Committed: Tue Mar 18 17:30:17 2003 UTC (22 years, 7 months ago) by greg
Changes since 1.1: +0 -0 lines
State: FILE REMOVED
Decided to move ray/lib directory into non-CVS distribution
# User Rev Content
1 greg 1.1 { New functions for calculating light transmission through prisms.
2
3     R. Compagnon and F. Di Pasquale (Spring 1992)
4     LESO-PB
5     EPFL
6     CH-1015 LAUSANNE
7
8     G. Ward modified for new fprism.c 6/30/93
9     }
10
11     { function fprism(A1..A10) performs the calculations
12     A1: length a of the prism panel
13     A2: length b "
14     A3: length c "
15     A4: length d "
16     A5: indice of refraction of the prism material
17     A6: fraction of the incident ray under which the ray propagation inside
18     the prism is aborted (0<A6<1)
19     A7: indicates which face of the prism is covered by a metallic layer
20     1: face beta
21     2: face gamma
22     4: no face
23     A8: reflection factor of the metallic layer (0<=A8<=1)
24     A9: angle tolerance (in radians) for combining rays travelling nearly
25     in the same direction
26     A10: angle tolerance (in radians) for assuming that a ray is directed
27     toward a source
28
29     function fprism_val(a,b,c,d) is used to pick the necessary output values
30     calculated by fprism
31     a: selector for choosing which value we ask for:
32     0: X direction of the ray
33     1: Y "
34     2: Z "
35     3: transmission or reflection factor of the ray
36     b: selector for choosing which kind of ray we ask for:
37     -1: a reflected ray is expected
38     0: any ray (reflected or transmitted) is expected
39     1: a transmitted ray is expected
40     c: rank of the expected ray (1<=c)
41     }
42     tau1 = fprism_val(3,1,1);
43     dx1 = fprism_val(0,1,1);
44     dy1 = fprism_val(1,1,1);
45     dz1 = fprism_val(2,1,1);
46     tau2 = fprism_val(3,1,2);
47     dx2 = fprism_val(0,1,2);
48     dy2 = fprism_val(1,1,2);
49     dz2 = fprism_val(2,1,2);
