root/radiance/ray/lib/fprism.cal
Revision: 1.2
Committed: Tue Mar 18 17:30:17 2003 UTC (22 years, 1 month ago) by greg
Changes since 1.1: +0 -0 lines
State: FILE REMOVED
Error occurred while calculating annotation data.
Decided to move ray/lib directory into non-CVS distribution
1 { New functions for calculating light transmission through prisms.
2
3 R. Compagnon and F. Di Pasquale (Spring 1992)
4 LESO-PB
5 EPFL
6 CH-1015 LAUSANNE
7
8 G. Ward modified for new fprism.c 6/30/93
9 }
10
11 { function fprism(A1..A10) performs the calculations
12 A1: length a of the prism panel
13 A2: length b "
14 A3: length c "
15 A4: length d "
16 A5: indice of refraction of the prism material
17 A6: fraction of the incident ray under which the ray propagation inside
18 the prism is aborted (0<A6<1)
19 A7: indicates which face of the prism is covered by a metallic layer
20 1: face beta
21 2: face gamma
22 4: no face
23 A8: reflection factor of the metallic layer (0<=A8<=1)
24 A9: angle tolerance (in radians) for combining rays travelling nearly
25 in the same direction
26 A10: angle tolerance (in radians) for assuming that a ray is directed
27 toward a source
28
29 function fprism_val(a,b,c,d) is used to pick the necessary output values
30 calculated by fprism
31 a: selector for choosing which value we ask for:
32 0: X direction of the ray
33 1: Y "
34 2: Z "
35 3: transmission or reflection factor of the ray
36 b: selector for choosing which kind of ray we ask for:
37 -1: a reflected ray is expected
38 0: any ray (reflected or transmitted) is expected
39 1: a transmitted ray is expected
40 c: rank of the expected ray (1<=c)
41 }
42 tau1 = fprism_val(3,1,1);
43 dx1 = fprism_val(0,1,1);
44 dy1 = fprism_val(1,1,1);
45 dz1 = fprism_val(2,1,1);
46 tau2 = fprism_val(3,1,2);
47 dx2 = fprism_val(0,1,2);
48 dy2 = fprism_val(1,1,2);
49 dz2 = fprism_val(2,1,2);
