root/radiance/ray/lib/adobe.cal
Revision: 1.2
Committed: Tue Mar 18 17:30:16 2003 UTC (22 years, 1 month ago) by greg
Changes since 1.1: +0 -0 lines
State: FILE REMOVED
Decided to move ray/lib directory into non-CVS distribution
1 {
2 Adobe texture.
3
4 Applies to any large, flat surface.
5
6 A1 - overall magnitude
7 }
8
9 { Basic texture is scaled gradient of 3D Perlin noise function.
10 Additional perturbation is added when in_crack is true. }
11 dx = A1 * noise3a(Px, Py, Pz) + if(in_crack, cdx, 0);
12 dy = A1 * noise3b(Px, Py, Pz) + if(in_crack, cdy, 0);
13 dz = A1 * noise3c(Px, Py, Pz) + if(in_crack, cdz, 0);
14
15 { First, compute crack coordinate system, which is at 3 times original
16 bump scale and has additional fractal noise through in for irregularity
17 over an even larger scale. }
18 fn3 = fnoise3(Px, Py, Pz);
19 cu = Px/3 + fn3/30;
20 cv = Py/3 + fn3/30;
21 cw = Pz/3 + fn3/30;
22
23 { Test in_crack returns true (positive) when sum of [-1,1] Perlin noise in
24 crack coordinate system is about -.4 times the fractal noise function at
25 the same point. }
26 in_crack = inside(-.02, noise3(cu, cv, cw) + .4*fnoise3(cu, cv, cw), .02);
27
28 { Final crack perturbation is 5 times as large as normal gradient at that
29 point in Perlin function, meaning it will yank the surface normal one way
30 or the other along that wiggly line where in_crack is true, yielding an
31 apparent discontinuity in the surface. }
32 cdx = 5*A1*noise3a(cu, cv, cw);
33 cdy = 5*A1*noise3b(cu, cv, cw);
34 cdz = 5*A1*noise3c(cu, cv, cw);
