root/Development/ray/lib/README
Revision: 1.2
Committed: Tue Mar 18 17:30:16 2003 UTC (22 years, 6 months ago) by greg
Changes since 1.1: +0 -0 lines
State: FILE REMOVED
Decided to move ray/lib directory into non-CVS distribution
1 This directory contains common auxiliary files used by Radiance. Files
2 with the ".cal" suffix specify procedural patterns, textures and coordinate
3 mappings. Files with the ".fnt" suffix are font descriptions. Files
4 with the ".oct" suffix are compiled scene descriptions for use in
5 instances. Files with the ".mat" suffix contain the names of materials
6 used in the corresponding ".oct" file, for exclusion in the interreflection
7 calculation using the -aE rendering option. Files with the ".pic" suffix
8 are images for patterns. Note that most pictures are normalized to a
9 value of 1 rather than the more usual .5, and must be displayed with
10 the -e -1 option. This is so the material reflectance given in the
11 scene description holds true. (Suggested reflectances are given in
12 parentheses.)
13
14 adobe.cal Texture for cracked adobe surface
15 ball.cal Coordinate mapping for spheres
16 bark.cal Procedural pattern for tree bark
17 brick.cal Procedural pattern for brick
18 carpet.cal Procedural pattern for carpeting
19 covelight.cal Calculation of reflected fluorescent light
20 cyl.cal Coordinate mapping for cylinders
21 dirt.cal Fractal dirt function
22 fisheye.cal Coordinate mapping for fisheye patterns
23 glazing.cal BRTDfunc definitions for coated glazings
24 globe.cal Coordinate mapping for Earth.pic
25 gloss.cal Texture for glossy reflections
26 jigglepic.cal Coordinate jiggle for irregular natural patterns
27 marble.cal Procedural marble pattern
28 orange.cal Procedural orange texture
29 picture.cal Common coordinate mapping for patterns
30 plink.cal Definitions needed by materials in lib/material.rad
31 rayinit.cal Initialization file and common definitions
32 rev.cal Surface normal interpolation for genrev
33 skybright.cal Sky brightness calculation for gensky
34 slate.cal Procedural texture for slate stone
35 source.cal Common coordinate mappings for light sources (ies2rad)
36 speckle.cal Procedural speckle patterns for sand or granite
37 surf.cal Surface normal interpolation for gensurf
38 tilt.cal Tilt correction used by ies2rad
39 weave.cal Procedural weave pattern
40 winxmit.cal Approximation to window transmittance for sec. sources
41 woodpat.cal Procedural woodgrain pattern
42 woodtex.cal Procedural woodgrain texture
43
44 lamp.tab Table of lamp types and their CIE color coordinates
45
46 helvet.fnt Helvetica font (from Hershey set)
47 hexbit4x1.fnt 4 by 1 hex bit font for creating bitmaps
48
49 n.150.oct Spray of needles used by sapling.oct
50 sapling.oct A small pine tree sapling
51 tree.oct A larger pine tree built from sapling.oct
52 tree.mat Exclude material list for tree.oct and sapling.oct
53
54 alberta.pic A scanned vacation slide from Alberta, Canada
55 brick.pic A scanned brick pattern (staggered layout) (rho=16.3%)
56 brickweave.pic A scanned brick pattern (weave layout) (rho=19.8%)
57 cabin.pic A rendering of the cabin during winter
58 Earth.pic A picture of the Earth
59 forestfl.pic A scanned forest floor pattern
60 oakfloor.pic A scanned pattern of an oak floor
61 pine.pic A rendering of a small pine-like bush
62 pinebark.pic A scanned pattern of pine tree bark
63 richgrove.pic A photograph from Richardson's Grove in California
64 shingle.pic A scanned shake shingle pattern
65 tulips.pic A rendering of a tulip sculpture
66
67 source/ Directory for light sources of different manufacturers
68
69 lib/arch.map Default material mapping for arch2rad
70 lib/arch.mat Default materials for arch2rad
71 lib/coord Radiance description of a coordinate system
72 lib/gamma.pic Picture for monitor gamma determination
73 lib/macbeth_spec.pic Picture showing Macbeth color checker colors
74 lib/material.rad Library of RADIANCE materials from ADELINE package
75 lib/rgbw.pic Picture with red, green, blue and white for mon. calib.
76 lib/testimg.pic Picture running through positive and negative primaries
77 lib/testroom Small test room used by objpict and objview
78
79 meta/ Directory with library files for metafile 2-d graphics
