| 1 |
This directory contains common auxiliary files used by Radiance. Files
| 2 |
with the ".cal" suffix specify procedural patterns, textures and coordinate
| 3 |
mappings. Files with the ".fnt" suffix are font descriptions. Files
| 4 |
with the ".oct" suffix are compiled scene descriptions for use in
| 5 |
instances. Files with the ".mat" suffix contain the names of materials
| 6 |
used in the corresponding ".oct" file, for exclusion in the interreflection
| 7 |
calculation using the -aE rendering option. Files with the ".pic" suffix
| 8 |
are images for patterns. Note that most pictures are normalized to a
| 9 |
value of 1 rather than the more usual .5, and must be displayed with
| 10 |
the -e -1 option. This is so the material reflectance given in the
| 11 |
scene description holds true. (Suggested reflectances are given in
| 12 |
parentheses.)
| 13 |
| 14 |
adobe.cal Texture for cracked adobe surface
| 15 |
ball.cal Coordinate mapping for spheres
| 16 |
bark.cal Procedural pattern for tree bark
| 17 |
brick.cal Procedural pattern for brick
| 18 |
carpet.cal Procedural pattern for carpeting
| 19 |
covelight.cal Calculation of reflected fluorescent light
| 20 |
cyl.cal Coordinate mapping for cylinders
| 21 |
dirt.cal Fractal dirt function
| 22 |
fisheye.cal Coordinate mapping for fisheye patterns
| 23 |
glazing.cal BRTDfunc definitions for coated glazings
| 24 |
globe.cal Coordinate mapping for Earth.pic
| 25 |
gloss.cal Texture for glossy reflections
| 26 |
jigglepic.cal Coordinate jiggle for irregular natural patterns
| 27 |
marble.cal Procedural marble pattern
| 28 |
orange.cal Procedural orange texture
| 29 |
picture.cal Common coordinate mapping for patterns
| 30 |
plink.cal Definitions needed by materials in lib/material.rad
| 31 |
rayinit.cal Initialization file and common definitions
| 32 |
rev.cal Surface normal interpolation for genrev
| 33 |
skybright.cal Sky brightness calculation for gensky
| 34 |
slate.cal Procedural texture for slate stone
| 35 |
source.cal Common coordinate mappings for light sources (ies2rad)
| 36 |
speckle.cal Procedural speckle patterns for sand or granite
| 37 |
surf.cal Surface normal interpolation for gensurf
| 38 |
tilt.cal Tilt correction used by ies2rad
| 39 |
weave.cal Procedural weave pattern
| 40 |
winxmit.cal Approximation to window transmittance for sec. sources
| 41 |
woodpat.cal Procedural woodgrain pattern
| 42 |
woodtex.cal Procedural woodgrain texture
| 43 |
| 44 |
lamp.tab Table of lamp types and their CIE color coordinates
| 45 |
| 46 |
helvet.fnt Helvetica font (from Hershey set)
| 47 |
hexbit4x1.fnt 4 by 1 hex bit font for creating bitmaps
| 48 |
| 49 |
n.150.oct Spray of needles used by sapling.oct
| 50 |
sapling.oct A small pine tree sapling
| 51 |
tree.oct A larger pine tree built from sapling.oct
| 52 |
tree.mat Exclude material list for tree.oct and sapling.oct
| 53 |
| 54 |
alberta.pic A scanned vacation slide from Alberta, Canada
| 55 |
brick.pic A scanned brick pattern (staggered layout) (rho=16.3%)
| 56 |
brickweave.pic A scanned brick pattern (weave layout) (rho=19.8%)
| 57 |
cabin.pic A rendering of the cabin during winter
| 58 |
Earth.pic A picture of the Earth
| 59 |
forestfl.pic A scanned forest floor pattern
| 60 |
oakfloor.pic A scanned pattern of an oak floor
| 61 |
pine.pic A rendering of a small pine-like bush
| 62 |
pinebark.pic A scanned pattern of pine tree bark
| 63 |
richgrove.pic A photograph from Richardson's Grove in California
| 64 |
shingle.pic A scanned shake shingle pattern
| 65 |
tulips.pic A rendering of a tulip sculpture
| 66 |
| 67 |
source/ Directory for light sources of different manufacturers
| 68 |
| 69 |
lib/arch.map Default material mapping for arch2rad
| 70 |
lib/arch.mat Default materials for arch2rad
| 71 |
lib/coord Radiance description of a coordinate system
| 72 |
lib/gamma.pic Picture for monitor gamma determination
| 73 |
lib/macbeth_spec.pic Picture showing Macbeth color checker colors
| 74 |
lib/material.rad Library of RADIANCE materials from ADELINE package
| 75 |
lib/rgbw.pic Picture with red, green, blue and white for mon. calib.
| 76 |
lib/testimg.pic Picture running through positive and negative primaries
| 77 |
lib/testroom Small test room used by objpict and objview
| 78 |
| 79 |
meta/ Directory with library files for metafile 2-d graphics
