root/radiance/ray/lib/He.cal
Revision: 1.2
Committed: Tue Mar 18 17:30:16 2003 UTC (22 years, 1 month ago) by greg
Changes since 1.1: +0 -0 lines
State: FILE REMOVED
Decided to move ray/lib directory into non-CVS distribution
# User Rev Content
1 greg 1.1 {
2     He-Torrance Reflectance Model (Siggraph 1991)
3
4     This is the simplified version that doesn't account for
5     changes in reflection due to changes in wavelength. Also,
6     specular and directional-diffuse hightlights are left uncolored
7     because coloring them requires multiple evaluations of some
8     very expensive functions.
9
10     The primitive for this function should look something like:
11
12     void BRTDfunc name
13     10
14     s s s
15     0 0 0
16     dd dd dd
17     He.cal
18     0
19     13 amb_r amb_g amb_b
20     amb_r amb_g amb_b
21     0 0 0
22     sigma0 tau
23     n_real n_imag
24
25     For metals, the specular color may be modified like so:
26
27     void BRTDfunc name
28     10
29     s_r s_g s_b
30     0 0 0
31     dd dd dd
32     He.cal
33     0
34     13 amb_r amb_g amb_b
35     amb_r amb_g amb_b
36     0 0 0
37     sigma0 tau
38     n_real n_imag
39
40     This doesn't work for the directional diffuse component, unfortunately.
41     A second set of functions dd_r, dd_g and dd_b may be used, but they
42     cost three times as much to compute!
43     }
44
45     { Constants }
46     lambda : .5; { wavelength (microns) }
47     z0err : .0001; { accepted error in value of z0 }
48     Dsumlim : .000001; { last term of D summation }
49     Dsummax : 200; { maximum terms in D summation }
50
51     { Parameters }
52     sigma0 = arg(10); { surface height deviation (microns) }
53     tau = arg(11); { correlation distance (microns) }
54     n_real = arg(12); { real part of index of refraction }
55     n_imag = arg(13); { imaginary part of index of refraction }
56     { Derived parameters }
57     n_k = n_imag/n_real;
58     { Constant functions }
59     Exp(x) : if(-x-400, 0, exp(x)); { rayinit.cal version too timid for D() }
60
61     { Repeated formulas }
62     cotexp(t) = tau/sigma0/2/tan(t);
63     shadowf2(et,erfcet) = (1-.5*erfcet) /
64     ((Exp(-sq(et))/sqrt(PI)/et - erfcet)/2 + 1);
65     shadowf1(t) = or(FTINY-sigma0, .01-abs(t));
66     shadowf0(t) = abs(t) - (PI/2-.0001);
67     shadowf(t) = if(shadowf0(t), 0, if(shadowf1(t), 1,
68     shadowf2(cotexp(t), erfc(cotexp(t)))));
69     K(t) = if(abs(t)-FTINY, tan(t) * erfc(cotexp(t)), 0);
70     fuvA(ct) = sq(n_real)*(1-sq(n_k)) - (1-sq(ct));
71     fuvB(ct) = sqrt(sq(fuvA(ct)) + 4*sq(sq(n_real)*n_k));
72     fu2(ct) = (fuvA(ct) + fuvB(ct))/2;
73     fv2(ct) = (-fuvA(ct) + fuvB(ct))/2;
74     fperp2(ct) = (sq(ct-sqrt(fu2(ct))) + fv2(ct)) /
75     (sq(ct+sqrt(fu2(ct))) + fv2(ct));
76     fpara2(ct) = (sq(sq(n_real)*(1-sq(n_k))*ct - sqrt(fu2(ct))) +
77     sq(2*sq(n_real)*n_k*ct - Sqrt(fv2(ct)))) /
78     (sq(sq(n_real)*(1-sq(n_k))*ct + sqrt(fu2(ct))) +
79     sq(2*sq(n_real)*n_k*ct + Sqrt(fv2(ct))));
80     fresnel2(ct) = (fperp2(ct) + fpara2(ct))/2;
81
82     { Formulas dependent only on reflected direction }
83     theta_r = acos(RdotP);
84     shadowf_r = shadowf(theta_r);
85     K_r = K(theta_r);
86     srx = Dy*NzP - Dz*NyP; sry = Dz*NxP - Dx*NzP; srz = Dx*NyP - Dy*NxP;
87     srn2 = sq(srx) + sq(sry) + sq(srz);
88     prx = sry*Dz - srz*Dy;
89     pry = srz*Dx - srx*Dz;
90     prz = srx*Dy - sry*Dx;
91     s = fresnel2(RdotP)*Exp(-g(RdotP))*sq(shadowf_r);
92     s_r = s*arg(1)*CrP;
93     s_g = s*arg(2)*CgP;
94     s_b = s*arg(3)*CbP;
95
96     { Formulas dependent on incident direction }
97     { z0 }
98     z0d(Ki,z) = -(Ki+K_r)/(4*sigma0)*z*Exp(-sq(z/sigma0)/2) - sqrt(PI/2);
99     z0lim(x) = if(x, max(x,z0err), min(x,-z0err));
100     z0off(Ki,z) = (sigma0/4*(Ki+K_r)*Exp(-sq(z/sigma0)/2)-sqrt(PI/2)*z)/
101     z0lim(z0d(Ki,z));
102     z0root(Ki, x0, x1, i) = if(i,
103     if(z0err-abs(x1-x0),
104     x1,
105     z0root(Ki,x1,x1-z0off(Ki,x1),i-1)),
106     0);
107     z0(ti) = z0root(K(ti), .1, -z0off(K(ti),.1), 100);
108     { sigma }
109     sigma(ti) = if( FTINY-sigma0, sigma0,
110     sigma0/sqrt(1+sq(z0(ti)/sigma0)) );
111     { g }
112     g(cti) = sq(2*PI/lambda*sigma(Acos(cti))*(cti+RdotP));
113     { |F|^2 }
114     fresnel2dd(kix,kiy,kiz) = fresnel2(sqrt(sq(kix-Dx) + sq(kiy-Dy) +
115     sq(kiz-Dz))/2);
116     { G }
117     { The bulk of G was found by Andrew Willmott to cancel. This is the original:
118     G2( kix,kiy,kiz, six,siy,siz ) =
119     sq( (sq(kix-Dx)+sq(kiy-Dy)+sq(kiz-Dz)) /
120     (NxP*(kix-Dx)+NyP*(kiy-Dy)+NzP*(kiz-Dz)) ) /
121     sq(sq(Dy*kiz-Dz*kiy)+sq(Dz*kix-Dx*kiz)+sq(Dx*kiy-Dy*kix)) *
122     (sq(srx*kix+sry*kiy+srz*kiz) +
123     sq(prx*kix+pry*kiy+prz*kiz)) *
124     (sq(six*Dx+siy*Dy+siz*Dz) +
125     sq((siy*kiz-siz*kiy)*Dx+(siz*kix-six*kiz)*Dy+(six*kiy-siy*kix)*Dz)) /
126     srn2 / (sq(six)+sq(siy)+sq(siz));
127     G(kix,kiy,kiz) = G2(kix,kiy,kiz,
128     kiy*NzP-kiz*NyP, kiz*NxP-kix*NzP, kix*NyP-kiy*NxP);
129     -- Newer version below is much simpler: }
130     G(kix,kiy,kiz) = sq( (sq(kix-Dx)+sq(kiy-Dy)+sq(kiz-Dz)) /
131     (NxP*(kix-Dx)+NyP*(kiy-Dy)+NzP*(kiz-Dz)) );
132     { D }
133     Dsum2(m,lt,c,t,e,g) = if(or(m-Dsummax,and(lt-t,Dsumlim-t)),t,
134     t+Dsum2(m+1,t,c*g/(m+1),c*g/(m+1)*Exp(-g-e/(m+1))/(m+1),e,g));
135     Dsum(e,g) = Dsum2(1,0,g,g*Exp(-g-e),e,g);
136     D(kix,kiy,kiz) = sq(PI)/4/sq(lambda)*sq(tau) *
137     Dsum(sq(2*PI/lambda)/4*sq(tau)*
138     (sq(kix-Dx)+sq(kiy-Dy)+sq(kiz-Dz) -
139     sq(NxP*(kix-Dx)+NyP*(kiy-Dy)+NzP*(kiz-Dz))),
140     g(kix*NxP+kiy*NyP+kiz*NzP));
141     { rho_dd }
142     dd2(cti) = shadowf_r*shadowf(Acos(cti))/cti/RdotP;
143     dd(kix,kiy,kiz) = dd2(kix*NxP+kiy*NyP+kiz*NzP)*G(kix,kiy,kiz)*
144     fresnel2dd(kix,kiy,kiz)/PI*D(kix,kiy,kiz);
145     { Color version 3x as slow! }
146     dd_r(kix,kiy,kiz) = dd(kix,kiy,kiz)*arg(1)*CrP;
147     dd_g(kix,kiy,kiz) = dd(kix,kiy,kiz)*arg(2)*CgP;
148     dd_b(kix,kiy,kiz) = dd(kix,kiy,kiz)*arg(3)*CbP;
