root/Development/ray/lib/Earth.cal
Revision: 1.2
Committed: Tue Mar 18 17:30:16 2003 UTC (22 years, 7 months ago) by greg
Changes since 1.1: +0 -0 lines
State: FILE REMOVED
Decided to move ray/lib directory into non-CVS distribution
1 {
2 Coordinate mapping for point above Earth
3 assuming uniform projection of latitude and longitude
4
5 5/1/96 Greg Ward
6
7 A1 = latitude position (degrees)
8 A2 = longitude position (degrees)
9 A3 = height above Earth (kilometers)
10 A4 = Julian date (1-365)
11 A5 = Greenwich Mean Time (0-24)
12
13 By modifying this file so that the above arguments are defined
14 instead as constants, significant gains in speed are possible.
15 (Be sure to change Su, Sv and Sw to constant definitions also.)
16
17 Y-axis points North, Z-axis points up (away from Earth)
18 }
19 {
20 Example usage:
21
22 void colorpict epict
23 7 Eval Eval Eval Earth.pic Earth.cal u v
24 0
25 5 lat long height JDate GMT
26
27 epict glow eglow
28 0
29 0
30 4 1 1 1 0
31
32 eglow source earth
33 0
34 0
35 4 0 0 -1 max_angle
36
37 where:
38 max_angle = 2*180/PI * asin(EarthRad/(EarthRad+height))
39
40 If you are really close to the Earth (below atmosphere), use:
41
42 !gensky month day time -a lat -o lon -m std_meridian
43
44 skybright colorpict epict
45 7 noop noop noop Earth.pic Earth.cal u v
46 0
47 3 lat long height
48
49 epict glow eglow
50 0
51 0
52 4 1 1 1 0
53
54 eglow source earth
55 0
56 0
57 4 0 0 -1 max_angle
58 }
59
60 EarthRad : 6378.5; { Earth radius in kilometers }
61 EarthTilt : 23.45*DEGREE; { Earth's orbital axis tilt }
62 EarthIrrad : 770 {watts/meter^2}; { Maximum Earth irradiance }
63 PA : 256/512; { Picture Height/Width }
64
65 { Change the following to constants to speed things up }
66 Lat = arg(1)*DEGREE; { Position latitude }
67 Lon = arg(2)*DEGREE; { Position longitude }
68 Height = arg(3); { Position height above Earth (km) }
69 JDate = arg(4); { Julian date (1-365) }
70 GMT = arg(5); { Greenwich Mean Time (0-24) }
71
72 GOu = EarthRad*sin(Lon)*cos(Lat); { Starting Earth position }
73 GOv = EarthRad*cos(Lon)*cos(Lat);
74 GOw = EarthRad*sin(Lat);
75
76 raduv = max(FTINY, sqrt(GOu*GOu + GOv*GOv)); { Earthwise direction vector }
77 GVXu = -GOv / raduv;
78 GVXv = GOu / raduv;
79 GVXw = 0;
80 GVYu = (-GOw*GOu) / EarthRad / raduv;
81 GVYv = (GOw*-GOv) / EarthRad / raduv;
82 GVYw = (GOu*GOu + GOv*GOv) / EarthRad / raduv;
83 radxy = max(FTINY, sqrt(Dx*Dx + Dy*Dy));
84 GDu = (GVXu*Dx + GVYu*Dy) / radxy;
85 GDv = (GVXv*Dx + GVYv*Dy) / radxy;
86 GDw = (GVXw*Dx + GVYw*Dy) / radxy;
87
88 tana = if(FTINY+Dz, radxy/FTINY, radxy/-Dz);
89
90 det = sq(EarthRad+Height) - (tana*tana + 1)*(2*EarthRad*Height + Height*Height);
91
92 a = if(tana-FTINY, b/tana, Height);
93
94 b = if(tana-FTINY, (EarthRad + Height - Sqrt(det)) / (tana + 1/tana), 0);
95
96 c = EarthRad + Height - a;
97
98 digfactor = 1 - (a - Height)/EarthRad;
99 { Global position vector }
100 GPu = GOu*digfactor + GDu*b;
101 GPv = GOv*digfactor + GDv*b;
102 GPw = GOw*digfactor + GDw*b;
103 { Earthly coordinates }
104 longitude = atan2(GPu, GPv);
105 latitude = Asin(GPw/EarthRad);
106 { Image lookup coordinates }
107 u = if(PA-1, 1, 1/PA) * (.5 - longitude/(2*PI));
108 v = if(PA-1, PA, 1) * (.5 + latitude/PI);
109 { Solar declination (lat.) }
110 Slat = EarthTilt * sin(2*PI/368 * (JDate - 81));
111 { Solar longitude }
112 Slon = 2*PI/24 * (GMT - 12);
113 { Solar position vector }
114 Su = EarthRad*sin(Slon)*cos(Slat);
115 Sv = EarthRad*cos(Slon)*cos(Slat);
116 Sw = EarthRad*sin(Slat);
117 { Solar cosine }
118 Scos = (Su*GPu + Sv*GPv + Sw*GPw)/(EarthRad*EarthRad);
119 { Earth radiance multiplier }
120 Eradmult = EarthIrrad / PI * noneg(Scos);
121 { Earth radiance }
122 Eval(rho) = Eradmult * rho;
