1 |
2 |
Coordinate mapping for point above Earth |
3 |
assuming uniform projection of latitude and longitude |
4 |
5 |
5/1/96 Greg Ward |
6 |
7 |
A1 = latitude position (degrees) |
8 |
A2 = longitude position (degrees) |
9 |
A3 = height above Earth (kilometers) |
10 |
A4 = Julian date (1-365) |
11 |
A5 = Greenwich Mean Time (0-24) |
12 |
13 |
By modifying this file so that the above arguments are defined |
14 |
instead as constants, significant gains in speed are possible. |
15 |
(Be sure to change Su, Sv and Sw to constant definitions also.) |
16 |
17 |
Y-axis points North, Z-axis points up (away from Earth) |
18 |
19 |
20 |
Example usage: |
21 |
22 |
void colorpict epict |
23 |
7 Eval Eval Eval Earth.pic Earth.cal u v |
24 |
0 |
25 |
5 lat long height JDate GMT |
26 |
27 |
epict glow eglow |
28 |
0 |
29 |
0 |
30 |
4 1 1 1 0 |
31 |
32 |
eglow source earth |
33 |
0 |
34 |
0 |
35 |
4 0 0 -1 max_angle |
36 |
37 |
where: |
38 |
max_angle = 2*180/PI * asin(EarthRad/(EarthRad+height)) |
39 |
40 |
If you are really close to the Earth (below atmosphere), use: |
41 |
42 |
!gensky month day time -a lat -o lon -m std_meridian |
43 |
44 |
skybright colorpict epict |
45 |
7 noop noop noop Earth.pic Earth.cal u v |
46 |
0 |
47 |
3 lat long height |
48 |
49 |
epict glow eglow |
50 |
0 |
51 |
0 |
52 |
4 1 1 1 0 |
53 |
54 |
55 |
0 |
56 |
0 |
57 |
58 |
59 |
60 |
EarthRad : 6378.5; { Earth radius in kilometers } |
61 |
EarthTilt : 23.45*DEGREE; { Earth's orbital axis tilt } |
62 |
EarthIrrad : 770 {watts/meter^2}; { Maximum Earth irradiance } |
63 |
PA : 256/512; { Picture Height/Width } |
64 |
65 |
{ Change the following to constants to speed things up } |
66 |
Lat = arg(1)*DEGREE; { Position latitude } |
67 |
Lon = arg(2)*DEGREE; { Position longitude } |
68 |
Height = arg(3); { Position height above Earth (km) } |
69 |
JDate = arg(4); { Julian date (1-365) } |
70 |
GMT = arg(5); { Greenwich Mean Time (0-24) } |
71 |
72 |
GOu = EarthRad*sin(Lon)*cos(Lat); { Starting Earth position } |
73 |
GOv = EarthRad*cos(Lon)*cos(Lat); |
74 |
GOw = EarthRad*sin(Lat); |
75 |
76 |
raduv = max(FTINY, sqrt(GOu*GOu + GOv*GOv)); { Earthwise direction vector } |
77 |
GVXu = -GOv / raduv; |
78 |
GVXv = GOu / raduv; |
79 |
GVXw = 0; |
80 |
GVYu = (-GOw*GOu) / EarthRad / raduv; |
81 |
GVYv = (GOw*-GOv) / EarthRad / raduv; |
82 |
GVYw = (GOu*GOu + GOv*GOv) / EarthRad / raduv; |
83 |
radxy = max(FTINY, sqrt(Dx*Dx + Dy*Dy)); |
84 |
GDu = (GVXu*Dx + GVYu*Dy) / radxy; |
85 |
GDv = (GVXv*Dx + GVYv*Dy) / radxy; |
86 |
GDw = (GVXw*Dx + GVYw*Dy) / radxy; |
87 |
88 |
tana = if(FTINY+Dz, radxy/FTINY, radxy/-Dz); |
89 |
90 |
det = sq(EarthRad+Height) - (tana*tana + 1)*(2*EarthRad*Height + Height*Height); |
91 |
92 |
a = if(tana-FTINY, b/tana, Height); |
93 |
94 |
b = if(tana-FTINY, (EarthRad + Height - Sqrt(det)) / (tana + 1/tana), 0); |
95 |
96 |
c = EarthRad + Height - a; |
97 |
98 |
digfactor = 1 - (a - Height)/EarthRad; |
99 |
{ Global position vector } |
100 |
GPu = GOu*digfactor + GDu*b; |
101 |
GPv = GOv*digfactor + GDv*b; |
102 |
GPw = GOw*digfactor + GDw*b; |
103 |
{ Earthly coordinates } |
104 |
longitude = atan2(GPu, GPv); |
105 |
latitude = Asin(GPw/EarthRad); |
106 |
{ Image lookup coordinates } |
107 |
u = if(PA-1, 1, 1/PA) * (.5 - longitude/(2*PI)); |
108 |
v = if(PA-1, PA, 1) * (.5 + latitude/PI); |
109 |
{ Solar declination (lat.) } |
110 |
Slat = EarthTilt * sin(2*PI/368 * (JDate - 81)); |
111 |
{ Solar longitude } |
112 |
Slon = 2*PI/24 * (GMT - 12); |
113 |
{ Solar position vector } |
114 |
Su = EarthRad*sin(Slon)*cos(Slat); |
115 |
Sv = EarthRad*cos(Slon)*cos(Slat); |
116 |
Sw = EarthRad*sin(Slat); |
117 |
{ Solar cosine } |
118 |
Scos = (Su*GPu + Sv*GPv + Sw*GPw)/(EarthRad*EarthRad); |
119 |
{ Earth radiance multiplier } |
120 |
Eradmult = EarthIrrad / PI * noneg(Scos); |
121 |
{ Earth radiance } |
122 |
Eval(rho) = Eradmult * rho; |
