1 |
#!/bin/csh -f |
2 |
# RCSid $Id: installib,v 1.3 2003/10/30 15:41:23 greg Exp $ |
3 |
4 |
# Install library files |
5 |
6 |
again2: |
7 |
echo -n "Where do you want the library files [/usr/local/lib/ray]? " |
8 |
set ldir=$< |
9 |
(echo $ldir) >/dev/null |
10 |
if ( $status ) goto again2 |
11 |
set ldir=$ldir |
12 |
if ( "$ldir" == "" ) then |
13 |
set ldir=/usr/local/lib/ray |
14 |
else if ( "$ldir" !~ /* ) then |
15 |
echo "Directory must be relative to root, please reenter" |
16 |
goto again2 |
17 |
endif |
18 |
if ( ! -d $ldir ) then |
19 |
mkdir $ldir |
20 |
if ( $status ) then |
21 |
echo "Cannot create directory, please reenter" |
22 |
goto again2 |
23 |
endif |
24 |
endif |
25 |
if (! -d lib) then |
26 |
echo ">>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>" |
27 |
echo "You forgot to install the auxiliary files overlay." |
28 |
echo "Download rad5R1supp.tar.gz from http://www.radiance-online.org" |
29 |
echo "and run 'installib' later manually, or ^C now." |
30 |
echo "<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<" |
31 |
exit |
32 |
endif |
33 |
set d1=(`ls -Lid lib`) |
34 |
set d2=(`ls -Lid $ldir`) |
35 |
if ($d1[1] != $d2[1]) then |
36 |
echo -n "Install library files now [n]? " |
37 |
if ( "$<" =~ [yY]* ) then |
38 |
echo -n "Copying library files to $ldir... " |
39 |
(cd lib ; tar -cf - *) | (cd $ldir ; tar -xf -) |
40 |
echo "Done." |
41 |
endif |
42 |
endif |
43 |
unset d1 d2 |
