| 1 |
#!/bin/csh -f
| 2 |
# RCSid $Id: installib,v 1.1 2003/02/28 20:06:51 greg Exp $
| 3 |
| 4 |
# Install library files
| 5 |
| 6 |
again2:
| 7 |
echo -n "Where do you want the library files [/usr/local/lib/ray]? "
| 8 |
set ldir=$<
| 9 |
(echo $ldir) >/dev/null
| 10 |
if ( $status ) goto again2
| 11 |
set ldir=$ldir
| 12 |
if ( "$ldir" == "" ) then
| 13 |
set ldir=/usr/local/lib/ray
| 14 |
else if ( "$ldir" !~ /* ) then
| 15 |
echo "Directory must be relative to root, please reenter"
| 16 |
goto again2
| 17 |
endif
| 18 |
if ( ! -d $ldir ) then
| 19 |
mkdir $ldir
| 20 |
if ( $status ) then
| 21 |
echo "Cannot create directory, please reenter"
| 22 |
goto again2
| 23 |
endif
| 24 |
endif
| 25 |
if ( $ldir != $cwd/lib ) then
| 26 |
set d1=(`ls -id lib`)
| 27 |
set d2=(`ls -id $ldir`)
| 28 |
if ($d1[1] != $d2[1]) then
| 29 |
echo -n "Install library files now [n]? "
| 30 |
if ( "$<" =~ [yY]* ) then
| 31 |
echo -n "Copying library files to $ldir... "
| 32 |
(cd lib ; tar -cf - *) | (cd $ldir ; tar -xf -)
| 33 |
echo "Done."
| 34 |
endif
| 35 |
endif
| 36 |
unset d1 d2
| 37 |
endif
