| 1 | greg | 1.1 | #!/bin/csh -f |
| 2 | greg | 1.3 | # RCSid $Id: installib,v 1.2 2003/10/20 15:10:17 greg Exp $ |
| 3 | greg | 1.1 | # |
| 4 |  |  | # Install library files |
| 5 |  |  | # |
| 6 |  |  | again2: |
| 7 |  |  | echo -n "Where do you want the library files [/usr/local/lib/ray]? " |
| 8 |  |  | set ldir=$< |
| 9 |  |  | (echo $ldir) >/dev/null |
| 10 |  |  | if ( $status ) goto again2 |
| 11 |  |  | set ldir=$ldir |
| 12 |  |  | if ( "$ldir" == "" ) then |
| 13 |  |  | set ldir=/usr/local/lib/ray |
| 14 |  |  | else if ( "$ldir" !~ /* ) then |
| 15 |  |  | echo "Directory must be relative to root, please reenter" |
| 16 |  |  | goto again2 |
| 17 |  |  | endif |
| 18 | greg | 1.2 | if ( ! -d $ldir ) then |
| 19 |  |  | mkdir $ldir |
| 20 |  |  | if ( $status ) then |
| 21 |  |  | echo "Cannot create directory, please reenter" |
| 22 |  |  | goto again2 |
| 23 |  |  | endif |
| 24 |  |  | endif |
| 25 | greg | 1.3 | if (! -d lib) then |
| 26 |  |  | echo ">>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>" |
| 27 |  |  | echo "You forgot to install the auxiliary files overlay." |
| 28 |  |  | echo "Download rad3R6supp.tar.gz from http://www.radiance-online.org" |
| 29 |  |  | echo "and run 'installib' later manually, or ^C now." |
| 30 |  |  | echo "<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<" |
| 31 |  |  | exit |
| 32 |  |  | endif |
| 33 |  |  | set d1=(`ls -Lid lib`) |
| 34 |  |  | set d2=(`ls -Lid $ldir`) |
| 35 |  |  | if ($d1[1] != $d2[1]) then |
| 36 |  |  | echo -n "Install library files now [n]? " |
| 37 |  |  | if ( "$<" =~ [yY]* ) then |
| 38 |  |  | echo -n "Copying library files to $ldir... " |
| 39 |  |  | (cd lib ; tar -cf - *) | (cd $ldir ; tar -xf -) |
| 40 |  |  | echo "Done." |
| 41 | greg | 1.1 | endif |
| 42 |  |  | endif |
| 43 | greg | 1.3 | unset d1 d2 |
