root/Development/ray/installib
Revision: 1.3
Committed: Thu Oct 30 15:41:23 2003 UTC (21 years, 10 months ago) by greg
CVS Tags: rad5R0, rad4R2, rad3R7P2, rad3R7P1, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad4R2P2
Changes since 1.2: +18 -12 lines
Added check for installation of overlay files.
# User Rev Content
1 greg 1.1 #!/bin/csh -f
2 greg 1.3 # RCSid $Id: installib,v 1.2 2003/10/20 15:10:17 greg Exp $
3 greg 1.1 #
4     # Install library files
5     #
6     again2:
7     echo -n "Where do you want the library files [/usr/local/lib/ray]? "
8     set ldir=$<
9     (echo $ldir) >/dev/null
10     if ( $status ) goto again2
11     set ldir=$ldir
12     if ( "$ldir" == "" ) then
13     set ldir=/usr/local/lib/ray
14     else if ( "$ldir" !~ /* ) then
15     echo "Directory must be relative to root, please reenter"
16     goto again2
17     endif
18 greg 1.2 if ( ! -d $ldir ) then
19     mkdir $ldir
20     if ( $status ) then
21     echo "Cannot create directory, please reenter"
22     goto again2
23     endif
24     endif
25 greg 1.3 if (! -d lib) then
26     echo ">>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>"
27     echo "You forgot to install the auxiliary files overlay."
28     echo "Download rad3R6supp.tar.gz from http://www.radiance-online.org"
29     echo "and run 'installib' later manually, or ^C now."
30     echo "<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<"
31     exit
32     endif
33     set d1=(`ls -Lid lib`)
34     set d2=(`ls -Lid $ldir`)
35     if ($d1[1] != $d2[1]) then
36     echo -n "Install library files now [n]? "
37     if ( "$<" =~ [yY]* ) then
38     echo -n "Copying library files to $ldir... "
39     (cd lib ; tar -cf - *) | (cd $ldir ; tar -xf -)
40     echo "Done."
41 greg 1.1 endif
42     endif
43 greg 1.3 unset d1 d2
