The RADIANCE 6.0 Synthetic Imaging System
    1. Primitive Types
      1. Surfaces
      2. Materials
      3. Textures
      4. Patterns
      5. Mixtures
    2. Auxiliary Files
      1. Function Files
      2. Data Files
      3. Font Files
    3. Generators
  3. Image Generation
  4. License
  5. Acknowledgements
  6. References
  7. Types Index
RADIANCE was developed as a research tool for predicting the distribution of visible radiation in illuminated spaces. It takes as input a three-dimensional geometric model of the physical environment, and produces a map of spectral radiance values in a color image. The technique of ray-tracing follows light backwards from the image plane to the source(s). Because it can produce realistic images from a simple description, RADIANCE has a wide range of applications in graphic arts, lighting design, computer-aided engineering and architecture.
The diagram in Figure 1 shows the flow between programs (boxes) and data (ovals). The central program is rpict, which produces a picture from a scene description. Rvu is a variation of rpict that computes and displays images interactively, and rtrace computes single ray values. Other programs (not shown) connect many of these elements together, such as the executive programs rad and ranimate, the interactive rendering program rholo, and the animation program ranimove. The program obj2mesh acts as both a converter and scene compiler, converting a Wavefront .OBJ file into a compiled mesh octree for efficient rendering.
A scene description file lists the surfaces and materials that make up a specific environment. The current surface types are spheres, polygons, cones, and cylinders. There is also a composite surface type, called mesh, and a pseudosurface type, called instance, which facilitates very complex geometries. Surfaces can be made from materials such as plastic, metal, and glass. Light sources can be distant disks as well as local spheres, disks and polygons.
From a three-dimensional scene description and a specified view, rpict produces a two-dimensional image. A picture file is a compressed binary representation of the pixels in the image. This picture can be scaled in size and brightness, anti-aliased, and sent to a graphics output device.
A header in each picture file lists the program(s) and parameters that produced it. This is useful for identifying a picture without having to display it. The information can be read by the program getinfo.
A scene description file represents a three-dimensional physical environment in Cartesian (rectilinear) world coordinates. It is stored as ASCII text, with the following basic format:
The scene description primitives all have the same general format, and can be either surfaces or modifiers. A primitive has a modifier, a type, and an identifier.
A modifier is either the identifier of a previously defined primitive, or "void".
[ The most recent definition of a modifier is the one used, and later definitions do not cause relinking of loaded primitives. Thus, the same identifier may be used repeatedly, and each new definition will apply to the primitives following it. ]
An identifier can be any string (i.e., any sequence of non-white characters).
An alias gets its type and arguments from a previously defined primitive. This is useful when the same material is used with a different modifier, or as a convenient naming mechanism. The reserved modifier name "inherit" may be used to specificy that an alias will inherit its modifier from the original. Surfaces cannot be aliased.
A line beginning with an exclamation point, `!', is interpreted as a command. It is executed by the shell, and its output is read as input to the program. The command must not try to read from its standard input, or confusion will result. A command may be continued over multiple lines using a backslash, `\', to escape the newline.
White space is generally ignored, except as a separator. The exception is the newline character after a command or comment. Commands, comments and primitives may appear in any combination, so long as they are not intermingled.
Primitives can be surfaces, materials, textures or patterns. Modifiers can be materials, mixtures, textures or patterns. Simple surfaces must have one material in their modifier list.
2.1.1. Surfaces
A scene description will consist mostly of surfaces. The basic types are given below.
Source
A source is not really a surface, but a solid angle. It is used for specifying light sources that are very distant. The direction to the center of the source and the number of degrees subtended by its disk are given as follows:
	mod source id
	4 xdir ydir zdir angle
Sphere
A sphere is given by its center and radius:
        mod sphere id
        4 xcent ycent zcent radius
Bubble
A bubble is simply a sphere whose surface normal points inward.
Polygon
A polygon is given by a list of three-dimensional vertices, which are ordered counter-clockwise as viewed from the front side (into the surface normal). The last vertex is automatically connected to the first. Holes are represented in polygons as interior vertices connected to the outer perimeter by coincident edges (seams).
        mod polygon id
        3n
                x1      y1      z1
                x2      y2      z2
                xn      yn      zn
Cone
A cone is a megaphone-shaped object. It is truncated by two planes perpendicular to its axis, and one of its ends may come to a point. It is given as two axis endpoints, and the starting and ending radii:
        mod cone id
        8
                x0      y0      z0
                x1      y1      z1
                r0      r1
Cup
A cup is an inverted cone (i.e., has an inward surface normal).
Cylinder
A cylinder is like a cone, but its starting and ending radii are equal.
        mod cylinder id
        7
                x0      y0      z0
                x1      y1      z1
Tube
A tube is an inverted cylinder.
Ring
A ring is a circular disk given by its center, surface normal, and inner and outer radii:
        mod ring id
        8
                xcent   ycent   zcent
                xdir    ydir    zdir
                r0      r1
Instance
An instance is a compound surface, given by the contents of an octree file (created by oconv).
        mod instance id
        1+ octree transform
If the modifier is "void", then surfaces will use the modifiers given in the original description. Otherwise, the modifier specified is used in their place. The transform moves the octree to the desired location in the scene. Multiple instances using the same octree take little extra memory, hence very complex descriptions can be rendered using this primitive.
Mesh
A mesh is a compound surface, made up of many triangles and an octree data structure to accelerate ray intersection. It is typically converted from a Wavefront .OBJ file using the obj2mesh program.
        mod mesh id
        1+ meshfile transform
If the modifier is "void", then surfaces will use the modifiers given in the original mesh description. Otherwise, the modifier specified is used in their place. The transform moves the mesh to the desired location in the scene. Multiple instances using the same meshfile take little extra memory, and the compiled mesh itself takes much less space than individual polygons would. In the case of an unsmoothed mesh, using the mesh primitive reduces memory requirements by a factor of 30 relative to individual triangles. If a mesh has smoothed surfaces, we save a factor of 50 or more, permitting very detailed geometries that would otherwise exhaust the available memory. In addition, the mesh primitive can have associated (u,v) coordinates for pattern and texture mapping. These are made available to function files via the Lu and Lv variables.
2.1.2. Materials
A material defines the way light interacts with a surface. The basic types are given below.
Light
Light is the basic material for self-luminous surfaces (i.e., light sources). In addition to the source surface type, spheres, discs (rings with zero inner radius), cylinders (provided they are long enough), and polygons can act as light sources. Polygons work best when they are rectangular. Cones cannot be used at this time. A pattern may be used to specify a light output distribution. Light is defined simply as a RGB radiance value (watts/steradian/m2):
        mod light id
        3 red green blue
Illum
Illum is used for secondary light sources with broad distributions. A secondary light source is treated like any other light source, except when viewed directly. It then acts like it is made of a different material (indicated by the string argument), or becomes invisible (if no string argument is given, or the argument is "void"). Secondary sources are useful when modeling windows or brightly illuminated surfaces.
        mod illum id
        1 material
        3 red green blue
Glow
Glow is used for surfaces that are self-luminous, but limited in their effect. In addition to the radiance value, a maximum radius for shadow testing is given:
        mod glow id
        4 red green blue maxrad
If maxrad is zero, then the surface will never be tested for shadow, although it may participate in an interreflection calculation. If maxrad is negative, then the surface will never contribute to scene illumination. Glow sources will never illuminate objects on the other side of an illum surface. This provides a convenient way to illuminate local light fixture geometry without overlighting nearby objects.
Spotlight
Spotlight is used for self-luminous surfaces having directed output. As well as radiance, the full cone angle (in degrees) and orientation (output direction) vector are given. The length of the orientation vector is the distance of the effective focus behind the source center (i.e., the focal length).
        mod spotlight id
        7 red green blue angle xdir ydir zdir
Mirror
Mirror is used for planar surfaces that produce virtual source reflections. This material should be used sparingly, as it may cause the light source calculation to blow up if it is applied to many small surfaces. This material is only supported for flat surfaces such as polygons and rings. The arguments are simply the RGB reflectance values, which should be between 0 and 1. An optional string argument may be used like the illum type to specify a different material to be used for shading non-source rays. If this alternate material is given as "void", then the mirror surface will be invisible. This is only appropriate if the surface hides other (more detailed) geometry with the same overall reflectance.
        mod mirror id
        1 material
        3 red green blue
While alternate materials that are reflective will appear as normal, indirect rays will use the mirror's reflectance rather than the alternate type. Transmitting materials are an exception, where both transmission and reflection will use the alternate type for all rays not specifically targeting virtual light sources. In this case, it is important that any reflections be purely specular (mirror-like) and equal to the mirror's reflectivity to maintain a valid result. A pure diffuse reflection may be added if desired.
The mirror material type reflects light sources only from the front side of a surface, regardless of any alternate material. If virtual source generation is desired on both sides, two coincident surfaces with opposite normal orientations may be employed to achieve this effect. The reflectance and alternate material type may be different for the overlapped surfaces, and the two sides will behave accordingly.
Prism1
The prism1 material is for general light redirection from prismatic glazings, generating virtual light sources. It can only be used to modify a planar surface (i.e., a polygon or disk) and should not result in either light concentration or scattering. The new direction of the ray can be on either side of the material, and the definitions must have the correct bidirectional properties to work properly with virtual light sources. The arguments give the coefficient for the redirected light and its direction.
        mod prism1 id
        5+ coef dx dy dz funcfile transform
        n A1 A2 .. An
The new direction variables dx, dy and dz need not produce a normalized vector. For convenience, the variables DxA, DyA and DzA are defined as the normalized direction to the target light source. See section 2.2.1 on function files for further information.
Prism2
The material prism2 is identical to prism1 except that it provides for two ray redirections rather than one.
        mod prism2 id
        9+ coef1 dx1 dy1 dz1 coef2 dx2 dy2 dz2 funcfile transform
        n A1 A2 .. An
Mist
Mist is a virtual material used to delineate a volume of participating atmosphere. A list of important light sources may be given, along with an extinction coefficient, scattering albedo and scattering eccentricity parameter. The light sources named by the string argument list will be tested for scattering within the volume. Sources are identified by name, and virtual light sources may be indicated by giving the relaying object followed by '>' followed by the source, i.e:
	3  source1  mirror1>source10  mirror2>mirror1>source3
Normally, only one source is given per mist material, and there is an upper limit of 32 to the total number of active scattering sources. The extinction coefficient, if given, is added the the global coefficient set on the command line. Extinction is in units of 1/distance (distance based on the world coordinates), and indicates the proportional loss of radiance over one unit distance. The scattering albedo, if present, will override the global setting within the volume. An albedo of 0 0 0 means a perfectly absorbing medium, and an albedo of 1 1 1 means a perfectly scattering medium (no absorption). The scattering eccentricity parameter will likewise override the global setting if it is present. Scattering eccentricity indicates how much scattered light favors the forward direction, as fit by the Henyey-Greenstein function:
	P(theta) = (1 - g*g) / (1 + g*g - 2*g*cos(theta))^1.5
A perfectly isotropic scattering medium has a g parameter of 0, and a highly directional material has a g parameter close to 1. Fits to the g parameter may be found along with typical extinction coefficients and scattering albedos for various atmospheres and cloud types in USGS meteorological tables. (A pattern will be applied to the extinction values.)
	mod mist id
	N src1 src2 .. srcN
	0|3|6|7 [ rext gext bext [ ralb galb balb [ g ] ] ]
There are two usual uses of the mist type. One is to surround a beam from a spotlight or laser so that it is visible during rendering. For this application, it is important to use a cone (or cylinder) that is long enough and wide enough to contain the important visible portion. Light source photometry and intervening objects will have the desired effect, and crossing beams will result in additive scattering. For this application, it is best to leave off the real arguments, and use the global rendering parameters to control the atmosphere. The second application is to model clouds or other localized media. Complex boundary geometry may be used to give shape to a uniform medium, so long as the boundary encloses a proper volume. Alternatively, a pattern may be used to set the line integral value through the cloud for a ray entering or exiting a point in a given direction. For this application, it is best if cloud volumes do not overlap each other, and opaque objects contained within them may not be illuminated correctly unless the line integrals consider enclosed geometry.
Plastic
Plastic is a material with uncolored highlights. It is given by its RGB reflectance, its fraction of specularity, and its roughness value. Roughness is specified as the rms slope of surface facets. A value of 0 corresponds to a perfectly smooth surface, and a value of 1 would be a very rough surface. Specularity fractions greater than 0.1 and roughness values greater than 0.2 are not very realistic. (A pattern modifying plastic will affect the material color.)
        mod plastic id
        5 red green blue spec rough
Metal
Metal is similar to plastic, but specular highlights are modified by the material color. Specularity of metals is usually .9 or greater. As for plastic, roughness values above .2 are uncommon.
Trans
Trans is a translucent material, similar to plastic. The transmissivity is the fraction of penetrating light that travels all the way through the material. The transmitted specular component is the fraction of transmitted light that is not diffusely scattered. Transmitted and diffusely reflected light is modified by the material color. Translucent objects are infinitely thin.
        mod trans id
        7 red green blue spec rough trans tspec
Plastic2
Plastic2 is similar to plastic, but with anisotropic roughness. This means that highlights in the surface will appear elliptical rather than round. The orientation of the anisotropy is determined by the unnormalized direction vector ux uy uz. These three expressions (separated by white space) are evaluated in the context of the function file funcfile. If no function file is required (i.e., no special variables or functions are required), a period (`.') may be given in its place. (See the discussion of Function Files in the Auxiliary Files section). The urough value defines the roughness along the u vector given projected onto the surface. The vrough value defines the roughness perpendicular to this vector. Note that the highlight will be narrower in the direction of the smaller roughness value. Roughness values of zero are not allowed for efficiency reasons since the behavior would be the same as regular plastic in that case.
        mod plastic2 id
        4+ ux uy uz funcfile transform
        6 red green blue spec urough vrough
Metal2
Metal2 is the same as plastic2, except that the highlights are modified by the material color.
Trans2
Trans2 is the anisotropic version of trans. The string arguments are the same as for plastic2, and the real arguments are the same as for trans but with an additional roughness value.
        mod trans2 id
        8 red green blue spec urough vrough trans tspec
Ashik2
Ashik2 is the anisotropic reflectance model by Ashikhmin & Shirley. The string arguments are the same as for plastic2, but the real arguments have additional flexibility to specify the specular color. Also, rather than roughness, specular power is used, which has no physical meaning other than larger numbers are equivalent to a smoother surface. Unlike other material types, total reflectance is the sum of diffuse and specular colors, and should be adjusted accordingly.
	mod ashik2 id
	8 dred dgrn dblu sred sgrn sblu u-power v-power
WGMDfunc
WGMDfunc is a more programmable version of trans2, with separate modifier paths and variables to control each component. (WGMD stands for Ward-Geisler-Moroder-Duer, which is the basis for this empirical model, similar to previous ones beside Ashik2.) The specification of this material is given below.
	mod WGMDfunc id
	13+ rs_mod  rs  rs_urough rs_vrough
	    ts_mod  ts  ts_urough ts_vrough
	    td_mod
	9+  rfdif gfdif bfdif
	    rbdif gbdif bbdif
	    rtdif gtdif btdif
	    A10 ..
The sum of specular reflectance (rs), specular transmittance (ts), diffuse reflectance (rfdif gfdif bfdif for front and rbdif gbdif bbdif for back) and diffuse transmittance (rtdif gtdif btdif) should be less than 1 for each channel.
Unique to this material, separate modifier channels are provided for each component. The main modifier is used on the diffuse reflectance, both front and back. The rs_mod modifier is used for specular reflectance. If "void" is given for rs_mod, then the specular reflection color will be white. The special "inherit" keyword may also be given, in which case specular reflectance will share the main modifier. This behavior is replicated for the specular transmittance modifier ts_mod, which also has its own independent roughness expressions. Finally, the diffuse transmittance modifier is given as td_mod, which may also be "void" or "inherit". Note that any spectra or color for specular components must be carried by the named modifier(s).
The main advantage to this material over BRTDfunc and other programmable types described below is that the specular sampling is well-defined, so that all components are fully computed.
Dielectric
A dielectric material is transparent, and it refracts light as well as reflecting it. Its behavior is determined by the index of refraction and transmission coefficient in each wavelength band per unit length. Common glass has a index of refraction (n) around 1.5, and a transmission coefficient of roughly 0.92 over an inch. An additional number, the Hartmann constant, describes how the index of refraction changes as a function of wavelength. It is usually zero. (A pattern modifies only the refracted value.)
        mod dielectric id
        5 rtn gtn btn n hc
Interface
An interface is a boundary between two dielectrics. The first transmission coefficient and refractive index are for the inside; the second ones are for the outside. Ordinary dielectrics are surrounded by a vacuum (1 1 1 1).
        mod interface id
        8 rtn1 gtn1 btn1 n1 rtn2 gtn2 btn2 n2
Glass
Glass is similar to dielectric, but it is optimized for thin glass surfaces (n = 1.52). One transmitted ray and one reflected ray is produced. By using a single surface is in place of two, internal reflections are avoided. The surface orientation is irrelevant, as it is for plastic, metal, and trans. The only specification required is the transmissivity at normal incidence. (Transmissivity is the amount of light not absorbed in one traversal of the material. Transmittance -- the value usually measured -- is the total light transmitted through the pane including multiple reflections.) To compute transmissivity (tn) from transmittance (Tn) use:
        tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.0036261119/Tn
Standard 88% transmittance glass has a transmissivity of 0.96. (A pattern modifying glass will affect the transmissivity.) If a fourth real argument is given, it is interpreted as the index of refraction to use instead of 1.52.
        mod glass id
        3 rtn gtn btn
Plasfunc
Plasfunc in used for the procedural definition of plastic-like materials with arbitrary bidirectional reflectance distribution functions (BRDF's). The arguments to this material include the color and specularity, as well as the function defining the specular distribution and the auxiliary file where it may be found.
        mod plasfunc id
        2+ refl funcfile transform
        4+ red green blue spec A5 ..
The function refl takes four arguments, the x, y and z direction towards the incident light, and the solid angle subtended by the source. The solid angle is provided to facilitate averaging, and is usually ignored. The refl function should integrate to 1 over the projected hemisphere to maintain energy balance. At least four real arguments must be given, and these are made available along with any additional values to the reflectance function. Currently, only the contribution from direct light sources is considered in the specular calculation. As in most material types, the surface normal is always altered to face the incoming ray.
Metfunc
Metfunc is identical to plasfunc and takes the same arguments, but the specular component is multiplied also by the material color.
Transfunc
Transfunc is similar to plasfunc but with an arbitrary bidirectional transmittance distribution as well as a reflectance distribution. Both reflectance and transmittance are specified with the same function.
        mod transfunc id
        2+ brtd funcfile transform
        6+ red green blue rspec trans tspec A7 ..
Where trans is the total light transmitted and tspec is the non-Lambertian fraction of transmitted light. The function brtd should integrate to 1 over each projected hemisphere.
BRTDfunc
The material BRTDfunc gives the maximum flexibility over surface reflectance and transmittance, providing for spectrally-dependent specular rays and reflectance and transmittance distribution functions.
        mod BRTDfunc id
        10+  rrefl  grefl  brefl
             rtrns  gtrns  btrns
             rbrtd  gbrtd  bbrtd
             funcfile  transform
             rbdif gbdif bbdif
             rtdif gtdif btdif
             A10 ..
The variables rrefl, grefl and brefl specify the color coefficients for the ideal specular (mirror) reflection of the surface. The variables rtrns, gtrns and btrns specify the color coefficients for the ideal specular transmission. The functions rbrtd, gbrtd and bbrtd take the direction to the incident light (and its solid angle) and compute the color coefficients for the directional diffuse part of reflection and transmission. As a special case, three identical values of '0' may be given in place of these function names to indicate no directional diffuse component.
Plasdata
Plasdata is used for arbitrary BRDF's that are most conveniently given as interpolated data. The arguments to this material are the data file and coordinate index functions, as well as a function to optionally modify the data values.
        mod plasdata id
        3+n+
                func datafile
                funcfile x1 x2 .. xn transform
The coordinate indices (x1, x2, etc.) are themselves functions of the x, y and z direction to the incident light, plus the solid angle subtended by the light source (usually ignored). The data function (func) takes five variables, the interpolated value from the n-dimensional data file, followed by the x, y and z direction to the incident light and the solid angle of the source. The light source direction and size may of course be ignored by the function.
Metdata
As metfunc is to plasfunc, metdata is to plasdata. Metdata takes the same arguments as plasdata, but the specular component is modified by the given material color.
Transdata
Transdata is like plasdata but the specification includes transmittance as well as reflectance. The parameters are as follows.
        mod transdata id
        3+n+
                func datafile
BSDF
The BSDF material type loads an XML (eXtensible Markup Language) file describing a bidirectional scattering distribution function. Real arguments to this material may define additional diffuse components that augment the BSDF data. String arguments are used to define thickness for proxied surfaces and the "up" orientation for the material.
	mod BSDF id
	6+ thick BSDFfile ux uy uz funcfile transform
	0|3|6|9
		rfdif gfdif bfdif
		rbdif gbdif bbdif
		rtdif gtdif btdif
aBSDF
The aBSDF material is identical to the BSDF type with two important differences. First, proxy geometry is not supported, so there is no thickness parameter. Second, an aBSDF is assumed to have some specular through component (the ’a’ stands for "aperture"), which is treated specially during the direct calculation and when viewing the material. Based on the BSDF data, the coefficient of specular transmission is determined and used for modifying unscattered shadow and view rays.
	mod aBSDF id
	5+ BSDFfile ux uy uz funcfile transform
	0|3|6|9
	     rfdif gfdif bfdif
	     rbdif gbdif bbdif
	     rtdif gtdif btdif
If a material has no specular transmitted component, it is much better to use the BSDF type with a zero thickness than to use aBSDF.
Antimatter
Antimatter is a material that can "subtract" volumes from other volumes. A ray passing into an antimatter object becomes blind to all the specified modifiers:
        mod antimatter id
        N mod1 mod2 .. modN
The first modifier will also be used to shade the area leaving the antimatter volume and entering the regular volume. If mod1 is void, the antimatter volume is completely invisible. Antimatter does not work properly with the material type "trans", and multiple antimatter surfaces should be disjoint. The viewpoint must be outside all volumes concerned for a correct rendering.
2.1.3. Textures
A texture is a perturbation of the surface normal, and is given by either a function or data.
Texfunc
A texfunc uses an auxiliary function file to specify a procedural texture:
        mod texfunc id
        4+ xpert ypert zpert funcfile transform
        n A1 A2 .. An
Texdata
A texdata texture uses three data files to get the surface normal perturbations. The variables xfunc, yfunc and zfunc take three arguments each from the interpolated values in xdfname, ydfname and zdfname.
        mod texdata id
        8+ xfunc yfunc zfunc xdfname ydfname zdfname funcfile x0 x1 .. xf
        n A1 A2 .. An
2.1.4. Patterns
Patterns are used to modify the reflectance of materials. The basic types are given below.
Colorfunc
A colorfunc is a procedurally defined color pattern. It is specified as follows:
        mod colorfunc id
        4+ red green blue funcfile transform
        n A1 A2 .. An
Brightfunc
A brightfunc is the same as a colorfunc, except it is monochromatic.
        mod brightfunc id
        n A1 A2 .. An
Colordata
Colordata uses an interpolated data map to modify a material's color. The map is n-dimensional, and is stored in three auxiliary files, one for each color. The coordinates used to look up and interpolate the data are defined in another auxiliary file. The interpolated data values are modified by functions of one or three variables. If the functions are of one variable, then they are passed the corresponding color component (red or green or blue). If the functions are of three variables, then they are passed the original red, green, and blue values as parameters.
        mod colordata id
        7+n+
                rfunc gfunc bfunc rdatafile gdatafile bdatafile
        m A1 A2 .. Am
Brightdata
Brightdata is like colordata, except monochromatic.
        mod brightdata id
        3+n+
                func datafile
        m A1 A2 .. Am
Colorpict
Colorpict is a special case of colordata, where the pattern is a two-dimensional image stored in the RADIANCE picture format. The dimensions of the image data are determined by the picture such that the smaller dimension is always 1, and the other is the ratio between the larger and the smaller. For example, a 500x338 picture would have coordinates (u,v) in the rectangle between (0,0) and (1.48,1).
        mod colorpict id
        7+
                rfunc gfunc bfunc pictfile
                funcfile u v transform
        m A1 A2 .. Am
Colortext
Colortext is dichromatic writing in a polygonal font. The font is defined in an auxiliary file, such as helvet.fnt. The text itself is also specified in a separate file, or can be part of the material arguments. The character size, orientation, aspect ratio and slant is determined by right and down motion vectors. The upper left origin for the text block as well as the foreground and background colors must also be given.
        mod colortext id
        2 fontfile textfile
        15+
                Ox Oy Oz
                Rx Ry Rz
                Dx Dy Dz
                rfore gfore bfore
                rback gback bback
                [spacing]
or:
        mod colortext id
        2+N fontfile . This is a line with N words ...
        15+
                Ox Oy Oz
                Rx Ry Rz
                Dx Dy Dz
                rfore gfore bfore
                rback gback bback
                [spacing]
Brighttext
Brighttext is like colortext, but the writing is monochromatic.
        mod brighttext id
        2 fontfile textfile
        11+
                Ox Oy Oz
                Rx Ry Rz
                Dx Dy Dz
                foreground background
                [spacing]
or:
        mod brighttext id
        11+
                Ox Oy Oz
                Rx Ry Rz
                Dx Dy Dz
                [spacing]
Spectrum
The spectrum primitive is the most basic type for introducing spectral color to a material. Since materials only provide RGB parameters, spectral patterns are the only way to superimpose wavelength-dependent behavior.
        mod spectrum id
	5+ nmA nmB s1 s2 .. sN
The first two real arguments indicate the extrema of the spectral range in nanometers. Subsequent real values correspond to multipliers at each wavelength. The nmA wavelength may be greater or less than nmB, but they may not be equal, and their ordering matches the order of the spectral values. A minimum of 3 values must be given, which would act more or less the same as a constant RGB multiplier. As with RGB values, spectral quantities normally range between 0 and 1 at each wavelength, or average to 1.0 against a standard sensitivity functions such as V(lambda). The best results obtain when the spectral range and number of samples match rendering options, though resampling will handle any differences, zero-filling wavelenths outside the nmA to nmB range. A warning will be issued if the given wavelength range does not adequately cover the visible spectrum.
Specfile
The specfile primitive is equivalent to the spectrum type, but the wavelength range and values are contained in a 1-dimensional data file. This may be a more convenient way to specify a spectral color, especially one corresponding to a standard illuminant such as D65 or a library of measured spectra.
        mod specfile id
	1 datafile
As with the spectrum type, rendering wavelengths outside the defined range will be zero-filled. Unlike the spectrum type, the file may contain non-uniform samples.
Specfunc
The specfunc primitive offers dynamic control over a spectral pattern, similar to the colorfunc type.
        mod specfunc id
	2+ sfunc funcfile transform
	2+ nmA nmB A3 ..
Like the spectrum primitive, the wavelength range is specified in the first two real arguments, and additional real values are set in the evaluation context. This function is fed a wavelenth sample between nmA and nmB as its only argument, and it returns the corresponding spectral intensity.
Specdata
Specdata is like brightdata and colordata, but with more than 3 specular samples.
	mod specdata id
	3+n+
		func datafile
	m A1 A2 .. Am
The data file must have one more dimension than the coordinate variable count, as this final dimension corresponds to the covered spectrum. The starting and ending wavelengths are specified in "datafile" as well as the number of spectral samples. The function "func" will be called with two parameters, the interpolated spectral value for the current coordinate and the associated wavelength. If the spectrum is broken into 12 components, then 12 calls will be made to "func" for the relevant ray evaluation.
Specpict
Specpict is a special case of specdata, where the pattern is a hyperspectral image stored in the common-exponent file format. The dimensions of the image data are determined by the picture just as with the colorpict primitive.
	mod specpict id
	5+
		func specfile
	m A1 A2 .. Am
The function "func" is called with the interpolated pixel value and the wavelength sample in nanometers, the same as specdata, with as many calls made as there are components in "specfile".
2.1.5. Mixtures
A mixture is a blend of one or more materials or textures and patterns. Blended materials should not be light source types or virtual source types. The basic types are given below.
Mixfunc
A mixfunc mixes two modifiers procedurally. It is specified as follows:
        mod mixfunc id
        4+ foreground background vname funcfile transform
        n A1 A2 .. An
Foreground and background are modifier names that must be defined earlier in the scene description. If one of these is a material, then the modifier of the mixfunc must be "void". (Either the foreground or background modifier may be "void", which serves as a form of opacity control when used with a material.) Vname is the coefficient defined in funcfile that determines the influence of foreground. The background coefficient is always (1-vname).
Mixdata
Mixdata combines two modifiers using an auxiliary data file:
        mod mixdata id
        5+n+
                foreground background func datafile
        m A1 A2 .. Am
Mixpict
Mixpict combines two modifiers based on a picture:
        mod mixpict id
        7+
                foreground background func pictfile
        m A1 A2 .. Am
Mixtext
Mixtext uses one modifier for the text foreground, and one for the background:
        mod mixtext id
        4 foreground background fontfile textfile
        9+
                Ox Oy Oz
                Rx Ry Rz
                Dx Dy Dz
                [spacing]
or:
        mod mixtext id
        4+N
                foreground background fontfile .
        9+
                Ox Oy Oz
                Rx Ry Rz
                Dx Dy Dz
                [spacing]
2.2. Auxiliary Files
Auxiliary files used in textures and patterns are accessed by the programs during image generation. These files may be located in the working directory, or in a library directory. The environment variable RAYPATH can be assigned an alternate set of search directories. Following is a brief description of some common file types.
12.2.1. Function Files
A function file contains the definitions of variables, functions and constants used by a primitive. The transformation that accompanies the file name contains the necessary rotations, translations and scalings to bring the coordinates of the function file into agreement with the world coordinates. The transformation specification is the same as for the xform command. An example function file is given below:
                This is a comment, enclosed in curly braces.
                {Comments can be nested.}
                                { standard expressions use +,-,*,/,^,(,) }
        vname = Ny * func(A1) ;
                                { constants are defined with a colon }
        const : sqrt(PI/2) ;
                                { user-defined functions add to library }
        func(x) = 5 + A1*sin(x/3) ;
                                { functions may be passed and recursive }
        rfunc(f,x) = if(x,f(x),f(-x)*rfunc(f,x+1)) ;
                                { constant functions may also be defined }
        cfunc(x) : 10*x / sqrt(x) ;
Many variables and functions are already defined by the program, and they are listed in the file rayinit.cal. The following variables are particularly important:
                Dx, Dy, Dz              - incident ray direction
                Nx, Ny, Nz              - surface normal at intersection point
                Px, Py, Pz              - intersection point
		T			- distance from start
		Ts			- single ray (shadow) distance
                Rdot                    - cosine between ray and normal
                arg(0)                  - number of real arguments
                arg(i)                  - i'th real argument
For mesh objects, the local surface coordinates are available:
        	Lu, Lv                  - local (u,v) coordinates
For BRDF types, the following variables are defined as well:
                NxP, NyP, NzP           - perturbed surface normal
                RdotP                   - perturbed dot product
                CrP, CgP, CbP           - perturbed material color
A unique context is set up for each file so that the same variable may appear in different function files without conflict. The variables listed above and any others defined in rayinit.cal are available globally. If no file is needed by a given primitive because all the required variables are global, a period (`.') can be given in place of the file name. It is also possible to give an expression instead of a straight variable name in a scene file. Functions (requiring parameters) must be given as names and not as expressions.
2.2.2. Data Files
Data files contain n-dimensional arrays of real numbers used for interpolation. Typically, definitions in a function file determine how to index and use interpolated data values. The basic data file format is as follows:
        N
        beg1 end1 m1
        0 0 m2 x2.1 x2.2 x2.3 x2.4 .. x2.m2
        begN endN mN
        DATA, later dimensions changing faster.
N is the number of dimensions. For each dimension, the beginning and ending coordinate values and the dimension size is given. Alternatively, individual coordinate values can be given when the points are not evenly spaced. These values must either be increasing or decreasing monotonically. The data is m1*m2*...*mN real numbers in ASCII form. Comments may appear anywhere in the file, beginning with a pound sign ('#') and continuing to the end of line.
2.2.3. Font Files
A font file lists the polygons which make up a character set. Comments may appear anywhere in the file, beginning with a pound sign ('#') and continuing to the end of line. All numbers are decimal integers:
        code n
                x0 y0
                x1 y1
                xn yn
The ASCII codes can appear in any order. N is the number of vertices, and the last is automatically connected to the first. Separate polygonal sections are joined by coincident sides. The character coordinate system is a square with lower left corner at (0,0), lower right at (255,0) and upper right at (255,255).
2.3. Generators
A generator is any program that produces a scene description as its output. They usually appear as commands in a scene description file. An example of a simple generator is genbox.
3. Image Generation
Once the scene has been described in three-dimensions, it is possible to generate a two-dimensional image from a given perspective.
4. License
The Radiance Software License, Version 2.0
Radiance v6.0 Copyright (c) 1990 to 2025, The Regents of the University of
California, through Lawrence Berkeley National Laboratory (subject to receipt
of any required approvals from the U.S. Dept. of Energy).  All rights reserved.
modification, are permitted provided that the following conditions are met:
(1) Redistributions of source code must retain the above copyright notice,
this list of conditions and the following disclaimer.
(2) Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
(3) Neither the name of the University of California, Lawrence Berkeley
National Laboratory, U.S. Dept. of Energy nor the names of its contributors
may be used to endorse or promote products derived from this software
without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
POSSIBILITY OF SUCH DAMAGE.
You are under no obligation whatsoever to provide any bug fixes, patches,
or upgrades to the features, functionality or performance of the source
code ("Enhancements") to anyone; however, if you choose to make your
Enhancements available either publicly, or directly to Lawrence Berkeley
National Laboratory, without imposing a separate written license agreement
for such Enhancements, then you hereby grant the following license: a
non-exclusive, royalty-free perpetual license to install, use, modify,
prepare derivative works, incorporate into other computer software,
distribute, and sublicense such enhancements or derivative works thereof,
in binary and source code form.
5. Acknowledgements
This work was supported by the Assistant Secretary of Conservation and Renewable Energy, Office of Building Energy Research and Development, Buildings Equipment Division of the U.S. Department of Energy under Contract No. DE-AC03-76SF00098.
6. References
7. Types Index
Last Update: October 22, 1997
