The diagram in Figure 1 shows the flow between programs (boxes) and data
(ovals).
The central program is rpict, which produces a picture from a scene
description.
Rvu is a variation of rpict that computes and displays images
interactively, and rtrace computes single ray values.
Other programs (not shown) connect many of these elements together,
such as the executive programs
and
ranimate,
the interactive rendering program
rholo,
and the animation program
ranimove.
The program
obj2mesh
acts as both a converter and scene compiler, converting a Wavefront .OBJ
file into a compiled mesh octree for efficient rendering.
A scene description file lists the surfaces and materials
that make up a specific environment.
The current surface types are spheres, polygons, cones, and cylinders.
There is also a composite surface type, called mesh, and a pseudosurface
type, called instance, which facilitates very complex geometries.
Surfaces can be made from materials such as plastic, metal, and glass.
Light sources can be distant disks as well as local spheres, disks
and polygons.
From a three-dimensional scene description and a specified view,
rpict produces a two-dimensional image.
A picture file is a compressed binary representation of the
pixels in the image.
This picture can be scaled in size and brightness,
anti-aliased, and sent to a graphics output device.
A header in each picture file lists the program(s)
and parameters that produced it.
This is useful for identifying a picture without having to display it.
The information can be read by the program getinfo.
The scene description primitives
all have the same general format, and can be either surfaces or modifiers.
A primitive has a modifier, a type, and an identifier.
A modifier is either the
identifier of a previously defined primitive, or "void".
An identifier can be any string
(i.e., any sequence of non-white characters).
An alias gets its type and arguments from
a previously defined primitive.
This is useful when the same material is
used with a different modifier, or as a convenient naming mechanism.
The reserved modifier name "inherit" may be used to specificy that
an alias will inherit its modifier from the original.
Surfaces cannot be aliased.
A line beginning with an exclamation point, `!',
is interpreted as a command.
It is executed by the shell, and its output is read as input to the program.
The command must not try to read from its standard input, or confusion
will result.
A command may be continued over multiple lines using a
backslash, `\', to escape the newline.
White space is generally ignored, except as a separator.
The exception is the newline character after a command or comment.
Commands, comments and primitives may appear in any
combination, so long as they are not intermingled.
RADIANCE was developed as a research tool for predicting
the distribution of visible radiation in illuminated spaces.
It takes as input a three-dimensional geometric model
of the physical environment, and produces a map of
spectral radiance values in a color image.
The technique of ray-tracing follows light backwards
from the image plane to the source(s).
Because it can produce realistic images from a
simple description, RADIANCE has a wide range of applications
in graphic arts, lighting design,
computer-aided engineering and architecture.
A scene description file represents a three-dimensional physical environment in Cartesian (rectilinear) world coordinates.
It is stored as ASCII text, with the following basic format:
[ The most recent definition of a modifier is the
one used, and later definitions do not cause relinking
of loaded primitives.
Thus, the same identifier may be used repeatedly,
and each new definition will apply to the primitives following it. ]
Primitives can be surfaces,
materials,
textures or
patterns.
Modifiers can be materials,
mixtures,
textures or patterns.
Simple surfaces must have one material in their modifier list.
mod source id 0 0 4 xdir ydir zdir angle
mod sphere id 0 0 4 xcent ycent zcent radius
mod polygon id 0 0 3n x1 y1 z1 x2 y2 z2 ... xn yn zn
mod cone id 0 0 8 x0 y0 z0 x1 y1 z1 r0 r1
mod cylinder id 0 0 7 x0 y0 z0 x1 y1 z1 rad
mod ring id 0 0 8 xcent ycent zcent xdir ydir zdir r0 r1
mod instance id 1+ octree transform 0 0
If the modifier is "void", then surfaces will use the modifiers given in the original description. Otherwise, the modifier specified is used in their place. The transform moves the octree to the desired location in the scene. Multiple instances using the same octree take little extra memory, hence very complex descriptions can be rendered using this primitive.
mod mesh id 1+ meshfile transform 0 0
If the modifier is "void", then surfaces will use the modifiers given in the original mesh description. Otherwise, the modifier specified is used in their place. The transform moves the mesh to the desired location in the scene. Multiple instances using the same meshfile take little extra memory, and the compiled mesh itself takes much less space than individual polygons would. In the case of an unsmoothed mesh, using the mesh primitive reduces memory requirements by a factor of 30 relative to individual triangles. If a mesh has smoothed surfaces, we save a factor of 50 or more, permitting very detailed geometries that would otherwise exhaust the available memory. In addition, the mesh primitive can have associated (u,v) coordinates for pattern and texture mapping. These are made available to function files via the Lu and Lv variables.
mod light id 0 0 3 red green blue
mod illum id 1 material 0 3 red green blue
mod glow id 0 0 4 red green blue maxrad
If maxrad is zero, then the surface will never be tested for shadow, although it may participate in an interreflection calculation. If maxrad is negative, then the surface will never contribute to scene illumination. Glow sources will never illuminate objects on the other side of an illum surface. This provides a convenient way to illuminate local light fixture geometry without overlighting nearby objects.
mod spotlight id 0 0 7 red green blue angle xdir ydir zdir
mod mirror id 1 material 0 3 red green blueWhile alternate materials that are reflective will appear as normal, indirect rays will use the mirror's reflectance rather than the alternate type. Transmitting materials are an exception, where both transmission and reflection will use the alternate type for all rays not specifically targeting virtual light sources. In this case, it is important that any reflections be purely specular (mirror-like) and equal to the mirror's reflectivity to maintain a valid result. A pure diffuse reflection may be added if desired.
The mirror material type reflects light sources only from the front side of a surface, regardless of any alternate material. If virtual source generation is desired on both sides, two coincident surfaces with opposite normal orientations may be employed to achieve this effect. The reflectance and alternate material type may be different for the overlapped surfaces, and the two sides will behave accordingly.
mod prism1 id 5+ coef dx dy dz funcfile transform 0 n A1 A2 .. An
The new direction variables dx, dy and dz need not produce a normalized vector. For convenience, the variables DxA, DyA and DzA are defined as the normalized direction to the target light source. See section 2.2.1 on function files for further information.
mod prism2 id 9+ coef1 dx1 dy1 dz1 coef2 dx2 dy2 dz2 funcfile transform 0 n A1 A2 .. An
3 source1 mirror1>source10 mirror2>mirror1>source3
Normally, only one source is given per mist material, and there is an upper limit of 32 to the total number of active scattering sources. The extinction coefficient, if given, is added the the global coefficient set on the command line. Extinction is in units of 1/distance (distance based on the world coordinates), and indicates the proportional loss of radiance over one unit distance. The scattering albedo, if present, will override the global setting within the volume. An albedo of 0 0 0 means a perfectly absorbing medium, and an albedo of 1 1 1 means a perfectly scattering medium (no absorption). The scattering eccentricity parameter will likewise override the global setting if it is present. Scattering eccentricity indicates how much scattered light favors the forward direction, as fit by the Henyey-Greenstein function:
P(theta) = (1 - g*g) / (1 + g*g - 2*g*cos(theta))^1.5
A perfectly isotropic scattering medium has a g parameter of 0, and a highly directional material has a g parameter close to 1. Fits to the g parameter may be found along with typical extinction coefficients and scattering albedos for various atmospheres and cloud types in USGS meteorological tables. (A pattern will be applied to the extinction values.)
mod mist id N src1 src2 .. srcN 0 0|3|6|7 [ rext gext bext [ ralb galb balb [ g ] ] ]
There are two usual uses of the mist type. One is to surround a beam from a spotlight or laser so that it is visible during rendering. For this application, it is important to use a cone (or cylinder) that is long enough and wide enough to contain the important visible portion. Light source photometry and intervening objects will have the desired effect, and crossing beams will result in additive scattering. For this application, it is best to leave off the real arguments, and use the global rendering parameters to control the atmosphere. The second application is to model clouds or other localized media. Complex boundary geometry may be used to give shape to a uniform medium, so long as the boundary encloses a proper volume. Alternatively, a pattern may be used to set the line integral value through the cloud for a ray entering or exiting a point in a given direction. For this application, it is best if cloud volumes do not overlap each other, and opaque objects contained within them may not be illuminated correctly unless the line integrals consider enclosed geometry.
mod plastic id 0 0 5 red green blue spec rough
mod trans id 0 0 7 red green blue spec rough trans tspec
mod plastic2 id 4+ ux uy uz funcfile transform 0 6 red green blue spec urough vrough
mod trans2 id 4+ ux uy uz funcfile transform 0 8 red green blue spec urough vrough trans tspec
mod ashik2 id 4+ ux uy uz funcfile transform 0 8 dred dgrn dblu sred sgrn sblu u-power v-power
mod WGMDfunc id 13+ rs_mod rs rs_urough rs_vrough ts_mod ts ts_urough ts_vrough td_mod ux uy uz funcfile transform 0 9+ rfdif gfdif bfdif rbdif gbdif bbdif rtdif gtdif btdif A10 ..
The sum of specular reflectance (rs), specular transmittance (ts), diffuse reflectance (rfdif gfdif bfdif for front and rbdif gbdif bbdif for back) and diffuse transmittance (rtdif gtdif btdif) should be less than 1 for each channel.
Unique to this material, separate modifier channels are provided for each component. The main modifier is used on the diffuse reflectance, both front and back. The rs_mod modifier is used for specular reflectance. If "void" is given for rs_mod, then the specular reflection color will be white. The special "inherit" keyword may also be given, in which case specular reflectance will share the main modifier. This behavior is replicated for the specular transmittance modifier ts_mod, which also has its own independent roughness expressions. Finally, the diffuse transmittance modifier is given as td_mod, which may also be "void" or "inherit". Note that any spectra or color for specular components must be carried by the named modifier(s).
The main advantage to this material over BRTDfunc and other programmable types described below is that the specular sampling is well-defined, so that all components are fully computed.
mod dielectric id 0 0 5 rtn gtn btn n hc
mod interface id 0 0 8 rtn1 gtn1 btn1 n1 rtn2 gtn2 btn2 n2
tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.0036261119/Tn
Standard 88% transmittance glass has a transmissivity of 0.96. (A pattern modifying glass will affect the transmissivity.) If a fourth real argument is given, it is interpreted as the index of refraction to use instead of 1.52.
mod glass id 0 0 3 rtn gtn btn
mod plasfunc id 2+ refl funcfile transform 0 4+ red green blue spec A5 ..
The function refl takes four arguments, the x, y and z direction towards the incident light, and the solid angle subtended by the source. The solid angle is provided to facilitate averaging, and is usually ignored. The refl function should integrate to 1 over the projected hemisphere to maintain energy balance. At least four real arguments must be given, and these are made available along with any additional values to the reflectance function. Currently, only the contribution from direct light sources is considered in the specular calculation. As in most material types, the surface normal is always altered to face the incoming ray.
mod transfunc id 2+ brtd funcfile transform 0 6+ red green blue rspec trans tspec A7 ..
Where trans is the total light transmitted and tspec is the non-Lambertian fraction of transmitted light. The function brtd should integrate to 1 over each projected hemisphere.
mod BRTDfunc id 10+ rrefl grefl brefl rtrns gtrns btrns rbrtd gbrtd bbrtd funcfile transform 0 9+ rfdif gfdif bfdif rbdif gbdif bbdif rtdif gtdif btdif A10 ..
The variables rrefl, grefl and brefl specify the color coefficients for the ideal specular (mirror) reflection of the surface. The variables rtrns, gtrns and btrns specify the color coefficients for the ideal specular transmission. The functions rbrtd, gbrtd and bbrtd take the direction to the incident light (and its solid angle) and compute the color coefficients for the directional diffuse part of reflection and transmission. As a special case, three identical values of '0' may be given in place of these function names to indicate no directional diffuse component.
mod plasdata id 3+n+ func datafile funcfile x1 x2 .. xn transform 0 4+ red green blue spec A5 ..
The coordinate indices (x1, x2, etc.) are themselves functions of the x, y and z direction to the incident light, plus the solid angle subtended by the light source (usually ignored). The data function (func) takes five variables, the interpolated value from the n-dimensional data file, followed by the x, y and z direction to the incident light and the solid angle of the source. The light source direction and size may of course be ignored by the function.
mod transdata id 3+n+ func datafile funcfile x1 x2 .. xn transform 0 6+ red green blue rspec trans tspec A7 ..
mod BSDF id 6+ thick BSDFfile ux uy uz funcfile transform 0 0|3|6|9 rfdif gfdif bfdif rbdif gbdif bbdif rtdif gtdif btdif
mod aBSDF id 5+ BSDFfile ux uy uz funcfile transform 0 0|3|6|9 rfdif gfdif bfdif rbdif gbdif bbdif rtdif gtdif btdif
If a material has no specular transmitted component, it is much better to use the BSDF type with a zero thickness than to use aBSDF.
mod antimatter id N mod1 mod2 .. modN 0 0
The first modifier will also be used to shade the area leaving the antimatter volume and entering the regular volume. If mod1 is void, the antimatter volume is completely invisible. Antimatter does not work properly with the material type "trans", and multiple antimatter surfaces should be disjoint. The viewpoint must be outside all volumes concerned for a correct rendering.
mod texfunc id 4+ xpert ypert zpert funcfile transform 0 n A1 A2 .. An
mod texdata id 8+ xfunc yfunc zfunc xdfname ydfname zdfname vfname x0 x1 .. xf 0 n A1 A2 .. An
mod colorfunc id 4+ red green blue funcfile transform 0 n A1 A2 .. An
mod brightfunc id 2+ refl funcfile transform 0 n A1 A2 .. An
mod colordata id 7+n+ rfunc gfunc bfunc rdatafile gdatafile bdatafile funcfile x1 x2 .. xn transform 0 m A1 A2 .. Am
mod brightdata id 3+n+ func datafile funcfile x1 x2 .. xn transform 0 m A1 A2 .. Am
mod colorpict id 7+ rfunc gfunc bfunc pictfile funcfile u v transform 0 m A1 A2 .. Am
mod colortext id 2 fontfile textfile 0 15+ Ox Oy Oz Rx Ry Rz Dx Dy Dz rfore gfore bfore rback gback bback [spacing]
or:
mod colortext id 2+N fontfile . This is a line with N words ... 0 15+ Ox Oy Oz Rx Ry Rz Dx Dy Dz rfore gfore bfore rback gback bback [spacing]
mod brighttext id 2 fontfile textfile 0 11+ Ox Oy Oz Rx Ry Rz Dx Dy Dz foreground background [spacing]
or:
mod brighttext id 2+N fontfile . This is a line with N words ... 0 11+ Ox Oy Oz Rx Ry Rz Dx Dy Dz foreground background [spacing]
mod spectrum id 0 0 5+ nmA nmB s1 s2 .. sN
The first two real arguments indicate the extrema of the spectral range in nanometers. Subsequent real values correspond to multipliers at each wavelength. The nmA wavelength may be greater or less than nmB, but they may not be equal, and their ordering matches the order of the spectral values. A minimum of 3 values must be given, which would act more or less the same as a constant RGB multiplier. As with RGB values, spectral quantities normally range between 0 and 1 at each wavelength, or average to 1.0 against a standard sensitivity functions such as V(lambda). The best results obtain when the spectral range and number of samples match rendering options, though resampling will handle any differences, zero-filling wavelenths outside the nmA to nmB range. A warning will be issued if the given wavelength range does not adequately cover the visible spectrum.
mod specfile id 1 datafile 0 0
As with the spectrum type, rendering wavelengths outside the defined range will be zero-filled. Unlike the spectrum type, the file may contain non-uniform samples.
mod specfunc id 2+ sfunc funcfile transform 0 2+ nmA nmB A3 ..
Like the spectrum primitive, the wavelength range is specified in the first two real arguments, and additional real values are set in the evaluation context. This function is fed a wavelenth sample between nmA and nmB as its only argument, and it returns the corresponding spectral intensity.
mod specdata id 3+n+ func datafile funcfile x1 x2 .. xn transform 0 m A1 A2 .. Am
The data file must have one more dimension than the coordinate variable count, as this final dimension corresponds to the covered spectrum. The starting and ending wavelengths are specified in "datafile" as well as the number of spectral samples. The function "func" will be called with two parameters, the interpolated spectral value for the current coordinate and the associated wavelength. If the spectrum is broken into 12 components, then 12 calls will be made to "func" for the relevant ray evaluation.
mod specpict id 5+ func specfile funcfile u v transform 0 m A1 A2 .. Am
The function "func" is called with the interpolated pixel value and the wavelength sample in nanometers, the same as specdata, with as many calls made as there are components in "specfile".
mod mixfunc id 4+ foreground background vname funcfile transform 0 n A1 A2 .. An
Foreground and background are modifier names that must be defined earlier in the scene description. If one of these is a material, then the modifier of the mixfunc must be "void". (Either the foreground or background modifier may be "void", which serves as a form of opacity control when used with a material.) Vname is the coefficient defined in funcfile that determines the influence of foreground. The background coefficient is always (1-vname).
mod mixdata id 5+n+ foreground background func datafile funcfile x1 x2 .. xn transform 0 m A1 A2 .. Am
mod mixpict id 7+ foreground background func pictfile funcfile u v transform 0 m A1 A2 .. Am
mod mixtext id 4 foreground background fontfile textfile 0 9+ Ox Oy Oz Rx Ry Rz Dx Dy Dz [spacing]
or:
mod mixtext id 4+N foreground background fontfile . This is a line with N words ... 0 9+ Ox Oy Oz Rx Ry Rz Dx Dy Dz [spacing]
{ This is a comment, enclosed in curly braces. {Comments can be nested.} } { standard expressions use +,-,*,/,^,(,) } vname = Ny * func(A1) ; { constants are defined with a colon } const : sqrt(PI/2) ; { user-defined functions add to library } func(x) = 5 + A1*sin(x/3) ; { functions may be passed and recursive } rfunc(f,x) = if(x,f(x),f(-x)*rfunc(f,x+1)) ; { constant functions may also be defined } cfunc(x) : 10*x / sqrt(x) ;
Many variables and functions are already defined by the program, and they are listed in the file rayinit.cal. The following variables are particularly important:
Dx, Dy, Dz - incident ray direction Nx, Ny, Nz - surface normal at intersection point Px, Py, Pz - intersection point T - distance from start Ts - single ray (shadow) distance Rdot - cosine between ray and normal arg(0) - number of real arguments arg(i) - i'th real argument
For mesh objects, the local surface coordinates are available:
Lu, Lv - local (u,v) coordinates
For BRDF types, the following variables are defined as well:
NxP, NyP, NzP - perturbed surface normal RdotP - perturbed dot product CrP, CgP, CbP - perturbed material color
A unique context is set up for each file so that the same variable may appear in different function files without conflict. The variables listed above and any others defined in rayinit.cal are available globally. If no file is needed by a given primitive because all the required variables are global, a period (`.') can be given in place of the file name. It is also possible to give an expression instead of a straight variable name in a scene file. Functions (requiring parameters) must be given as names and not as expressions.
N beg1 end1 m1 0 0 m2 x2.1 x2.2 x2.3 x2.4 .. x2.m2 ... begN endN mN DATA, later dimensions changing faster.
N is the number of dimensions. For each dimension, the beginning and ending coordinate values and the dimension size is given. Alternatively, individual coordinate values can be given when the points are not evenly spaced. These values must either be increasing or decreasing monotonically. The data is m1*m2*...*mN real numbers in ASCII form. Comments may appear anywhere in the file, beginning with a pound sign ('#') and continuing to the end of line.
code n x0 y0 x1 y1 ... xn yn ...
The ASCII codes can appear in any order. N is the number of vertices, and the last is automatically connected to the first. Separate polygonal sections are joined by coincident sides. The character coordinate system is a square with lower left corner at (0,0), lower right at (255,0) and upper right at (255,255).
Copyright (c) 1990 - 2021 The Regents of the University of California,
through Lawrence Berkeley National Laboratory. All rights reserved.
permission, please contact [email protected].
THIS SOFTWARE IS PROVIDED ``AS IS" AND ANY EXPRESSED OR IMPLIED
DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
