| 1 |
<html>
| 2 |
<!-- RCSid $Id: ray.html,v 1.23 2016/07/10 23:41:37 greg Exp $ -->
| 3 |
<head>
| 4 |
<title>
| 5 |
The RADIANCE 5.2 Synthetic Imaging System
| 6 |
</title>
| 7 |
</head>
| 8 |
<body>
| 9 |
| 10 |
<p>
| 11 |
| 12 |
<h1>
| 13 |
| 14 |
</h1>
| 15 |
| 16 |
<p>
| 17 |
| 18 |
Building Technologies Program<br>
| 19 |
Lawrence Berkeley National Laboratory<br>
| 20 |
1 Cyclotron Rd., 90-3111<br>
| 21 |
Berkeley, CA 94720<br>
| 22 |
<a HREF="http://radsite.lbl.gov/radiance"</a>
| 23 |
http://radsite.lbl.gov/radiance<br>
| 24 |
| 25 |
<p>
| 26 |
<hr>
| 27 |
| 28 |
<h2>
| 29 |
<a NAME="Overview">Overview</a>
| 30 |
</h2>
| 31 |
<ol>
| 32 |
<li><a HREF="#Intro">Introduction</a><!P>
| 33 |
<li><a HREF="#Scene">Scene Description</a><!P>
| 34 |
<ol>
| 35 |
<li><a HREF="#Primitive"> Primitive Types</a>
| 36 |
<ol>
| 37 |
<li><a HREF="#Surfaces">Surfaces</a>
| 38 |
<li><a HREF="#Materials">Materials</a>
| 39 |
<li><a HREF="#Textures">Textures</a>
| 40 |
<li><a HREF="#Patterns">Patterns</a>
| 41 |
<li><a HREF="#Mixtures">Mixtures</a>
| 42 |
</ol><!P>
| 43 |
<li><a HREF="#Auxiliary">Auxiliary Files</a>
| 44 |
<ol>
| 45 |
<li><a HREF="#Function">Function Files</a>
| 46 |
<li><a HREF="#Data">Data Files</a>
| 47 |
<li><a HREF="#Font">Font Files</a>
| 48 |
</ol><!P>
| 49 |
<li><a HREF="#Generators">Generators</a>
| 50 |
</ol><!P>
| 51 |
<li><a HREF="#Image">Image Generation</a><!P>
| 52 |
<li><a HREF="#License">License</a><!P>
| 53 |
<li><a HREF="#Ack">Acknowledgements</a><!P>
| 54 |
<li><a HREF="#Ref">References</a><!P>
| 55 |
<li><a HREF="#Index">Types Index</a><!P>
| 56 |
</ol>
| 57 |
| 58 |
<p>
| 59 |
<hr>
| 60 |
| 61 |
<h2>
| 62 |
<a NAME="Intro">1. Introduction</a>
| 63 |
</h2>
| 64 |
| 65 |
RADIANCE was developed as a research tool for predicting
| 66 |
the distribution of visible radiation in illuminated spaces.
| 67 |
It takes as input a three-dimensional geometric model
| 68 |
of the physical environment, and produces a map of
| 69 |
spectral radiance values in a color image.
| 70 |
The technique of ray-tracing follows light backwards
| 71 |
from the image plane to the source(s).
| 72 |
Because it can produce realistic images from a
| 73 |
simple description, RADIANCE has a wide range of applications
| 74 |
in graphic arts, lighting design,
| 75 |
computer-aided engineering and architecture.
| 76 |
| 77 |
<p>
| 78 |
<img SRC="diagram1.gif">
| 79 |
<p>
| 80 |
Figure 1
| 81 |
<p>
| 82 |
The diagram in Figure 1 shows the flow between programs (boxes) and data
| 83 |
(ovals).
| 84 |
The central program is <i>rpict</i>, which produces a picture from a scene
| 85 |
description.
| 86 |
<i>Rview</i> is a variation of rpict that computes and displays images
| 87 |
interactively, and rtrace computes single ray values.
| 88 |
Other programs (not shown) connect many of these elements together,
| 89 |
such as the executive programs
| 90 |
<i>rad</i>
| 91 |
and
| 92 |
<i>ranimate</i>,
| 93 |
the interactive rendering program
| 94 |
<i>rholo</i>,
| 95 |
and the animation program
| 96 |
<i>ranimove</i>.
| 97 |
The program
| 98 |
<i>obj2mesh</i>
| 99 |
acts as both a converter and scene compiler, converting a Wavefront .OBJ
| 100 |
file into a compiled mesh octree for efficient rendering.
| 101 |
| 102 |
<p>
| 103 |
A scene description file lists the surfaces and materials
| 104 |
that make up a specific environment.
| 105 |
The current surface types are spheres, polygons, cones, and cylinders.
| 106 |
There is also a composite surface type, called mesh, and a pseudosurface
| 107 |
type, called instance, which facilitates very complex geometries.
| 108 |
Surfaces can be made from materials such as plastic, metal, and glass.
| 109 |
Light sources can be distant disks as well as local spheres, disks
| 110 |
and polygons.
| 111 |
| 112 |
<p>
| 113 |
From a three-dimensional scene description and a specified view,
| 114 |
<i>rpict</i> produces a two-dimensional image.
| 115 |
A picture file is a compressed binary representation of the
| 116 |
pixels in the image.
| 117 |
This picture can be scaled in size and brightness,
| 118 |
anti-aliased, and sent to a graphics output device.
| 119 |
| 120 |
<p>
| 121 |
A header in each picture file lists the program(s)
| 122 |
and parameters that produced it.
| 123 |
This is useful for identifying a picture without having to display it.
| 124 |
The information can be read by the program <i>getinfo</i>.
| 125 |
| 126 |
<p>
| 127 |
<hr>
| 128 |
| 129 |
<h2>
| 130 |
<a name="Scene">2. Scene Description</a>
| 131 |
</h2>
| 132 |
| 133 |
A scene description file represents a three-dimensional physical environment in Cartesian (rectilinear) world coordinates.
| 134 |
It is stored as ASCII text, with the following basic format:
| 135 |
| 136 |
<pre>
| 137 |
# comment
| 138 |
| 139 |
modifier type identifier
| 140 |
n S1 S2 "S 3" .. Sn
| 141 |
0
| 142 |
m R1 R2 R3 .. Rm
| 143 |
| 144 |
modifier alias identifier reference
| 145 |
| 146 |
! command
| 147 |
| 148 |
| 149 |
</pre>
| 150 |
| 151 |
A comment line begins with a pound sign, `#'.
| 152 |
| 153 |
<p>
| 154 |
The <a NAME="scene_desc">scene description primitives</a>
| 155 |
all have the same general format, and can be either surfaces or modifiers.
| 156 |
A primitive has a modifier, a type, and an identifier.
| 157 |
<p>
| 158 |
A <a NAME="modifier"><b>modifier</b></a> is either the
| 159 |
identifier of a previously defined primitive, or "void".
| 160 |
<br>
| 161 |
[ The most recent definition of a modifier is the
| 162 |
one used, and later definitions do not cause relinking
| 163 |
of loaded primitives.
| 164 |
Thus, the same identifier may be used repeatedly,
| 165 |
and each new definition will apply to the primitives following it. ]
| 166 |
<p>
| 167 |
An <a NAME="identifier"><b>identifier</b></a> can be any string
| 168 |
(i.e., any sequence of non-white characters).
| 169 |
<p>
| 170 |
The arguments associated with a primitive can be strings or real numbers.
| 171 |
<ul>
| 172 |
<li> The first integer following the identifier is the number of <b>string arguments</b>,
| 173 |
and it is followed by the arguments themselves (separated by white space or enclosed in quotes).
| 174 |
<li> The next integer is the number of integer arguments, and is followed by the <b>integer arguments</b>.
| 175 |
(There are currently no primitives that use them, however.)
| 176 |
<li> The next integer is the real argument count, and it is followed by the <b>real arguments</b>.
| 177 |
</ul>
| 178 |
| 179 |
<p>
| 180 |
An <a NAME="alias"><b>alias</b></a> gets its type and arguments from
| 181 |
a previously defined primitive.
| 182 |
This is useful when the same material is
| 183 |
used with a different modifier, or as a convenient naming mechanism.
| 184 |
The reserved modifier name "inherit" may be used to specificy that
| 185 |
an alias will inherit its modifier from the original.
| 186 |
Surfaces cannot be aliased.
| 187 |
| 188 |
<p>
| 189 |
A line beginning with an exclamation point, `!',
| 190 |
is interpreted as a command.
| 191 |
It is executed by the shell, and its output is read as input to the program.
| 192 |
The command must not try to read from its standard input, or confusion
| 193 |
will result.
| 194 |
A command may be continued over multiple lines using a
| 195 |
backslash, `\', to escape the newline.
| 196 |
| 197 |
<p>
| 198 |
White space is generally ignored, except as a separator.
| 199 |
The exception is the newline character after a command or comment.
| 200 |
Commands, comments and primitives may appear in any
| 201 |
combination, so long as they are not intermingled.
| 202 |
| 203 |
<p>
| 204 |
<hr>
| 205 |
| 206 |
<h3>
| 207 |
<a NAME="Primitive">2.1. Primitive Types</a>
| 208 |
</h3>
| 209 |
| 210 |
Primitives can be <a HREF="#Surfaces">surfaces</a>,
| 211 |
<a HREF="#Materials">materials</a>,
| 212 |
<a HREF="#Textures">textures</a> or
| 213 |
<a HREF="#Patterns">patterns</a>.
| 214 |
Modifiers can be <a HREF="#Materials">materials</a>,
| 215 |
<a HREF="#Mixtures">mixtures</a>,
| 216 |
<a HREF="#Textures">textures</a> or <a HREF="#Patterns">patterns</a>.
| 217 |
Simple surfaces must have one material in their modifier list.
| 218 |
| 219 |
<p>
| 220 |
<hr>
| 221 |
| 222 |
<h4>
| 223 |
<a NAME="Surfaces">2.1.1. Surfaces</a>
| 224 |
</h4>
| 225 |
<dl>
| 226 |
| 227 |
A scene description will consist mostly of surfaces.
| 228 |
The basic types are given below.
| 229 |
| 230 |
<p>
| 231 |
| 232 |
<dt>
| 233 |
<a NAME="Source">
| 234 |
<b>Source </b>
| 235 |
</a>
| 236 |
<dd>
| 237 |
A source is not really a surface, but a solid angle.
| 238 |
It is used for specifying light sources that are very distant.
| 239 |
The direction to the center of the source and the number of degrees subtended by its disk are given as follows:
| 240 |
| 241 |
<pre>
| 242 |
mod source id
| 243 |
0
| 244 |
0
| 245 |
4 xdir ydir zdir angle
| 246 |
</pre>
| 247 |
| 248 |
<p>
| 249 |
| 250 |
<dt>
| 251 |
<a NAME="Sphere">
| 252 |
<b>Sphere</b>
| 253 |
</a>
| 254 |
<dd>
| 255 |
A sphere is given by its center and radius:
| 256 |
| 257 |
<pre>
| 258 |
mod sphere id
| 259 |
0
| 260 |
0
| 261 |
4 xcent ycent zcent radius
| 262 |
</pre>
| 263 |
| 264 |
<p>
| 265 |
| 266 |
<dt>
| 267 |
<a NAME="Bubble">
| 268 |
<b>Bubble</b>
| 269 |
</a>
| 270 |
| 271 |
<dd>
| 272 |
A bubble is simply a sphere whose surface normal points inward.
| 273 |
| 274 |
<p>
| 275 |
| 276 |
<dt>
| 277 |
<a NAME="Polygon">
| 278 |
<b>Polygon</b>
| 279 |
</a>
| 280 |
<dd>
| 281 |
A polygon is given by a list of three-dimensional vertices,
| 282 |
which are ordered counter-clockwise as viewed from the
| 283 |
front side (into the surface normal).
| 284 |
The last vertex is automatically connected to the first.
| 285 |
Holes are represented in polygons as interior vertices
| 286 |
connected to the outer perimeter by coincident edges (seams).
| 287 |
| 288 |
<pre>
| 289 |
mod polygon id
| 290 |
0
| 291 |
0
| 292 |
3n
| 293 |
x1 y1 z1
| 294 |
x2 y2 z2
| 295 |
| 296 |
xn yn zn
| 297 |
</pre>
| 298 |
| 299 |
<p>
| 300 |
| 301 |
<dt>
| 302 |
<a NAME="Cone">
| 303 |
<b>Cone</b>
| 304 |
</a>
| 305 |
<dd>
| 306 |
A cone is a megaphone-shaped object.
| 307 |
It is truncated by two planes perpendicular to its axis,
| 308 |
and one of its ends may come to a point.
| 309 |
It is given as two axis endpoints, and the starting and ending radii:
| 310 |
| 311 |
<pre>
| 312 |
mod cone id
| 313 |
0
| 314 |
0
| 315 |
8
| 316 |
x0 y0 z0
| 317 |
x1 y1 z1
| 318 |
r0 r1
| 319 |
</pre>
| 320 |
| 321 |
<p>
| 322 |
| 323 |
<dt>
| 324 |
<a NAME="Cup">
| 325 |
<b>Cup</b>
| 326 |
</a>
| 327 |
<dd>
| 328 |
A cup is an inverted <a HREF="#Cone">cone</a> (i.e., has an
| 329 |
inward surface normal).
| 330 |
| 331 |
<p>
| 332 |
| 333 |
<dt>
| 334 |
<a NAME="Cylinder">
| 335 |
<b>Cylinder</b>
| 336 |
</a>
| 337 |
<dd>
| 338 |
A cylinder is like a <a HREF="#Cone">cone</a>, but its
| 339 |
starting and ending radii are equal.
| 340 |
| 341 |
<pre>
| 342 |
mod cylinder id
| 343 |
0
| 344 |
0
| 345 |
7
| 346 |
x0 y0 z0
| 347 |
x1 y1 z1
| 348 |
rad
| 349 |
</pre>
| 350 |
| 351 |
<p>
| 352 |
| 353 |
<dt>
| 354 |
<a NAME="Tube">
| 355 |
<b>Tube</b>
| 356 |
</a>
| 357 |
<dd>
| 358 |
A tube is an inverted <a HREF="#Cylinder">cylinder</a>.
| 359 |
| 360 |
<p>
| 361 |
| 362 |
<dt>
| 363 |
<a NAME="Ring">
| 364 |
<b>Ring</b>
| 365 |
</a>
| 366 |
<dd>
| 367 |
A ring is a circular disk given by its center,
| 368 |
surface normal, and inner and outer radii:
| 369 |
| 370 |
<pre>
| 371 |
mod ring id
| 372 |
0
| 373 |
0
| 374 |
8
| 375 |
xcent ycent zcent
| 376 |
xdir ydir zdir
| 377 |
r0 r1
| 378 |
</pre>
| 379 |
| 380 |
<p>
| 381 |
| 382 |
<dt>
| 383 |
<a NAME="Instance">
| 384 |
<b>Instance</b>
| 385 |
</a>
| 386 |
<dd>
| 387 |
An instance is a compound surface, given
| 388 |
by the contents of an octree file (created by oconv).
| 389 |
| 390 |
<pre>
| 391 |
mod instance id
| 392 |
1+ octree transform
| 393 |
0
| 394 |
0
| 395 |
</pre>
| 396 |
| 397 |
If the modifier is "void", then surfaces will
| 398 |
use the modifiers given in the original description.
| 399 |
Otherwise, the modifier specified is used in their place.
| 400 |
The transform moves the octree to the desired location in the scene.
| 401 |
Multiple instances using the same octree take
| 402 |
little extra memory, hence very complex
| 403 |
descriptions can be rendered using this primitive.
| 404 |
| 405 |
<p>
| 406 |
There are a number of important limitations to be aware of
| 407 |
when using instances.
| 408 |
First, the scene description used to generate the octree must
| 409 |
stand on its own, without referring to modifiers in the
| 410 |
parent description.
| 411 |
This is necessary for oconv to create the octree.
| 412 |
Second, light sources in the octree will not be
| 413 |
incorporated correctly in the calculation,
| 414 |
and they are not recommended.
| 415 |
Finally, there is no advantage (other than
| 416 |
convenience) to using a single instance of an octree,
| 417 |
or an octree containing only a few surfaces.
| 418 |
An <a HREF="../man_html/xform.1.html">xform</a> command
| 419 |
on the subordinate description is prefered in such cases.
| 420 |
</dl>
| 421 |
| 422 |
<p>
| 423 |
| 424 |
<dt>
| 425 |
<a NAME="Mesh">
| 426 |
<b>Mesh</b>
| 427 |
</a>
| 428 |
<dd>
| 429 |
A mesh is a compound surface, made up of many triangles and
| 430 |
an octree data structure to accelerate ray intersection.
| 431 |
It is typically converted from a Wavefront .OBJ file using the
| 432 |
<i>obj2mesh</i> program.
| 433 |
| 434 |
<pre>
| 435 |
mod mesh id
| 436 |
1+ meshfile transform
| 437 |
0
| 438 |
0
| 439 |
</pre>
| 440 |
| 441 |
| 442 |
use the modifiers given in the original mesh description.
| 443 |
| 444 |
The transform moves the mesh to the desired location in the scene.
| 445 |
Multiple instances using the same meshfile take little extra memory,
| 446 |
and the compiled mesh itself takes much less space than individual
| 447 |
polygons would.
| 448 |
In the case of an unsmoothed mesh, using the mesh primitive reduces
| 449 |
memory requirements by a factor of 30 relative to individual triangles.
| 450 |
If a mesh has smoothed surfaces, we save a factor of 50 or more,
| 451 |
permitting very detailed geometries that would otherwise exhaust the
| 452 |
available memory.
| 453 |
In addition, the mesh primitive can have associated (u,v) coordinates
| 454 |
for pattern and texture mapping.
| 455 |
These are made available to function files via the Lu and Lv variables.
| 456 |
| 457 |
</dl>
| 458 |
| 459 |
<p>
| 460 |
<hr>
| 461 |
| 462 |
<h4>
| 463 |
<a NAME="Materials">2.1.2. Materials</a>
| 464 |
</h4>
| 465 |
| 466 |
A material defines the way light interacts with a surface. The basic types are given below.
| 467 |
| 468 |
<p>
| 469 |
| 470 |
<dl>
| 471 |
| 472 |
<dt>
| 473 |
<a NAME="Light">
| 474 |
<b>Light</b>
| 475 |
</a>
| 476 |
<dd>
| 477 |
Light is the basic material for self-luminous surfaces (i.e.,
| 478 |
light sources).
| 479 |
In addition to the <a HREF="#Source">source</a> surface type,
| 480 |
<a HREF="#Sphere">spheres</a>,
| 481 |
discs (<a HREF="#Ring">rings</a> with zero inner radius),
| 482 |
<a HREF="#Cylinder">cylinders</a> (provided they are long enough), and <a HREF="#Polygon">polygons</a> can act as light sources.
| 483 |
Polygons work best when they are rectangular.
| 484 |
Cones cannot be used at this time.
| 485 |
A pattern may be used to specify a light output distribution.
| 486 |
Light is defined simply as a RGB radiance value (watts/steradian/m2):
| 487 |
| 488 |
<pre>
| 489 |
mod light id
| 490 |
0
| 491 |
0
| 492 |
3 red green blue
| 493 |
</pre>
| 494 |
| 495 |
<p>
| 496 |
| 497 |
<dt>
| 498 |
<a NAME="Illum">
| 499 |
<b>Illum</b>
| 500 |
</a>
| 501 |
| 502 |
<dd>
| 503 |
Illum is used for secondary light sources with broad distributions.
| 504 |
A secondary light source is treated like any other light source, except when viewed directly.
| 505 |
It then acts like it is made of a different material (indicated by
| 506 |
the string argument), or becomes invisible (if no string argument is given,
| 507 |
or the argument is "void").
| 508 |
Secondary sources are useful when modeling windows or brightly illuminated surfaces.
| 509 |
| 510 |
<pre>
| 511 |
mod illum id
| 512 |
1 material
| 513 |
0
| 514 |
3 red green blue
| 515 |
</pre>
| 516 |
| 517 |
<p>
| 518 |
| 519 |
<dt>
| 520 |
<a NAME="Glow">
| 521 |
<b>Glow</b>
| 522 |
</a>
| 523 |
| 524 |
<dd>
| 525 |
Glow is used for surfaces that are self-luminous, but limited in their effect.
| 526 |
In addition to the radiance value, a maximum radius for shadow testing is given:
| 527 |
| 528 |
<pre>
| 529 |
mod glow id
| 530 |
0
| 531 |
0
| 532 |
4 red green blue maxrad
| 533 |
</pre>
| 534 |
| 535 |
If maxrad is zero, then the surface will never be tested for shadow, although it may participate in an interreflection calculation.
| 536 |
If maxrad is negative, then the surface will never contribute to scene illumination.
| 537 |
Glow sources will never illuminate objects on the other side of an illum surface.
| 538 |
This provides a convenient way to illuminate local light fixture geometry without overlighting nearby objects.
| 539 |
| 540 |
<p>
| 541 |
| 542 |
<dt>
| 543 |
<a NAME="Spotlight">
| 544 |
<b>Spotlight</b>
| 545 |
</a>
| 546 |
| 547 |
<dd>
| 548 |
Spotlight is used for self-luminous surfaces having directed output.
| 549 |
As well as radiance, the full cone angle (in degrees) and orientation (output direction) vector are given.
| 550 |
The length of the orientation vector is the distance of the effective
| 551 |
focus behind the source center (i.e., the focal length).
| 552 |
| 553 |
<pre>
| 554 |
mod spotlight id
| 555 |
0
| 556 |
0
| 557 |
7 red green blue angle xdir ydir zdir
| 558 |
</pre>
| 559 |
| 560 |
<p>
| 561 |
| 562 |
<dt>
| 563 |
<a NAME="Mirror">
| 564 |
<b>Mirror</b>
| 565 |
</a>
| 566 |
| 567 |
<dd>
| 568 |
Mirror is used for planar surfaces that produce virtual source reflections.
| 569 |
This material should be used sparingly, as it may cause the light source calculation to blow up if it is applied to many small surfaces.
| 570 |
This material is only supported for flat surfaces such as <a HREF="#Polygon">polygons</a> and <a HREF="#Ring">rings</a>.
| 571 |
The arguments are simply the RGB reflectance values, which should be between 0 and 1.
| 572 |
An optional string argument may be used like the illum type to specify a different material to be used for shading non-source rays.
| 573 |
If this alternate material is given as "void", then the mirror surface will be invisible.
| 574 |
This is only appropriate if the surface hides other (more detailed) geometry with the same overall reflectance.
| 575 |
| 576 |
<pre>
| 577 |
mod mirror id
| 578 |
1 material
| 579 |
0
| 580 |
3 red green blue
| 581 |
</pre>
| 582 |
| 583 |
<p>
| 584 |
| 585 |
<dt>
| 586 |
<a NAME="Prism1">
| 587 |
<b>Prism1</b>
| 588 |
</a>
| 589 |
| 590 |
<dd>
| 591 |
The prism1 material is for general light redirection from prismatic glazings, generating virtual light sources.
| 592 |
It can only be used to modify a planar surface
| 593 |
(i.e., a <a HREF="#Polygon">polygon</a> or <a HREF="#Ring">disk</a>)
| 594 |
and should not result in either light concentration or scattering.
| 595 |
The new direction of the ray can be on either side of the material,
| 596 |
and the definitions must have the correct bidirectional properties to work properly with virtual light sources.
| 597 |
The arguments give the coefficient for the redirected light and its direction.
| 598 |
| 599 |
<pre>
| 600 |
mod prism1 id
| 601 |
5+ coef dx dy dz funcfile transform
| 602 |
0
| 603 |
n A1 A2 .. An
| 604 |
</pre>
| 605 |
| 606 |
The new direction variables dx, dy and dz need not produce a normalized vector.
| 607 |
For convenience, the variables DxA, DyA and DzA are defined as the normalized direction to the target light source.
| 608 |
See <a HREF="#Function">section 2.2.1</a> on function files for further information.
| 609 |
| 610 |
<p>
| 611 |
| 612 |
<dt>
| 613 |
<a NAME="Prism2">
| 614 |
<b>Prism2</b>
| 615 |
</a>
| 616 |
| 617 |
<dd>
| 618 |
The material prism2 is identical to <a HREF="#Prism1">prism1</a> except that it provides for two ray redirections rather than one.
| 619 |
| 620 |
<pre>
| 621 |
mod prism2 id
| 622 |
9+ coef1 dx1 dy1 dz1 coef2 dx2 dy2 dz2 funcfile transform
| 623 |
0
| 624 |
n A1 A2 .. An
| 625 |
</pre>
| 626 |
| 627 |
<p>
| 628 |
| 629 |
<dt>
| 630 |
<a NAME="Mist">
| 631 |
<b>Mist</b>
| 632 |
</a>
| 633 |
| 634 |
<dd>
| 635 |
Mist is a virtual material used to delineate a volume
| 636 |
of participating atmosphere.
| 637 |
A list of important light sources may be given, along with an
| 638 |
extinction coefficient, scattering albedo and scattering eccentricity
| 639 |
parameter.
| 640 |
The light sources named by the string argument list
| 641 |
will be tested for scattering within the volume.
| 642 |
Sources are identified by name, and virtual light sources may be indicated
| 643 |
by giving the relaying object followed by '>' followed by the source, i.e:
| 644 |
| 645 |
<pre>
| 646 |
3 source1 mirror1>source10 mirror2>mirror1>source3
| 647 |
</pre>
| 648 |
| 649 |
Normally, only one source is given per mist material, and there is an
| 650 |
upper limit of 32 to the total number of active scattering sources.
| 651 |
The extinction coefficient, if given, is added the the global
| 652 |
coefficient set on the command line.
| 653 |
Extinction is in units of 1/distance (distance based on the world coordinates),
| 654 |
and indicates the proportional loss of radiance over one unit distance.
| 655 |
The scattering albedo, if present, will override the global setting within
| 656 |
the volume.
| 657 |
An albedo of 0 0 0 means a perfectly absorbing medium, and an albedo of
| 658 |
1 1 1 means
| 659 |
a perfectly scattering medium (no absorption).
| 660 |
The scattering eccentricity parameter will likewise override the global
| 661 |
setting if it is present.
| 662 |
Scattering eccentricity indicates how much scattered light favors the
| 663 |
forward direction, as fit by the Henyey-Greenstein function:
| 664 |
| 665 |
<pre>
| 666 |
P(theta) = (1 - g*g) / (1 + g*g - 2*g*cos(theta))^1.5
| 667 |
</pre>
| 668 |
| 669 |
A perfectly isotropic scattering medium has a g parameter of 0, and
| 670 |
a highly directional material has a g parameter close to 1.
| 671 |
Fits to the g parameter may be found along with typical extinction
| 672 |
coefficients and scattering albedos for various atmospheres and
| 673 |
cloud types in USGS meteorological tables.
| 674 |
(A pattern will be applied to the extinction values.)
| 675 |
| 676 |
<pre>
| 677 |
mod mist id
| 678 |
N src1 src2 .. srcN
| 679 |
0
| 680 |
0|3|6|7 [ rext gext bext [ ralb galb balb [ g ] ] ]
| 681 |
</pre>
| 682 |
| 683 |
There are two usual uses of the mist type.
| 684 |
One is to surround a beam from a spotlight or laser so that it is
| 685 |
visible during rendering.
| 686 |
For this application, it is important to use a <a HREF="#Cone">cone</a>
| 687 |
(or <a HREF="#Cylinder">cylinder</a>) that
| 688 |
is long enough and wide enough to contain the important visible portion.
| 689 |
Light source photometry and intervening objects will have the desired
| 690 |
effect, and crossing beams will result in additive scattering.
| 691 |
For this application, it is best to leave off the real arguments, and
| 692 |
use the global rendering parameters to control the atmosphere.
| 693 |
The second application is to model clouds or other localized media.
| 694 |
Complex boundary geometry may be used to give shape to a uniform medium,
| 695 |
so long as the boundary encloses a proper volume.
| 696 |
Alternatively, a pattern may be used to set the line integral value
| 697 |
through the cloud for a ray entering or exiting a point in a given
| 698 |
direction.
| 699 |
For this application, it is best if cloud volumes do not overlap each other,
| 700 |
and opaque objects contained within them may not be illuminated correctly
| 701 |
unless the line integrals consider enclosed geometry.
| 702 |
| 703 |
<dt>
| 704 |
<a NAME="Plastic">
| 705 |
<b>Plastic</b>
| 706 |
</a>
| 707 |
| 708 |
<dd>
| 709 |
Plastic is a material with uncolored highlights.
| 710 |
It is given by its RGB reflectance, its fraction of specularity, and its roughness value.
| 711 |
Roughness is specified as the rms slope of surface facets.
| 712 |
A value of 0 corresponds to a perfectly smooth surface, and a value of 1 would be a very rough surface.
| 713 |
Specularity fractions greater than 0.1 and roughness values greater than 0.2 are not very realistic.
| 714 |
(A pattern modifying plastic will affect the material color.)
| 715 |
| 716 |
<pre>
| 717 |
mod plastic id
| 718 |
0
| 719 |
0
| 720 |
5 red green blue spec rough
| 721 |
</pre>
| 722 |
| 723 |
<p>
| 724 |
| 725 |
<dt>
| 726 |
<a NAME="Metal">
| 727 |
<b>Metal</b>
| 728 |
</a>
| 729 |
| 730 |
<dd>
| 731 |
Metal is similar to <a HREF="#Plastic">plastic</a>, but specular highlights are modified by the material color.
| 732 |
Specularity of metals is usually .9 or greater.
| 733 |
As for plastic, roughness values above .2 are uncommon.
| 734 |
| 735 |
<p>
| 736 |
| 737 |
<dt>
| 738 |
<a NAME="Trans">
| 739 |
<b>Trans</b>
| 740 |
</a>
| 741 |
| 742 |
<dd>
| 743 |
Trans is a translucent material, similar to <a HREF="#Plastic">plastic</a>.
| 744 |
The transmissivity is the fraction of penetrating light that travels all the way through the material.
| 745 |
The transmitted specular component is the fraction of transmitted light that is not diffusely scattered.
| 746 |
Transmitted and diffusely reflected light is modified by the material color.
| 747 |
Translucent objects are infinitely thin.
| 748 |
| 749 |
<pre>
| 750 |
mod trans id
| 751 |
0
| 752 |
0
| 753 |
7 red green blue spec rough trans tspec
| 754 |
</pre>
| 755 |
| 756 |
<p>
| 757 |
| 758 |
<dt>
| 759 |
<a NAME="Plastic2">
| 760 |
<b>Plastic2</b>
| 761 |
</a>
| 762 |
| 763 |
<dd>
| 764 |
Plastic2 is similar to <a HREF="#Plastic">plastic</a>, but with anisotropic roughness.
| 765 |
This means that highlights in the surface will appear elliptical rather than round.
| 766 |
The orientation of the anisotropy is determined by the unnormalized direction vector ux uy uz.
| 767 |
These three expressions (separated by white space) are evaluated in the context of the function file funcfile.
| 768 |
If no function file is required (i.e., no special variables or functions are required), a period (`.') may be given in its place.
| 769 |
(See the discussion of <a HREF="#Function">Function Files</a> in the Auxiliary Files section).
| 770 |
The urough value defines the roughness along the u vector given projected onto the surface.
| 771 |
The vrough value defines the roughness perpendicular to this vector.
| 772 |
Note that the highlight will be narrower in the direction of the smaller roughness value.
| 773 |
Roughness values of zero are not allowed for efficiency reasons since the behavior would be the same as regular plastic in that case.
| 774 |
| 775 |
<pre>
| 776 |
mod plastic2 id
| 777 |
4+ ux uy uz funcfile transform
| 778 |
0
| 779 |
6 red green blue spec urough vrough
| 780 |
</pre>
| 781 |
| 782 |
<p>
| 783 |
| 784 |
<dt>
| 785 |
<a NAME="Metal2">
| 786 |
<b>Metal2</b>
| 787 |
</a>
| 788 |
| 789 |
<dd>
| 790 |
Metal2 is the same as <a HREF="#Plastic2">plastic2</a>, except that the highlights are modified by the material color.
| 791 |
| 792 |
<p>
| 793 |
| 794 |
<dt>
| 795 |
<a NAME="Trans2">
| 796 |
<b>Trans2</b>
| 797 |
</a>
| 798 |
| 799 |
<dd>
| 800 |
Trans2 is the anisotropic version of <a HREF="#Trans">trans</a>.
| 801 |
The string arguments are the same as for <a HREF="#Plastic2">plastic2</a>,
| 802 |
and the real arguments are the same as for trans but with an additional roughness value.
| 803 |
| 804 |
<pre>
| 805 |
mod trans2 id
| 806 |
| 807 |
0
| 808 |
8 red green blue spec urough vrough trans tspec
| 809 |
</pre>
| 810 |
| 811 |
<p>
| 812 |
| 813 |
<dt>
| 814 |
<a NAME="Ashik2">
| 815 |
<b>Ashik2</b>
| 816 |
</a>
| 817 |
| 818 |
<dd>
| 819 |
Ashik2 is the anisotropic reflectance model by Ashikhmin & Shirley.
| 820 |
The string arguments are the same as for <a HREF="#Plastic2">plastic2</a>, but the real
| 821 |
arguments have additional flexibility to specify the specular color.
| 822 |
Also, rather than roughness, specular power is used, which has no
| 823 |
physical meaning other than larger numbers are equivalent to a smoother
| 824 |
surface.
| 825 |
<pre>
| 826 |
mod ashik2 id
| 827 |
| 828 |
0
| 829 |
8 dred dgrn dblu sred sgrn sblu u-power v-power
| 830 |
</pre>
| 831 |
| 832 |
<p>
| 833 |
| 834 |
<dt>
| 835 |
<a NAME="Dielectric">
| 836 |
<b>Dielectric</b>
| 837 |
</a>
| 838 |
| 839 |
<dd>
| 840 |
A dielectric material is transparent, and it refracts light as well as reflecting it.
| 841 |
Its behavior is determined by the index of refraction and transmission coefficient in each wavelength band per unit length.
| 842 |
Common glass has a index of refraction (n) around 1.5, and a transmission coefficient of roughly 0.92 over an inch.
| 843 |
An additional number, the Hartmann constant, describes how the index of refraction changes as a function of wavelength.
| 844 |
It is usually zero. (A <a HREF="#Patterns">pattern</a> modifies only the refracted value.)
| 845 |
| 846 |
<pre>
| 847 |
mod dielectric id
| 848 |
0
| 849 |
0
| 850 |
5 rtn gtn btn n hc
| 851 |
</pre>
| 852 |
| 853 |
<p>
| 854 |
| 855 |
<dt>
| 856 |
<a NAME="Interface">
| 857 |
<b>Interface</b>
| 858 |
</a>
| 859 |
| 860 |
<dd>
| 861 |
An interface is a boundary between two dielectrics.
| 862 |
The first transmission coefficient and refractive index are for the inside; the second ones are for the outside.
| 863 |
Ordinary dielectrics are surrounded by a vacuum (1 1 1 1).
| 864 |
| 865 |
<pre>
| 866 |
mod interface id
| 867 |
0
| 868 |
0
| 869 |
8 rtn1 gtn1 btn1 n1 rtn2 gtn2 btn2 n2
| 870 |
</pre>
| 871 |
| 872 |
<p>
| 873 |
| 874 |
<dt>
| 875 |
<a NAME="Glass">
| 876 |
<b>Glass</b>
| 877 |
</a>
| 878 |
| 879 |
<dd>
| 880 |
Glass is similar to <a HREF="#Dielectric">dielectric</a>, but it is optimized for thin glass surfaces (n = 1.52).
| 881 |
One transmitted ray and one reflected ray is produced.
| 882 |
By using a single surface is in place of two, internal reflections are avoided.
| 883 |
The surface orientation is irrelevant, as it is for <a HREF="#Plastic">plastic</a>, <a HREF="#Metal">metal</a>, and <a HREF="#Trans">trans</a>.
| 884 |
The only specification required is the transmissivity at normal incidence.
| 885 |
(Transmissivity is the amount of light not absorbed in one traversal
| 886 |
of the material.
| 887 |
Transmittance -- the value usually measured -- is the total light
| 888 |
transmitted through the pane including multiple reflections.)
| 889 |
To compute transmissivity (tn) from transmittance (Tn) use:
| 890 |
| 891 |
<pre>
| 892 |
tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.0036261119/Tn
| 893 |
</pre>
| 894 |
| 895 |
Standard 88% transmittance glass has a transmissivity of 0.96.
| 896 |
(A <a HREF="#Patterns">pattern</a> modifying glass will affect the transmissivity.)
| 897 |
If a fourth real argument is given, it is interpreted as the index of refraction to use instead of 1.52.
| 898 |
| 899 |
<pre>
| 900 |
mod glass id
| 901 |
0
| 902 |
0
| 903 |
3 rtn gtn btn
| 904 |
</pre>
| 905 |
| 906 |
<p>
| 907 |
| 908 |
<dt>
| 909 |
<a NAME="Plasfunc">
| 910 |
<b>Plasfunc</b>
| 911 |
</a>
| 912 |
| 913 |
<dd>
| 914 |
Plasfunc in used for the procedural definition of plastic-like materials
| 915 |
with arbitrary bidirectional reflectance distribution functions (BRDF's).
| 916 |
The arguments to this material include the color and specularity,
| 917 |
as well as the function defining the specular distribution and the auxiliary file where it may be found.
| 918 |
| 919 |
<pre>
| 920 |
mod plasfunc id
| 921 |
2+ refl funcfile transform
| 922 |
0
| 923 |
4+ red green blue spec A5 ..
| 924 |
</pre>
| 925 |
| 926 |
The function refl takes four arguments, the x, y and z
| 927 |
direction towards the incident light, and the solid angle
| 928 |
subtended by the source.
| 929 |
The solid angle is provided to facilitate averaging, and is usually
| 930 |
ignored.
| 931 |
The refl function should integrate to 1 over
| 932 |
the projected hemisphere to maintain energy balance.
| 933 |
At least four real arguments must be given, and these are made available along with any additional values to the reflectance function.
| 934 |
Currently, only the contribution from direct light sources is considered in the specular calculation.
| 935 |
As in most material types, the surface normal is always altered to face the incoming ray.
| 936 |
| 937 |
<p>
| 938 |
| 939 |
<dt>
| 940 |
<a NAME="Metfunc">
| 941 |
<b>Metfunc</b>
| 942 |
</a>
| 943 |
| 944 |
<dd>
| 945 |
Metfunc is identical to <a HREF="#Plasfunc">plasfunc</a> and takes the same arguments,
| 946 |
but the specular component is multiplied also by the material color.
| 947 |
| 948 |
<p>
| 949 |
| 950 |
<dt>
| 951 |
<a NAME="Transfunc">
| 952 |
<b>Transfunc</b>
| 953 |
</a>
| 954 |
| 955 |
<dd>
| 956 |
Transfunc is similar to <a HREF="#Plasfunc">plasfunc</a> but with an arbitrary bidirectional transmittance distribution
| 957 |
as well as a reflectance distribution.
| 958 |
Both reflectance and transmittance are specified with the same function.
| 959 |
| 960 |
<pre>
| 961 |
mod transfunc id
| 962 |
2+ brtd funcfile transform
| 963 |
0
| 964 |
6+ red green blue rspec trans tspec A7 ..
| 965 |
</pre>
| 966 |
| 967 |
Where trans is the total light transmitted and tspec is the non-Lambertian fraction of transmitted light.
| 968 |
The function brtd should integrate to 1 over each projected hemisphere.
| 969 |
| 970 |
<p>
| 971 |
| 972 |
<dt>
| 973 |
<a NAME="BRTDfunc">
| 974 |
<b>BRTDfunc</b>
| 975 |
</a>
| 976 |
| 977 |
<dd>
| 978 |
The material BRTDfunc gives the maximum flexibility over surface reflectance and transmittance,
| 979 |
providing for spectrally-dependent specular rays and reflectance and transmittance distribution functions.
| 980 |
| 981 |
<pre>
| 982 |
mod BRTDfunc id
| 983 |
10+ rrefl grefl brefl
| 984 |
rtrns gtrns btrns
| 985 |
rbrtd gbrtd bbrtd
| 986 |
funcfile transform
| 987 |
0
| 988 |
9+ rfdif gfdif bfdif
| 989 |
rbdif gbdif bbdif
| 990 |
rtdif gtdif btdif
| 991 |
A10 ..
| 992 |
</pre>
| 993 |
| 994 |
The variables rrefl, grefl and brefl specify the color coefficients for the ideal specular (mirror) reflection of the surface.
| 995 |
The variables rtrns, gtrns and btrns specify the color coefficients for the ideal specular transmission.
| 996 |
The functions rbrtd, gbrtd and bbrtd take the direction to the incident light (and its solid angle) and
| 997 |
compute the color coefficients for the directional diffuse part of reflection and transmission.
| 998 |
As a special case, three identical values of '0' may be given in place of these function names to indicate no directional diffuse component.
| 999 |
| 1000 |
<p>
| 1001 |
Unlike most other material types, the surface normal is not altered to face the incoming ray.
| 1002 |
Thus, functions and variables must pay attention to the orientation of the surface and make adjustments appropriately.
| 1003 |
However, the special variables for the perturbed dot product and surface normal, RdotP, NxP, NyP and NzP are reoriented
| 1004 |
as if the ray hit the front surface for convenience.
| 1005 |
| 1006 |
<p>
| 1007 |
A diffuse reflection component may be given for the front side with rfdif, gfdif and bfdif for the front side of the surface
| 1008 |
or rbdif, gbdif and bbdif for the back side.
| 1009 |
The diffuse transmittance (must be the same for both sides by physical law) is given by rtdif, gtdif and btdif.
| 1010 |
A pattern will modify these diffuse scattering values, and will be available through the special variables CrP, CgP and CbP.
| 1011 |
| 1012 |
<p>
| 1013 |
Care must be taken when using this material type to produce a physically valid reflection model.
| 1014 |
The reflectance functions should be bidirectional, and under no circumstances should the sum of reflected diffuse,
| 1015 |
transmitted diffuse, reflected specular, transmitted specular and the integrated directional diffuse component be greater than one.
| 1016 |
| 1017 |
<p>
| 1018 |
| 1019 |
<dt>
| 1020 |
<a NAME="Plasdata">
| 1021 |
<b>Plasdata</b>
| 1022 |
</a>
| 1023 |
| 1024 |
<dd>
| 1025 |
Plasdata is used for arbitrary BRDF's that are most conveniently given as interpolated data.
| 1026 |
The arguments to this material are the <a HREF="#Data">data file</a> and coordinate index functions,
| 1027 |
as well as a function to optionally modify the data values.
| 1028 |
| 1029 |
<pre>
| 1030 |
mod plasdata id
| 1031 |
3+n+
| 1032 |
func datafile
| 1033 |
funcfile x1 x2 .. xn transform
| 1034 |
0
| 1035 |
| 1036 |
</pre>
| 1037 |
| 1038 |
The coordinate indices (x1, x2, etc.) are themselves functions of the x, y and z direction to the incident light, plus the solid angle
| 1039 |
subtended by the light source (usually ignored).
| 1040 |
The data function (func) takes five variables, the
| 1041 |
interpolated value from the n-dimensional data file, followed by the
| 1042 |
x, y and z direction to the incident light and the solid angle of the source.
| 1043 |
The light source direction and size may of course be ignored by the function.
| 1044 |
| 1045 |
<p>
| 1046 |
| 1047 |
<dt>
| 1048 |
<a NAME="Metdata">
| 1049 |
<b>Metdata</b>
| 1050 |
</a>
| 1051 |
| 1052 |
<dd>
| 1053 |
As metfunc is to plasfunc, metdata is to <a HREF="#Plasdata">plasdata</a>.
| 1054 |
Metdata takes the same arguments as plasdata, but the specular component is modified by the given material color.
| 1055 |
| 1056 |
<p>
| 1057 |
| 1058 |
<dt>
| 1059 |
<a NAME="Transdata">
| 1060 |
<b>Transdata</b>
| 1061 |
</a>
| 1062 |
| 1063 |
<dd>
| 1064 |
Transdata is like <a HREF="#Plasdata">plasdata</a> but the specification includes transmittance as well as reflectance.
| 1065 |
The parameters are as follows.
| 1066 |
| 1067 |
<pre>
| 1068 |
mod transdata id
| 1069 |
3+n+
| 1070 |
func datafile
| 1071 |
| 1072 |
0
| 1073 |
| 1074 |
</pre>
| 1075 |
| 1076 |
<p>
| 1077 |
| 1078 |
<dt>
| 1079 |
<a NAME="BSDF">
| 1080 |
<b>BSDF</b>
| 1081 |
</a>
| 1082 |
| 1083 |
<dd>
| 1084 |
The BSDF material type loads an XML (eXtensible Markup Language)
| 1085 |
file describing a bidirectional scattering distribution function.
| 1086 |
Real arguments to this material may define additional
| 1087 |
diffuse components that augment the BSDF data.
| 1088 |
String arguments are used to define thickness for proxied
| 1089 |
surfaces and the "up" orientation for the material.
| 1090 |
| 1091 |
<pre>
| 1092 |
mod BSDF id
| 1093 |
6+ thick BSDFfile ux uy uz funcfile transform
| 1094 |
0
| 1095 |
0|3|6|9
| 1096 |
rfdif gfdif bfdif
| 1097 |
rbdif gbdif bbdif
| 1098 |
rtdif gtdif btdif
| 1099 |
</pre>
| 1100 |
| 1101 |
<p>
| 1102 |
The first string argument is a "thickness" parameter that may be used
| 1103 |
to hide detail geometry being proxied by an aggregate BSDF material.
| 1104 |
If a view or shadow ray hits a BSDF proxy with non-zero thickness,
| 1105 |
it will pass directly through as if the surface were not there.
| 1106 |
Similar to the illum type, this permits direct viewing and
| 1107 |
shadow testing of complex geometry.
| 1108 |
The BSDF is used when a scattered (indirect) ray hits the surface,
| 1109 |
and any transmitted sample rays will be offset by the thickness amount
| 1110 |
to avoid the hidden geometry and gather samples from the other side.
| 1111 |
In this manner, BSDF surfaces can improve the results for indirect
| 1112 |
scattering from complex systems without sacrificing appearance or
| 1113 |
shadow accuracy.
| 1114 |
If the BSDF has transmission and back-side reflection data,
| 1115 |
a parallel BSDF surface may be
| 1116 |
placed slightly less than the given thickness away from the front surface
| 1117 |
to enclose the complex geometry on both sides.
| 1118 |
The sign of the thickness is important, as it indicates
| 1119 |
whether the proxied geometry is behind the BSDF
| 1120 |
surface (when thickness is positive) or in front (when
| 1121 |
thickness is negative).
| 1122 |
<p>
| 1123 |
The second string argument is the name of the BSDF file,
| 1124 |
which is found in the usual auxiliary locations. The
| 1125 |
following three string parameters name variables for an
| 1126 |
"up" vector, which together with the surface
| 1127 |
normal, define the local coordinate system that orients the
| 1128 |
BSDF. These variables, along with the thickness, are defined
| 1129 |
in a function file given as the next string argument. An
| 1130 |
optional transform is used to scale the thickness and
| 1131 |
reorient the up vector.
| 1132 |
<p>
| 1133 |
If no real arguments are given, the BSDF is used by itself
| 1134 |
to determine reflection and transmission. If there are at
| 1135 |
least 3 real arguments, the first triplet is an additional
| 1136 |
diffuse reflectance for the front side. At least 6 real
| 1137 |
arguments adds diffuse reflectance to the rear side of the
| 1138 |
surface. If there are 9 real arguments, the final triplet
| 1139 |
will be taken as an additional diffuse transmittance. All
| 1140 |
diffuse components as well as the non-diffuse transmission
| 1141 |
are modified by patterns applied to this material. The
| 1142 |
non-diffuse reflection from either side are unaffected.
| 1143 |
Textures perturb the effective surface normal in the usual
| 1144 |
way.
| 1145 |
<p>
| 1146 |
The surface normal of this type is not altered to face the
| 1147 |
incoming ray, so the front and back BSDF reflections may
| 1148 |
differ. (Transmission is identical front-to-back by physical
| 1149 |
law.) If back visibility is turned off during rendering and
| 1150 |
there is no transmission or back-side reflection, only then
| 1151 |
the surface will be invisible from behind. Unlike other
| 1152 |
data-driven material types, the BSDF type is fully supported
| 1153 |
and all parts of the distribution are properly sampled.
| 1154 |
<p>
| 1155 |
| 1156 |
<dt>
| 1157 |
<a NAME="Antimatter">
| 1158 |
<b>Antimatter</b>
| 1159 |
</a>
| 1160 |
| 1161 |
<dd>
| 1162 |
Antimatter is a material that can "subtract" volumes from other volumes.
| 1163 |
A ray passing into an antimatter object becomes blind to all the specified modifiers:
| 1164 |
| 1165 |
<pre>
| 1166 |
mod antimatter id
| 1167 |
N mod1 mod2 .. modN
| 1168 |
0
| 1169 |
0
| 1170 |
</pre>
| 1171 |
| 1172 |
The first modifier will also be used to shade the area leaving the antimatter volume and entering the regular volume.
| 1173 |
If mod1 is void, the antimatter volume is completely invisible.
| 1174 |
Antimatter does not work properly with the material type <a HREF="#Trans">"trans"</a>,
| 1175 |
and multiple antimatter surfaces should be disjoint.
| 1176 |
The viewpoint must be outside all volumes concerned for a correct rendering.
| 1177 |
| 1178 |
</dl>
| 1179 |
| 1180 |
<p>
| 1181 |
<hr>
| 1182 |
| 1183 |
<h4>
| 1184 |
<a NAME="Textures">2.1.3. Textures</a>
| 1185 |
</h4>
| 1186 |
| 1187 |
A texture is a perturbation of the surface normal, and is given by either a function or data.
| 1188 |
| 1189 |
<p>
| 1190 |
| 1191 |
<dl>
| 1192 |
| 1193 |
<dt>
| 1194 |
<a NAME="Texfunc">
| 1195 |
<b>Texfunc</b>
| 1196 |
</a>
| 1197 |
| 1198 |
<dd>
| 1199 |
A texfunc uses an auxiliary function file to specify a procedural texture:
| 1200 |
| 1201 |
<pre>
| 1202 |
mod texfunc id
| 1203 |
4+ xpert ypert zpert funcfile transform
| 1204 |
0
| 1205 |
n A1 A2 .. An
| 1206 |
</pre>
| 1207 |
| 1208 |
<p>
| 1209 |
| 1210 |
<dt>
| 1211 |
<a NAME="Texdata">
| 1212 |
<b>Texdata</b>
| 1213 |
</a>
| 1214 |
| 1215 |
<dd>
| 1216 |
A texdata texture uses three data files to get the surface normal perturbations.
| 1217 |
The variables xfunc, yfunc and zfunc take three arguments each from the interpolated values in xdfname, ydfname and zdfname.
| 1218 |
| 1219 |
<pre>
| 1220 |
mod texdata id
| 1221 |
8+ xfunc yfunc zfunc xdfname ydfname zdfname vfname x0 x1 .. xf
| 1222 |
0
| 1223 |
n A1 A2 .. An
| 1224 |
</pre>
| 1225 |
| 1226 |
</dl>
| 1227 |
| 1228 |
<p>
| 1229 |
<hr>
| 1230 |
| 1231 |
<h4>
| 1232 |
<a NAME="Patterns">2.1.4. Patterns</a>
| 1233 |
</h4>
| 1234 |
| 1235 |
Patterns are used to modify the reflectance of materials. The basic types are given below.
| 1236 |
| 1237 |
<p>
| 1238 |
| 1239 |
<dl>
| 1240 |
| 1241 |
<dt>
| 1242 |
<a NAME="Colorfunc">
| 1243 |
<b>Colorfunc</b>
| 1244 |
</a>
| 1245 |
| 1246 |
<dd>
| 1247 |
A colorfunc is a procedurally defined color pattern. It is specified as follows:
| 1248 |
| 1249 |
<pre>
| 1250 |
mod colorfunc id
| 1251 |
4+ red green blue funcfile transform
| 1252 |
0
| 1253 |
n A1 A2 .. An
| 1254 |
</pre>
| 1255 |
| 1256 |
<p>
| 1257 |
| 1258 |
<dt>
| 1259 |
<a NAME="Brightfunc">
| 1260 |
<b>Brightfunc</b>
| 1261 |
</a>
| 1262 |
| 1263 |
<dd>
| 1264 |
A brightfunc is the same as a colorfunc, except it is monochromatic.
| 1265 |
| 1266 |
<pre>
| 1267 |
mod brightfunc id
| 1268 |
| 1269 |
0
| 1270 |
n A1 A2 .. An
| 1271 |
</pre>
| 1272 |
| 1273 |
<p>
| 1274 |
| 1275 |
<dt>
| 1276 |
<a NAME="Colordata">
| 1277 |
<b>Colordata</b>
| 1278 |
</a>
| 1279 |
| 1280 |
<dd>
| 1281 |
Colordata uses an interpolated data map to modify a material's color.
| 1282 |
The map is n-dimensional, and is stored in three auxiliary files, one for each color.
| 1283 |
The coordinates used to look up and interpolate the data are defined in another auxiliary file.
| 1284 |
The interpolated data values are modified by functions of one or three variables.
| 1285 |
If the functions are of one variable, then they are passed the corresponding color component (red or green or blue).
| 1286 |
If the functions are of three variables, then they are passed the original red, green, and blue values as parameters.
| 1287 |
| 1288 |
<pre>
| 1289 |
mod colordata id
| 1290 |
7+n+
| 1291 |
rfunc gfunc bfunc rdatafile gdatafile bdatafile
| 1292 |
| 1293 |
0
| 1294 |
m A1 A2 .. Am
| 1295 |
</pre>
| 1296 |
| 1297 |
<p>
| 1298 |
| 1299 |
<dt>
| 1300 |
<a NAME="Brightdata">
| 1301 |
<b>Brightdata</b>
| 1302 |
</a>
| 1303 |
| 1304 |
<dd>
| 1305 |
Brightdata is like colordata, except monochromatic.
| 1306 |
| 1307 |
<pre>
| 1308 |
mod brightdata id
| 1309 |
3+n+
| 1310 |
func datafile
| 1311 |
| 1312 |
0
| 1313 |
m A1 A2 .. Am
| 1314 |
</pre>
| 1315 |
| 1316 |
<p>
| 1317 |
| 1318 |
<dt>
| 1319 |
<a NAME="Colorpict">
| 1320 |
<b>Colorpict</b>
| 1321 |
</a>
| 1322 |
| 1323 |
<dd>
| 1324 |
Colorpict is a special case of colordata, where the pattern is a two-dimensional image stored in the RADIANCE picture format.
| 1325 |
The dimensions of the image data are determined by the picture such that the smaller dimension is always 1,
| 1326 |
and the other is the ratio between the larger and the smaller.
| 1327 |
For example, a 500x338 picture would have coordinates (u,v) in the rectangle between (0,0) and (1.48,1).
| 1328 |
| 1329 |
<pre>
| 1330 |
mod colorpict id
| 1331 |
7+
| 1332 |
rfunc gfunc bfunc pictfile
| 1333 |
funcfile u v transform
| 1334 |
0
| 1335 |
m A1 A2 .. Am
| 1336 |
</pre>
| 1337 |
| 1338 |
<p>
| 1339 |
| 1340 |
<dt>
| 1341 |
<a NAME="Colortext">
| 1342 |
<b>Colortext</b>
| 1343 |
</a>
| 1344 |
| 1345 |
<dd>
| 1346 |
Colortext is dichromatic writing in a polygonal font.
| 1347 |
The font is defined in an auxiliary file, such as helvet.fnt.
| 1348 |
The text itself is also specified in a separate file, or can be part of the material arguments.
| 1349 |
The character size, orientation, aspect ratio and slant is determined by right and down motion vectors.
| 1350 |
The upper left origin for the text block as well as the foreground and background colors must also be given.
| 1351 |
| 1352 |
<pre>
| 1353 |
mod colortext id
| 1354 |
2 fontfile textfile
| 1355 |
0
| 1356 |
15+
| 1357 |
Ox Oy Oz
| 1358 |
Rx Ry Rz
| 1359 |
Dx Dy Dz
| 1360 |
rfore gfore bfore
| 1361 |
rback gback bback
| 1362 |
[spacing]
| 1363 |
</pre>
| 1364 |
| 1365 |
or:
| 1366 |
| 1367 |
<pre>
| 1368 |
mod colortext id
| 1369 |
2+N fontfile . This is a line with N words ...
| 1370 |
0
| 1371 |
15+
| 1372 |
Ox Oy Oz
| 1373 |
Rx Ry Rz
| 1374 |
Dx Dy Dz
| 1375 |
rfore gfore bfore
| 1376 |
rback gback bback
| 1377 |
[spacing]
| 1378 |
</pre>
| 1379 |
| 1380 |
<p>
| 1381 |
| 1382 |
<dt>
| 1383 |
<a NAME="Brighttext">
| 1384 |
<b>Brighttext</b>
| 1385 |
</a>
| 1386 |
| 1387 |
<dd>
| 1388 |
Brighttext is like colortext, but the writing is monochromatic.
| 1389 |
| 1390 |
<pre>
| 1391 |
mod brighttext id
| 1392 |
2 fontfile textfile
| 1393 |
0
| 1394 |
11+
| 1395 |
Ox Oy Oz
| 1396 |
Rx Ry Rz
| 1397 |
Dx Dy Dz
| 1398 |
foreground background
| 1399 |
[spacing]
| 1400 |
</pre>
| 1401 |
| 1402 |
or:
| 1403 |
| 1404 |
<pre>
| 1405 |
mod brighttext id
| 1406 |
| 1407 |
0
| 1408 |
11+
| 1409 |
Ox Oy Oz
| 1410 |
Rx Ry Rz
| 1411 |
Dx Dy Dz
| 1412 |
| 1413 |
[spacing]
| 1414 |
</pre>
| 1415 |
| 1416 |
<p>
| 1417 |
| 1418 |
By default, a uniform spacing algorithm is used that guarantees every character will appear in a precisely determined position.
| 1419 |
Unfortunately, such a scheme results in rather unattractive and difficult to read text with most fonts.
| 1420 |
The optional spacing value defines the distance between characters for proportional spacing.
| 1421 |
A positive value selects a spacing algorithm that preserves right margins and indentation,
| 1422 |
but does not provide the ultimate in proportionally spaced text.
| 1423 |
A negative value insures that characters are properly spaced, but the placement of words then varies unpredictably.
| 1424 |
The choice depends on the relative importance of spacing versus formatting.
| 1425 |
When presenting a section of formatted text, a positive spacing value is usually preferred.
| 1426 |
A single line of text will often be accompanied by a negative spacing value.
| 1427 |
A section of text meant to depict a picture, perhaps using a special purpose font such as hexbit4x1.fnt, calls for uniform spacing.
| 1428 |
Reasonable magnitudes for proportional spacing are between 0.1 (for tightly spaced characters) and 0.3 (for wide spacing).
| 1429 |
| 1430 |
</dl>
| 1431 |
| 1432 |
<p>
| 1433 |
<hr>
| 1434 |
| 1435 |
<h4>
| 1436 |
<a NAME="Mixtures">2.1.5. Mixtures</a>
| 1437 |
</h4>
| 1438 |
| 1439 |
A mixture is a blend of one or more materials or textures and patterns.
| 1440 |
Blended materials should not be light source types or virtual source types.
| 1441 |
| 1442 |
| 1443 |
<p>
| 1444 |
| 1445 |
<dl>
| 1446 |
| 1447 |
<dt>
| 1448 |
<a NAME="Mixfunc">
| 1449 |
<b>Mixfunc</b>
| 1450 |
</a>
| 1451 |
| 1452 |
<dd>
| 1453 |
A mixfunc mixes two modifiers procedurally. It is specified as follows:
| 1454 |
| 1455 |
<pre>
| 1456 |
mod mixfunc id
| 1457 |
4+ foreground background vname funcfile transform
| 1458 |
0
| 1459 |
n A1 A2 .. An
| 1460 |
</pre>
| 1461 |
| 1462 |
Foreground and background are modifier names that must be
| 1463 |
defined earlier in the scene description.
| 1464 |
If one of these is a material, then
| 1465 |
the modifier of the mixfunc must be "void".
| 1466 |
(Either the foreground or background modifier may be "void",
| 1467 |
which serves as a form of opacity control when used with a material.)
| 1468 |
Vname is the coefficient defined in funcfile that determines the influence of foreground.
| 1469 |
The background coefficient is always (1-vname).
| 1470 |
| 1471 |
<p>
| 1472 |
| 1473 |
<dt>
| 1474 |
<a NAME="Mixdata">
| 1475 |
<b>Mixdata</b>
| 1476 |
</a>
| 1477 |
| 1478 |
<dd>
| 1479 |
Mixdata combines two modifiers using an auxiliary data file:
| 1480 |
| 1481 |
<pre>
| 1482 |
mod mixdata id
| 1483 |
5+n+
| 1484 |
foreground background func datafile
| 1485 |
| 1486 |
0
| 1487 |
m A1 A2 .. Am
| 1488 |
</pre>
| 1489 |
| 1490 |
<dt>
| 1491 |
<a NAME="Mixpict">
| 1492 |
<b>Mixpict</b>
| 1493 |
</a>
| 1494 |
| 1495 |
<dd>
| 1496 |
Mixpict combines two modifiers based on a picture:
| 1497 |
| 1498 |
<pre>
| 1499 |
mod mixpict id
| 1500 |
7+
| 1501 |
foreground background func pictfile
| 1502 |
| 1503 |
0
| 1504 |
m A1 A2 .. Am
| 1505 |
</pre>
| 1506 |
| 1507 |
<p>
| 1508 |
| 1509 |
The mixing coefficient function "func" takes three
| 1510 |
arguments, the red, green and blue values
| 1511 |
corresponding to the pixel at (u,v).
| 1512 |
| 1513 |
<p>
| 1514 |
| 1515 |
<dt>
| 1516 |
<a NAME="Mixtext">
| 1517 |
<b>Mixtext</b>
| 1518 |
</a>
| 1519 |
| 1520 |
<dd>
| 1521 |
Mixtext uses one modifier for the text foreground, and one for the background:
| 1522 |
| 1523 |
<pre>
| 1524 |
mod mixtext id
| 1525 |
4 foreground background fontfile textfile
| 1526 |
0
| 1527 |
9+
| 1528 |
Ox Oy Oz
| 1529 |
Rx Ry Rz
| 1530 |
Dx Dy Dz
| 1531 |
[spacing]
| 1532 |
</pre>
| 1533 |
| 1534 |
or:
| 1535 |
| 1536 |
<pre>
| 1537 |
mod mixtext id
| 1538 |
4+N
| 1539 |
foreground background fontfile .
| 1540 |
| 1541 |
0
| 1542 |
9+
| 1543 |
Ox Oy Oz
| 1544 |
Rx Ry Rz
| 1545 |
Dx Dy Dz
| 1546 |
[spacing]
| 1547 |
</pre>
| 1548 |
| 1549 |
</dl>
| 1550 |
| 1551 |
<p>
| 1552 |
<hr>
| 1553 |
| 1554 |
<h3>
| 1555 |
<a NAME="Auxiliary">2.2. Auxiliary Files</a>
| 1556 |
</h3>
| 1557 |
| 1558 |
Auxiliary files used in <a HREF="#Textures">textures</a> and <a HREF="#Patterns">patterns</a>
| 1559 |
are accessed by the programs during image generation.
| 1560 |
These files may be located in the working directory, or in a library directory.
| 1561 |
The environment variable RAYPATH can be assigned an alternate set of search directories.
| 1562 |
Following is a brief description of some common file types.
| 1563 |
| 1564 |
<p>
| 1565 |
| 1566 |
<h4>
| 1567 |
<a NAME="Function">12.2.1. Function Files</a>
| 1568 |
</h4>
| 1569 |
| 1570 |
A function file contains the definitions of variables, functions and constants used by a primitive.
| 1571 |
The transformation that accompanies the file name contains the necessary rotations, translations and scalings
| 1572 |
to bring the coordinates of the function file into agreement with the world coordinates.
| 1573 |
The transformation specification is the same as for the <a HREF="#Generators">xform</a> command.
| 1574 |
An example function file is given below:
| 1575 |
| 1576 |
<pre>
| 1577 |
| 1578 |
This is a comment, enclosed in curly braces.
| 1579 |
{Comments can be nested.}
| 1580 |
| 1581 |
{ standard expressions use +,-,*,/,^,(,) }
| 1582 |
vname = Ny * func(A1) ;
| 1583 |
{ constants are defined with a colon }
| 1584 |
const : sqrt(PI/2) ;
| 1585 |
{ user-defined functions add to library }
| 1586 |
func(x) = 5 + A1*sin(x/3) ;
| 1587 |
{ functions may be passed and recursive }
| 1588 |
rfunc(f,x) = if(x,f(x),f(-x)*rfunc(f,x+1)) ;
| 1589 |
{ constant functions may also be defined }
| 1590 |
cfunc(x) : 10*x / sqrt(x) ;
| 1591 |
</pre>
| 1592 |
| 1593 |
Many variables and functions are already defined by the program, and they are listed in the file rayinit.cal.
| 1594 |
The following variables are particularly important:
| 1595 |
| 1596 |
<pre>
| 1597 |
Dx, Dy, Dz - incident ray direction
| 1598 |
Nx, Ny, Nz - surface normal at intersection point
| 1599 |
Px, Py, Pz - intersection point
| 1600 |
T - distance from start
| 1601 |
Ts - single ray (shadow) distance
| 1602 |
Rdot - cosine between ray and normal
| 1603 |
arg(0) - number of real arguments
| 1604 |
arg(i) - i'th real argument
| 1605 |
</pre>
| 1606 |
| 1607 |
For mesh objects, the local surface coordinates are available:
| 1608 |
| 1609 |
<pre>
| 1610 |
Lu, Lv - local (u,v) coordinates
| 1611 |
</pre>
| 1612 |
| 1613 |
For BRDF types, the following variables are defined as well:
| 1614 |
| 1615 |
<pre>
| 1616 |
NxP, NyP, NzP - perturbed surface normal
| 1617 |
RdotP - perturbed dot product
| 1618 |
CrP, CgP, CbP - perturbed material color
| 1619 |
</pre>
| 1620 |
| 1621 |
A unique context is set up for each file so
| 1622 |
that the same variable may appear in different
| 1623 |
function files without conflict.
| 1624 |
The variables listed above and any others defined in
| 1625 |
rayinit.cal are available globally.
| 1626 |
If no file is needed by a given primitive because all
| 1627 |
the required variables are global,
| 1628 |
a period (`.') can be given in place of the file name.
| 1629 |
It is also possible to give an expression instead
| 1630 |
of a straight variable name in a scene file.
| 1631 |
Functions (requiring parameters) must be given
| 1632 |
as names and not as expressions.
| 1633 |
| 1634 |
<p>
| 1635 |
Constant expressions are used as an optimization in function files.
| 1636 |
They are replaced wherever they occur in an expression by their value.
| 1637 |
Constant expressions are evaluated only once, so they must not contain any variables or values that can change,
| 1638 |
such as the ray variables Px and Ny or the primitive argument function arg().
| 1639 |
All the math library functions such as sqrt() and cos() have the constant attribute,
| 1640 |
so they will be replaced by immediate values whenever they are given constant arguments.
| 1641 |
Thus, the subexpression cos(PI*sqrt(2)) is immediately replaced by its value, -.266255342,
| 1642 |
and does not cause any additional overhead in the calculation.
| 1643 |
| 1644 |
<p>
| 1645 |
It is generally a good idea to define constants and variables before they are referred to in a function file.
| 1646 |
Although evaluation does not take place until later, the interpreter does variable scoping and
| 1647 |
constant subexpression evaluation based on what it has compiled already.
| 1648 |
For example, a variable that is defined globally in rayinit.cal
| 1649 |
then referenced in the local context of a function file
| 1650 |
cannot subsequently be redefined in the same file
| 1651 |
because the compiler has already determined the scope of the referenced variable as global.
| 1652 |
To avoid such conflicts, one can state the scope of a variable explicitly by
| 1653 |
preceding the variable name with a context mark (a back-quote) for a local variable,
| 1654 |
or following the name with a context mark for a global variable.
| 1655 |
| 1656 |
<p>
| 1657 |
| 1658 |
<h4>
| 1659 |
<a NAME="Data">2.2.2. Data Files</a>
| 1660 |
</h4>
| 1661 |
| 1662 |
Data files contain n-dimensional arrays of real numbers used for interpolation.
| 1663 |
Typically, definitions in a function file determine how to index and use interpolated data values.
| 1664 |
The basic data file format is as follows:
| 1665 |
| 1666 |
<pre>
| 1667 |
N
| 1668 |
beg1 end1 m1
| 1669 |
0 0 m2 x2.1 x2.2 x2.3 x2.4 .. x2.m2
| 1670 |
| 1671 |
begN endN mN
| 1672 |
DATA, later dimensions changing faster.
| 1673 |
</pre>
| 1674 |
| 1675 |
N is the number of dimensions.
| 1676 |
For each dimension, the beginning and ending coordinate values and the dimension size is given.
| 1677 |
Alternatively, individual coordinate values can be given when the points are not evenly spaced.
| 1678 |
These values must either be increasing or decreasing monotonically.
| 1679 |
The data is m1*m2*...*mN real numbers in ASCII form.
| 1680 |
Comments may appear anywhere in the file, beginning with a pound
| 1681 |
sign ('#') and continuing to the end of line.
| 1682 |
| 1683 |
<p>
| 1684 |
| 1685 |
<h4>
| 1686 |
<a NAME="Font">2.2.3. Font Files</a>
| 1687 |
</h4>
| 1688 |
| 1689 |
A font file lists the polygons which make up a character set.
| 1690 |
| 1691 |
| 1692 |
All numbers are decimal integers:
| 1693 |
| 1694 |
<pre>
| 1695 |
code n
| 1696 |
x0 y0
| 1697 |
x1 y1
| 1698 |
| 1699 |
xn yn
| 1700 |
| 1701 |
</pre>
| 1702 |
| 1703 |
The ASCII codes can appear in any order. N is the number of vertices, and the last is automatically connected to the first.
| 1704 |
Separate polygonal sections are joined by coincident sides.
| 1705 |
The character coordinate system is a square with lower left corner at (0,0), lower right at (255,0) and upper right at (255,255).
| 1706 |
| 1707 |
<p>
| 1708 |
| 1709 |
<hr>
| 1710 |
| 1711 |
<h3>
| 1712 |
<a NAME="Generators">2.3. Generators</a>
| 1713 |
</h3>
| 1714 |
| 1715 |
A generator is any program that produces a scene description as its output.
| 1716 |
They usually appear as commands in a scene description file.
| 1717 |
An example of a simple generator is genbox.
| 1718 |
| 1719 |
<ul>
| 1720 |
| 1721 |
<li>
| 1722 |
<a NAME="Genbox" HREF="../man_html/genbox.1.html">
| 1723 |
<b>Genbox</b>
| 1724 |
</a>
| 1725 |
takes the arguments of width, height and depth to produce a parallelepiped description.
| 1726 |
<li>
| 1727 |
<a NAME="Genprism" HREF="../man_html/genprism.1.html">
| 1728 |
<b>Genprism</b>
| 1729 |
</a>
| 1730 |
takes a list of 2-dimensional coordinates and extrudes them along a vector to
| 1731 |
produce a 3-dimensional prism.
| 1732 |
<li>
| 1733 |
<a NAME="Genrev" HREF="../man_html/genrev.1.html">
| 1734 |
<b>Genrev</b>
| 1735 |
</a>
| 1736 |
is a more sophisticated generator that produces an object of rotation from parametric functions for radius and axis position.
| 1737 |
<li>
| 1738 |
<a NAME="Gensurf" HREF="../man_html/gensurf.1.html">
| 1739 |
<b>Gensurf</b>
| 1740 |
</a>
| 1741 |
tessellates a surface defined by the parametric functions x(s,t), y(s,t), and z(s,t).
| 1742 |
<li>
| 1743 |
<a NAME="Genworm" HREF="../man_html/genworm.1.html">
| 1744 |
<b>Genworm</b>
| 1745 |
</a>
| 1746 |
links cylinders and spheres along a curve.
| 1747 |
<li>
| 1748 |
<a NAME="Gensky" HREF="../man_html/gensky.1.html">
| 1749 |
<b>Gensky</b>
| 1750 |
</a>
| 1751 |
produces a sun and sky distribution corresponding to a given time and date.
| 1752 |
<li>
| 1753 |
<a NAME="Xform" HREF="../man_html/xform.1.html">
| 1754 |
<b>Xform</b>
| 1755 |
</a>
| 1756 |
is a program that transforms a scene description from one coordinate space to another.
| 1757 |
Xform does rotation, translation, scaling, and mirroring.
| 1758 |
| 1759 |
</ul>
| 1760 |
| 1761 |
<p>
| 1762 |
<hr>
| 1763 |
| 1764 |
<h2>
| 1765 |
<a NAME="Image">3. Image Generation</a>
| 1766 |
</h2>
| 1767 |
| 1768 |
Once the scene has been described in three-dimensions, it is possible to generate a two-dimensional image from a given perspective.
| 1769 |
| 1770 |
<p>
| 1771 |
The image generating programs use an <a NAME="octree"><b>octree</b></a> to efficiently trace rays through the scene.
| 1772 |
An octree subdivides space into nested octants which contain sets of surfaces.
| 1773 |
In RADIANCE, an octree is created from a scene description by <a NAME="oconv1" HREF="../man_html/oconv.1.html"><b>oconv</b></a>.
| 1774 |
The details of this process are not important, but the octree will serve as input to the ray-tracing programs and
| 1775 |
directs the use of a scene description.
| 1776 |
<ul>
| 1777 |
<li>
| 1778 |
<a NAME="rvu" HREF="../man_html/rvu.1.html"><b>Rview</b></a> is ray-tracing program for viewing a scene interactively.
| 1779 |
When the user specifies a new perspective, rvu quickly displays a rough image on the terminal,
| 1780 |
then progressively increases the resolution as the user looks on.
| 1781 |
He can select a particular section of the image to improve, or move to a different view and start over.
| 1782 |
This mode of interaction is useful for debugging scenes as well as determining the best view for a final image.
| 1783 |
| 1784 |
<li>
| 1785 |
<a NAME="rpict" HREF="../man_html/rpict.1.html"><b>Rpict</b></a> produces a high-resolution picture of a scene from a particular perspective.
| 1786 |
This program features adaptive sampling, crash recovery and progress reporting, all of which are important for time-consuming images.
| 1787 |
</ul>
| 1788 |
<p>
| 1789 |
A number of <a NAME="filters"><b>filters</b></a> are available for manipulating picture files:
| 1790 |
<ul>
| 1791 |
<li> <a HREF="../man_html/pfilt.1.html"><b>Pfilt</b></a>
| 1792 |
sets the exposure and performs antialiasing.
| 1793 |
<li> <a HREF="../man_html/pcompos.1.html"><b>Pcompos</b></a>
| 1794 |
composites (cuts and pastes) pictures.
| 1795 |
<li> <a HREF="../man_html/pcomb.1.html"><b>Pcomb</b></a>
| 1796 |
performs arbitrary math on one or more pictures.
| 1797 |
<li> <a HREF="../man_html/pcond.1.html"><b>Pcond</b></a>
| 1798 |
conditions a picture for a specific display device.
| 1799 |
<li> <a HREF="../man_html/protate.1.html"><b>Protate</b></a>
| 1800 |
rotates a picture 90 degrees clockwise.
| 1801 |
<li> <a HREF="../man_html/pflip.1.html"><b>Pflip</b></a>
| 1802 |
flips a picture horizontally, vertically, or both
| 1803 |
(180 degree rotation).
| 1804 |
<li> <a HREF="../man_html/pvalue.1.html"><b>Pvalue</b></a>
| 1805 |
converts a picture to and from simpler formats.
| 1806 |
</ul>
| 1807 |
| 1808 |
<p>
| 1809 |
Pictures may be displayed directly under X11 using the program
| 1810 |
<a HREF="../man_html/ximage.1.html">ximage</a>,
| 1811 |
or converted a standard image format using one of the following
| 1812 |
<b>translators</b>:
| 1813 |
<ul>
| 1814 |
<li> <a HREF="../man_html/ra_bmp.1.html"><b>Ra_bmp</b>
| 1815 |
converts to and from BMP image format.
| 1816 |
<li> <a HREF="../man_html/ra_ppm.1.html"><b>Ra_ppm</b></a>
| 1817 |
converts to and from Poskanzer Portable Pixmap formats.
| 1818 |
<li> <a HREF="../man_html/ra_ps.1.html"><b>Ra_ps</b></a>
| 1819 |
converts to PostScript color and greyscale formats.
| 1820 |
<li> <a HREF="../man_html/ra_rgbe.1.html"><b>Ra_rgbe</b></a>
| 1821 |
converts to and from Radiance uncompressed picture format.
| 1822 |
<li> <a HREF="../man_html/ra_t16.1.html"><b>Ra_t16</b></a>
| 1823 |
converts to and from Targa 16 and 24-bit image formats.
| 1824 |
<li> <a HREF="../man_html/ra_t8.1.html"><b>Ra_t8</b></a>
| 1825 |
converts to and from Targa 8-bit image format.
| 1826 |
<li> <a HREF="../man_html/ra_tiff.1.html"><b>Ra_tiff</b></a>
| 1827 |
converts to and from TIFF.
| 1828 |
<li> <a HREF="../man_html/ra_xyze.1.html"><b>Ra_xyze</b></a>
| 1829 |
converts to and from Radiance CIE picture format.
| 1830 |
</ul>
| 1831 |
| 1832 |
<p>
| 1833 |
| 1834 |
<hr>
| 1835 |
| 1836 |
<h2>
| 1837 |
<a NAME="License">4. License</a>
| 1838 |
</h2>
| 1839 |
| 1840 |
<pre>
| 1841 |
The Radiance Software License, Version 1.0
| 1842 |
| 1843 |
Copyright (c) 1990 - 2014 The Regents of the University of California,
| 1844 |
through Lawrence Berkeley National Laboratory. All rights reserved.
| 1845 |
| 1846 |
Redistribution and use in source and binary forms, with or without
| 1847 |
modification, are permitted provided that the following conditions
| 1848 |
are met:
| 1849 |
| 1850 |
1. Redistributions of source code must retain the above copyright
| 1851 |
notice, this list of conditions and the following disclaimer.
| 1852 |
| 1853 |
2. Redistributions in binary form must reproduce the above copyright
| 1854 |
notice, this list of conditions and the following disclaimer in
| 1855 |
the documentation and/or other materials provided with the
| 1856 |
distribution.
| 1857 |
| 1858 |
3. The end-user documentation included with the redistribution,
| 1859 |
if any, must include the following acknowledgment:
| 1860 |
"This product includes Radiance software
| 1861 |
(<a HREF="http://radsite.lbl.gov/">http://radsite.lbl.gov/</a>)
| 1862 |
developed by the Lawrence Berkeley National Laboratory
| 1863 |
(<a HREF="http://www.lbl.gov/">http://www.lbl.gov/</a>)."
| 1864 |
Alternately, this acknowledgment may appear in the software itself,
| 1865 |
if and wherever such third-party acknowledgments normally appear.
| 1866 |
| 1867 |
4. The names "Radiance," "Lawrence Berkeley National Laboratory"
| 1868 |
and "The Regents of the University of California" must
| 1869 |
not be used to endorse or promote products derived from this
| 1870 |
software without prior written permission. For written
| 1871 |
permission, please contact [email protected].
| 1872 |
| 1873 |
5. Products derived from this software may not be called "Radiance",
| 1874 |
nor may "Radiance" appear in their name, without prior written
| 1875 |
permission of Lawrence Berkeley National Laboratory.
| 1876 |
| 1877 |
THIS SOFTWARE IS PROVIDED ``AS IS" AND ANY EXPRESSED OR IMPLIED
| 1878 |
WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
| 1879 |
OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
| 1880 |
DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
| 1881 |
ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
| 1882 |
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
| 1883 |
LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
| 1884 |
USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
| 1885 |
ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
| 1886 |
OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
| 1887 |
OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
| 1888 |
SUCH DAMAGE.
| 1889 |
</pre>
| 1890 |
| 1891 |
<hr>
| 1892 |
| 1893 |
<h2>
| 1894 |
<a NAME="Ack">5. Acknowledgements</a>
| 1895 |
</h2>
| 1896 |
| 1897 |
This work was supported by the Assistant Secretary of Conservation and Renewable Energy,
| 1898 |
Office of Building Energy Research and Development,
| 1899 |
Buildings Equipment Division of the U.S. Department of Energy under Contract No. DE-AC03-76SF00098.
| 1900 |
| 1901 |
<p>
| 1902 |
Additional work was sponsored by the Swiss federal government
| 1903 |
under the Swiss LUMEN Project and was carried out in the
| 1904 |
Laboratoire d'Energie Solaire (LESO Group) at the
| 1905 |
Ecole Polytechnique Federale de Lausanne (EPFL University) in Lausanne, Switzerland.
| 1906 |
| 1907 |
<p>
| 1908 |
| 1909 |
<hr>
| 1910 |
| 1911 |
<h2>
| 1912 |
<a NAME="Ref">6.</a> References
| 1913 |
</h2>
| 1914 |
<p>
| 1915 |
<ul>
| 1916 |
<li>McNeil, A., C.J. Jonsson, D. Appelfeld, G. Ward, E.S. Lee,
| 1917 |
"<a href="http://gaia.lbl.gov/btech/papers/4414.pdf">
| 1918 |
A validation of a ray-tracing tool used to generate
| 1919 |
bi-directional scattering distribution functions for
| 1920 |
complex fenestration systems</a>,"
| 1921 |
<em>Solar Energy</em>, 98, 404-14,
| 1922 |
November 2013.
| 1923 |
<li>Ward, G., R. Mistrick, E.S. Lee, A. McNeil, J. Jonsson,
| 1924 |
"<a href="http://gaia.lbl.gov/btech/papers/4414.pdf">Simulating
| 1925 |
the Daylight Performance of Complex Fenestration Systems
| 1926 |
Using Bidirectional Scattering Distribution Functions within
| 1927 |
Radiance</a>,"
| 1928 |
<em>Leukos</em>, 7(4)
| 1929 |
April 2011.
| 1930 |
<li>Cater, Kirsten, Alan Chalmers, Greg Ward,
| 1931 |
"<a href="http://www.anyhere.com/gward/papers/egsr2003.pdf">Detail to Attention:
| 1932 |
Exploiting Visual Tasks for Selective Rendering</a>,"
| 1933 |
<em>Eurographics Symposium
| 1934 |
on Rendering 2003</em>, June 2003.
| 1935 |
<li>Ward, Greg, Elena Eydelberg-Vileshin,
| 1936 |
"<a HREF="http://www.anyhere.com/gward/papers/egwr02/index.html">Picture Perfect RGB
| 1937 |
Rendering Using Spectral Prefiltering and Sharp Color Primaries</a>,"
| 1938 |
Thirteenth Eurographics Workshop on Rendering (2002),
| 1939 |
P. Debevec and S. Gibson (Editors), June 2002.
| 1940 |
<li>Ward, Gregory,
| 1941 |
"<a HREF="http://www.anyhere.com/gward/papers/cic01.pdf">High Dynamic Range Imaging</a>,"
| 1942 |
Proceedings of the Ninth Color Imaging Conference, November 2001.
| 1943 |
<li>Ward, Gregory and Maryann Simmons,
| 1944 |
"<a HREF="http://www.anyhere.com/gward/papers/tog99.pdf">
| 1945 |
The Holodeck Ray Cache: An Interactive Rendering System for Global Illumination in Nondiffuse
| 1946 |
Environments</a>," ACM Transactions on Graphics, 18(4):361-98, October 1999.
| 1947 |
<li>Larson, G.W., "<a HREF="http://www.anyhere.com/gward/papers/ewp98.pdf">The Holodeck: A Parallel
| 1948 |
Ray-caching Rendering System</a>," Proceedings of the Second
| 1949 |
Eurographics Workshop on Parallel Graphics and Visualisation,
| 1950 |
September 1998.
| 1951 |
<li>Larson, G.W. and R.A. Shakespeare,
| 1952 |
<a HREF="http://radsite.lbl.gov/radiance/book/index.html"><em>Rendering with Radiance:
| 1953 |
the Art and Science of Lighting Visualization</em></a>,
| 1954 |
Morgan Kaufmann Publishers, 1998.
| 1955 |
<li>Larson, G.W., H. Rushmeier, C. Piatko,
| 1956 |
"<a HREF="http://radsite.lbl.gov/radiance/papers/lbnl39882/tonemap.pdf">A Visibility
| 1957 |
Matching Tone Reproduction Operator for
| 1958 |
High Dynamic Range Scenes</a>," LBNL Technical Report 39882,
| 1959 |
January 1997.
| 1960 |
<li>Ward, G., "<a HREF="http://radsite.lbl.gov/radiance/papers/erw95.1/paper.html">Making
| 1961 |
Global Illumination User-Friendly</a>," Sixth
| 1962 |
Eurographics Workshop on Rendering, Springer-Verlag,
| 1963 |
Dublin, Ireland, June 1995.</li>
| 1964 |
<li>Rushmeier, H., G. Ward, C. Piatko, P. Sanders, B. Rust,
| 1965 |
"<a HREF="http://radsite.lbl.gov/mgf/compare.html">
| 1966 |
Comparing Real and Synthetic Images: Some Ideas about
| 1967 |
Metrics</a>," Sixth Eurographics Workshop on Rendering,
| 1968 |
Springer-Verlag, Dublin, Ireland, June 1995.</li>
| 1969 |
<li>Ward, G., "<a HREF="http://radsite.lbl.gov/radiance/papers/sg94.1/paper.html">The RADIANCE
| 1970 |
Lighting Simulation and Rendering System</a>," <em>Computer
| 1971 |
Graphics</em>, July 1994.</li>
| 1972 |
<li>Rushmeier, H., G. Ward, "<a HREF="http://radsite.lbl.gov/radiance/papers/sg94.2/energy.html">Energy
| 1973 |
Preserving Non-Linear Filters</a>," <em>Computer
| 1974 |
| 1975 |
<li>Ward, G., "A Contrast-Based Scalefactor for Luminance
| 1976 |
Display," <em>Graphics Gems IV</em>, Edited by Paul Heckbert,
| 1977 |
Academic Press 1994.</li>
| 1978 |
<li>Ward, G., "<a HREF="http://radsite.lbl.gov/radiance/papers/sg92/paper.html">Measuring and
| 1979 |
Modeling Anisotropic Reflection</a>," <em>Computer
| 1980 |
Graphics</em>, Vol. 26, No. 2, July 1992. </li>
| 1981 |
<li>Ward, G., P. Heckbert, "<a HREF="http://radsite.lbl.gov/radiance/papers/erw92/paper.html">Irradiance
| 1982 |
Gradients</a>," Third Annual Eurographics Workshop on
| 1983 |
Rendering, Springer-Verlag, May 1992. </li>
| 1984 |
<li>Ward, G., "<a HREF="http://radsite.lbl.gov/radiance/papers/erw91/erw91.html">Adaptive Shadow
| 1985 |
Testing for Ray Tracing</a>" Photorealistic Rendering in
| 1986 |
Computer Graphics, proceedings of 1991 Eurographics
| 1987 |
Rendering Workshop, edited by P. Brunet and F.W. Jansen,
| 1988 |
Springer-Verlag. </li>
| 1989 |
<li>Ward, G., "Visualization," <em>Lighting Design and
| 1990 |
Application</em>, Vol. 20, No. 6, June 1990. </li>
| 1991 |
<li>Ward, G., F. Rubinstein, R. Clear, "<a HREF="http://radsite.lbl.gov/radiance/papers/sg88/paper.html">A Ray Tracing Solution for
| 1992 |
Diffuse Interreflection</a>," <em>Computer Graphics</em>,
| 1993 |
Vol. 22, No. 4, August 1988. </li>
| 1994 |
<li>Ward, G., F. Rubinstein, "A New Technique for Computer
| 1995 |
Simulation of Illuminated Spaces," <em>Journal of the
| 1996 |
Illuminating Engineering Society</em>, Vol. 17, No. 1,
| 1997 |
Winter 1988. </li>
| 1998 |
</ul>
| 1999 |
<p>
| 2000 |
See the <a HREF="index.html">RADIANCE Reference Materials</a> page
| 2001 |
for additional information.
| 2002 |
<hr>
| 2003 |
| 2004 |
<a NAME="Index"><h2>7. Types Index</h2></a>
| 2005 |
| 2006 |
<pre>
| 2007 |
<h4>
| 2008 |
SURFACES MATERIALS TEXTURES PATTERNS MIXTURES</h4>
| 2009 |
<a HREF="#Source">Source</a> <a HREF="#Light">Light</a> <a HREF="#Texfunc">Texfunc</a> <a HREF="#Colorfunc">Colorfunc</a> <a HREF="#Mixfunc">Mixfunc</a>
| 2010 |
<a HREF="#Sphere">Sphere</a> <a HREF="#Illum">Illum</a> <a HREF="#Texdata">Texdata</a> <a HREF="#Brightfunc">Brightfunc</a> <a HREF="#Mixdata">Mixdata</a>
| 2011 |
<a HREF="#Bubble">Bubble</a> <a HREF="#Glow">Glow</a> <a HREF="#Colordata">Colordata</a> <a HREF="#Mixtext">Mixtext</a>
| 2012 |
<a HREF="#Polygon">Polygon</a> <a HREF="#Spotlight">Spotlight</a> <a HREF="#Brightdata">Brightdata</a>
| 2013 |
<a HREF="#Cone">Cone</a> <a HREF="#Mirror">Mirror</a> <a HREF="#Colorpict">Colorpict</a>
| 2014 |
<a HREF="#Cup">Cup</a> <a HREF="#Prism1">Prism1</a> <a HREF="#Colortext">Colortext</a>
| 2015 |
<a HREF="#Cylinder">Cylinder</a> <a HREF="#Prism2">Prism2</a> <a HREF="#Brighttext">Brighttext</a>
| 2016 |
<a HREF="#Tube">Tube</a> <a HREF="#Plastic">Plastic</a>
| 2017 |
<a HREF="#Ring">Ring</a> <a HREF="#Metal">Metal</a>
| 2018 |
<a HREF="#Instance">Instance</a> <a HREF="#Trans">Trans</a>
| 2019 |
<a HREF="#Mesh">Mesh</a> <a HREF="#Plastic2">Plastic2</a>
| 2020 |
<a HREF="#Metal2">Metal2</a>
| 2021 |
<a HREF="#Trans2">Trans2</a>
| 2022 |
<a HREF="#Mist">Mist</a>
| 2023 |
<a HREF="#Dielectric">Dielectric</a>
| 2024 |
<a HREF="#Interface">Interface</a>
| 2025 |
<a HREF="#Glass">Glass</a>
| 2026 |
<a HREF="#Plasfunc">Plasfunc</a>
| 2027 |
<a HREF="#Metfunc">Metfunc</a>
| 2028 |
<a HREF="#Transfunc">Transfunc</a>
| 2029 |
<a HREF="#BRTDfunc">BRTDfunc</a>
| 2030 |
<a HREF="#Plasdata">Plasdata</a>
| 2031 |
<a HREF="#Metdata">Metdata</a>
| 2032 |
<a HREF="#Transdata">Transdata</a>
| 2033 |
<a HREF="#BSDF">BSDF</a>
| 2034 |
<a HREF="#Antimatter">Antimatter</a>
| 2035 |
| 2036 |
</pre>
| 2037 |
| 2038 |
<p>
| 2039 |
| 2040 |
| 2041 |
<hr>
| 2042 |
<center>Last Update: October 22, 1997</center>
| 2043 |
</body>
| 2044 |
</html>
| 2045 |
