--- ray/doc/ray.html 2010/03/12 18:43:30 1.9
+++ ray/doc/ray.html 2023/05/11 17:18:39 1.31
@@ -1,7 +1,8 @@
-The RADIANCE 4.0 Synthetic Imaging System
+The RADIANCE 5.4 Synthetic Imaging System
@@ -9,7 +10,7 @@ The RADIANCE 4.0 Synthetic Imaging System
@@ -82,7 +83,7 @@ The diagram in Figure 1 shows the flow between program
(ovals).
The central program is rpict, which produces a picture from a scene
description.
-Rview is a variation of rpict that computes and displays images
+Rvu is a variation of rpict that computes and displays images
interactively, and rtrace computes single ray values.
Other programs (not shown) connect many of these elements together,
such as the executive programs
@@ -797,7 +798,8 @@ unless the line integrals consider enclosed geometry.
Trans2 is the anisotropic version of trans.
- The string arguments are the same as for plastic2, and the real arguments are the same as for trans but with an additional roughness value.
+ The string arguments are the same as for plastic2,
+ and the real arguments are the same as for trans but with an additional roughness value.
mod trans2 id
@@ -809,6 +811,29 @@ unless the line integrals consider enclosed geometry.
+ Ashik2
+ Ashik2 is the anisotropic reflectance model by Ashikhmin & Shirley.
+ The string arguments are the same as for plastic2, but the real
+ arguments have additional flexibility to specify the specular color.
+ Also, rather than roughness, specular power is used, which has no
+ physical meaning other than larger numbers are equivalent to a smoother
+ surface.
+ Unlike other material types, total reflectance is the sum of
+ diffuse and specular colors, and should be adjusted accordingly.
+ mod ashik2 id
+ 4+ ux uy uz funcfile transform
+ 0
+ 8 dred dgrn dblu sred sgrn sblu u-power v-power
Dielectric
@@ -1053,6 +1078,116 @@ unless the line integrals consider enclosed geometry.
+ BSDF
+ The BSDF material type loads an XML (eXtensible Markup Language)
+ file describing a bidirectional scattering distribution function.
+ Real arguments to this material may define additional
+ diffuse components that augment the BSDF data.
+ String arguments are used to define thickness for proxied
+ surfaces and the "up" orientation for the material.
+ mod BSDF id
+ 6+ thick BSDFfile ux uy uz funcfile transform
+ 0
+ 0|3|6|9
+ rfdif gfdif bfdif
+ rbdif gbdif bbdif
+ rtdif gtdif btdif
+ The first string argument is a "thickness" parameter that may be used
+ to hide detail geometry being proxied by an aggregate BSDF material.
+ If a view or shadow ray hits a BSDF proxy with non-zero thickness,
+ it will pass directly through as if the surface were not there.
+ Similar to the illum type, this permits direct viewing and
+ shadow testing of complex geometry.
+ The BSDF is used when a scattered (indirect) ray hits the surface,
+ and any transmitted sample rays will be offset by the thickness amount
+ to avoid the hidden geometry and gather samples from the other side.
+ In this manner, BSDF surfaces can improve the results for indirect
+ scattering from complex systems without sacrificing appearance or
+ shadow accuracy.
+ If the BSDF has transmission and back-side reflection data,
+ a parallel BSDF surface may be
+ placed slightly less than the given thickness away from the front surface
+ to enclose the complex geometry on both sides.
+ The sign of the thickness is important, as it indicates
+ whether the proxied geometry is behind the BSDF
+ surface (when thickness is positive) or in front (when
+ thickness is negative).
+ The second string argument is the name of the BSDF file,
+ which is found in the usual auxiliary locations. The
+ following three string parameters name variables for an
+ "up" vector, which together with the surface
+ normal, define the local coordinate system that orients the
+ BSDF. These variables, along with the thickness, are defined
+ in a function file given as the next string argument. An
+ optional transform is used to scale the thickness and
+ reorient the up vector.
+ If no real arguments are given, the BSDF is used by itself
+ to determine reflection and transmission. If there are at
+ least 3 real arguments, the first triplet is an additional
+ diffuse reflectance for the front side. At least 6 real
+ arguments adds diffuse reflectance to the rear side of the
+ surface. If there are 9 real arguments, the final triplet
+ will be taken as an additional diffuse transmittance. All
+ diffuse components as well as the non-diffuse transmission
+ are modified by patterns applied to this material. The
+ non-diffuse reflection from either side are unaffected.
+ Textures perturb the effective surface normal in the usual
+ way.
+ The surface normal of this type is not altered to face the
+ incoming ray, so the front and back BSDF reflections may
+ differ. (Transmission is identical front-to-back by physical
+ law.) If back visibility is turned off during rendering and
+ there is no transmission or back-side reflection, only then
+ the surface will be invisible from behind. Unlike other
+ data-driven material types, the BSDF type is fully supported
+ and all parts of the distribution are properly sampled.
+ aBSDF
+ The aBSDF material is identical to the BSDF type with two
+ important differences. First, proxy geometry is not
+ supported, so there is no thickness parameter. Second, an
+ aBSDF is assumed to have some specular through component
+ (the ’a’ stands for "aperture"),
+ which is treated specially during the direct calculation
+ and when viewing the material. Based on the BSDF data, the
+ coefficient of specular transmission is determined and used
+ for modifying unscattered shadow and view rays.
+ mod aBSDF id
+ 5+ BSDFfile ux uy uz funcfile transform
+ 0
+ 0|3|6|9
+ rfdif gfdif bfdif
+ rbdif gbdif bbdif
+ rtdif gtdif btdif
+ If a material has no specular transmitted component, it is
+ much better to use the BSDF type with a zero thickness
+ than to use aBSDF.
Antimatter
@@ -1336,6 +1471,7 @@ or:
A mixture is a blend of one or more materials or textures and patterns.
+Blended materials should not be light source types or virtual source types.
The basic types are given below.
@@ -1408,7 +1544,6 @@ A mixfunc mixes two modifiers procedurally. It i
arguments, the red, green and blue values
corresponding to the pixel at (u,v).
@@ -1674,7 +1809,7 @@ The details of this process are not important, but
directs the use of a scene description.
-Rview is ray-tracing program for viewing a scene interactively.
+Rvu is ray-tracing program for viewing a scene interactively.
When the user specifies a new perspective, rvu quickly displays a rough image on the terminal,
then progressively increases the resolution as the user looks on.
He can select a particular section of the image to improve, or move to a different view and start over.
@@ -1710,16 +1845,10 @@ Pictures may be displayed directly under X11 using the
or converted a standard image format using one of the following
translators:
- - Ra_avs
- converts to and from AVS image format.
- Ra_pict
- converts to Macintosh 32-bit PICT2 format.
- Ra_bmp
+ converts to and from BMP image format.
- Ra_ppm
converts to and from Poskanzer Portable Pixmap formats.
- Ra_pr
- converts to and from Sun 8-bit rasterfile format.
- Ra_pr24
- converts to and from Sun 24-bit rasterfile format.
- Ra_ps
converts to PostScript color and greyscale formats.
- Ra_rgbe
@@ -1745,7 +1874,7 @@ or converted a standard image format using one of the
The Radiance Software License, Version 1.0
-Copyright (c) 1990 - 2010 The Regents of the University of California,
+Copyright (c) 1990 - 2021 The Regents of the University of California,
through Lawrence Berkeley National Laboratory. All rights reserved.
Redistribution and use in source and binary forms, with or without
@@ -1779,7 +1908,7 @@ are met:
nor may "Radiance" appear in their name, without prior written
permission of Lawrence Berkeley National Laboratory.
-THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
+THIS SOFTWARE IS PROVIDED ``AS IS" AND ANY EXPRESSED OR IMPLIED
WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
@@ -1818,25 +1947,65 @@ Ecole Polytechnique Federale de Lausanne (EPFL Unive
+ - Wang, Taoning, Gregory Ward, Eleanor Lee,
+ "Efficient
+ modeling of optically-complex, non-coplanar exterior shading:
+ Validation of matrix algebraic methods"
+ Energy & Buildings, vol. 174, pp. 464-83, Sept. 2018.
- Lee, Eleanor S., David Geisler-Moroder, Gregory Ward,
+ "Modeling
+ the direct sun component in buildings using matrix
+ algebraic approaches: Methods and
+ validation," Solar Energy,
+ vol. 160, 15 January 2018, pp 380-395.
- Narain, Rahul, Rachel A. Albert, Abdullah Bulbul,
+ Gregory J. Ward, Marty Banks, James F. O'Brien,
+ "Optimal
+ Presentation of Imagery with Focus
+ Cues on Multi-Plane Displays,"
+ SIGGRAPH 2015.
- Ward, Greg, Murat Kurt, and Nicolas Bonneel,
+ "Reducing
+ Anisotropic BSDF Measurement to Common Practice,"
+ Workshop on Material Appearance Modeling, 2014.
- Banks, Martin, Abdullah Bulbul, Rachel Albert, Rahul Narain,
+ James F. O'Brien, Gregory Ward,
+ "The
+ Perception of Surface Material from Disparity and Focus Cues,"
+ VSS 2014.
- McNeil, A., C.J. Jonsson, D. Appelfeld, G. Ward, E.S. Lee,
+ A validation of a ray-tracing tool used to generate
+ bi-directional scattering distribution functions for
+ complex fenestration systems,"
+ Solar Energy, 98, 404-14,
+ November 2013.
- Ward, G., R. Mistrick, E.S. Lee, A. McNeil, J. Jonsson,
+ "Simulating
+ the Daylight Performance of Complex Fenestration Systems
+ Using Bidirectional Scattering Distribution Functions within
+ Radiance,"
+ Leukos, 7(4)
+ April 2011.
- Cater, Kirsten, Alan Chalmers, Greg Ward,
"Detail to Attention:
Exploiting Visual Tasks for Selective Rendering,"
Eurographics Symposium
on Rendering 2003, June 2003.
- Ward, Greg, Elena Eydelberg-Vileshin,
- ``Picture Perfect RGB
- Rendering Using Spectral Prefiltering and Sharp Color Primaries,''
+ "Picture Perfect RGB
+ Rendering Using Spectral Prefiltering and Sharp Color Primaries,"
Thirteenth Eurographics Workshop on Rendering (2002),
P. Debevec and S. Gibson (Editors), June 2002.
- Ward, Gregory,
- ``High Dynamic Range Imaging,''
+ "High Dynamic Range Imaging,"
Proceedings of the Ninth Color Imaging Conference, November 2001.
- Ward, Gregory and Maryann Simmons,
The Holodeck Ray Cache: An Interactive Rendering System for Global Illumination in Nondiffuse
- Environments,'' ACM Transactions on Graphics, 18(4):361-98, October 1999.
- Larson, G.W., ``The Holodeck: A Parallel
- Ray-caching Rendering System,'' Proceedings of the Second
+ Environments," ACM Transactions on Graphics, 18(4):361-98, October 1999.
- Larson, G.W., "The Holodeck: A Parallel
+ Ray-caching Rendering System," Proceedings of the Second
Eurographics Workshop on Parallel Graphics and Visualisation,
September 1998.
- Larson, G.W. and R.A. Shakespeare,
@@ -1844,46 +2013,46 @@ Ecole Polytechnique Federale de Lausanne (EPFL Unive
the Art and Science of Lighting Visualization,
Morgan Kaufmann Publishers, 1998.
- Larson, G.W., H. Rushmeier, C. Piatko,
- ``A Visibility
+ "A Visibility
Matching Tone Reproduction Operator for
- High Dynamic Range Scenes,'' LBNL Technical Report 39882,
+ High Dynamic Range Scenes," LBNL Technical Report 39882,
January 1997.
- Ward, G., ``Making
- Global Illumination User-Friendly,'' Sixth
- Ward, G., "Making
+ Global Illumination User-Friendly," Sixth
Eurographics Workshop on Rendering, Springer-Verlag,
Dublin, Ireland, June 1995.
- Rushmeier, H., G. Ward, C. Piatko, P. Sanders, B. Rust,
Comparing Real and Synthetic Images: Some Ideas about
- Metrics,'' Sixth Eurographics Workshop on Rendering,
+ Metrics," Sixth Eurographics Workshop on Rendering,
Springer-Verlag, Dublin, Ireland, June 1995.
- - Ward, G., ``The RADIANCE
- Lighting Simulation and Rendering System,'' Computer
- Ward, G., "The RADIANCE
+ Lighting Simulation and Rendering System," Computer
Graphics, July 1994.
- - Rushmeier, H., G. Ward, ``Energy
- Preserving Non-Linear Filters,'' Computer
- Rushmeier, H., G. Ward, "Energy
+ Preserving Non-Linear Filters," Computer
- - Ward, G., ``A Contrast-Based Scalefactor for Luminance
- Display,'' Graphics Gems IV, Edited by Paul Heckbert,
- Ward, G., "A Contrast-Based Scalefactor for Luminance
+ Display," Graphics Gems IV, Edited by Paul Heckbert,
Academic Press 1994.
- - Ward, G., ``Measuring and
- Modeling Anisotropic Reflection,'' Computer
- Ward, G., "Measuring and
+ Modeling Anisotropic Reflection," Computer
Graphics, Vol. 26, No. 2, July 1992.
- - Ward, G., P. Heckbert, ``Irradiance
- Gradients,'' Third Annual Eurographics Workshop on
- Ward, G., P. Heckbert, "Irradiance
+ Gradients," Third Annual Eurographics Workshop on
Rendering, Springer-Verlag, May 1992.
- - Ward, G., ``Adaptive Shadow
- Testing for Ray Tracing'' Photorealistic Rendering in
- Ward, G., "Adaptive Shadow
+ Testing for Ray Tracing" Photorealistic Rendering in
Computer Graphics, proceedings of 1991 Eurographics
Rendering Workshop, edited by P. Brunet and F.W. Jansen,
Springer-Verlag.
- - Ward, G., ``Visualization,'' Lighting Design and
- Ward, G., "Visualization," Lighting Design and
Application, Vol. 20, No. 6, June 1990.
- - Ward, G., F. Rubinstein, R. Clear, ``A Ray Tracing Solution for
- Diffuse Interreflection,'' Computer Graphics,
- Ward, G., F. Rubinstein, R. Clear, "A Ray Tracing Solution for
+ Diffuse Interreflection," Computer Graphics,
Vol. 22, No. 4, August 1988.
- - Ward, G., F. Rubinstein, ``A New Technique for Computer
- Simulation of Illuminated Spaces,'' Journal of the
- Ward, G., F. Rubinstein, "A New Technique for Computer
+ Simulation of Illuminated Spaces," Journal of the
Illuminating Engineering Society, Vol. 17, No. 1,
Winter 1988.
@@ -1921,6 +2090,7 @@ SURFACES MATERIALS TEXTURES PATTERNS MIXTURES
Plasdata
Metdata
Transdata
+ BSDF
Antimatter
